Question about Eddie Bauer 22-859
I took the straps off to wash them and now I can't figure out how to put them back in. They're in....but I can't tighten them, I must have done something wrong
  • 5 Answers
SOURCE: Carsear Straps
I believe page 3 is what ur looking for. I have done this SOO many times, they get soo dirty soo quick!! Good luck and be safe!!
http://www.elitecarseats.com/assets/product_files/instructions/Eddie-Bauer/EddieBauer_3in1_manual.pdf
Posted on Nov 20, 2007
  • 25 Answers
SOURCE: having trouble with straps in car seat
Bring the straps up through the holes on the bottom of the seat, one on each side. The metal plate on the end should pull in flat and snug against the plastic. Slide the buckle pieces back on, making sure they're facing the right direction to snap in. Slide the chest clip back onto both straps.
Place the ends of the straps through the slots you want the harness at (at or below the child's shoulders for rear-facing, at or above the shoulder's for forward facing), making sure that they don't twist. Pull them down low behind the seat.
The adjuster part of the strap has a kind of Y shaped metal plate - pull it up to meet the ends of your straps, making sure that it
doesn't twist, either.
There are loops at the end of the harness straps. Feed the curved part of the Y through the loop of the strap that's on the same side of the seat. Pull it all the way through, so that the fatter part on the ends of the metal plate are exposed and curve around a bit beyond the strap so that it doesn't slip back off. Do the same with the other side.
Now adjust the harness to fit your child. When it's tightened properly, you should not be able to pinch up any slack, lengthwise, at the hips or shoulders, and it should lie in a straight line down the front, with no drooping. Also adjust the chest clip - it should lie even with your child's armpits - not up in the neck, and not over the belly, where it can't do it's job properly. (It's job is to hold the straps over the center of the shoulders...if it's over the belly, they're likely to slip down off of the shoulders in an accident or sudden stop and also poses the danger of internal injuries.)
One other thing - car seat harnesses should never be submerged in water, as it can damage and weaken the webbing. They should only cleaned with a damp rag. If you put your harness in water when you washed the rest of the seat, I'd strongly recommend contacting Cosco (contact info here) to order a replacement harness.
Posted on Feb 19, 2009
  • 50 Answers
SOURCE: i need to put the shlder/lap strap back in
the center of the belt will be under the seat coming up through the holes, place the two clips on the strap followed by the chest clip, then the neck protector pads. Push the ends of the strap through the two top holes. Route it down over the metal but under the plastic (on the back side) and attach both ends to the metal adjuster underneath. The receiver clip, you just turn 90 degrees and push through desired hole until the end catches.
Posted on Jan 24, 2010
  • 8 Answers
SOURCE: putting it back together
http://www.safety1st.com/usa/eng/Instructions?ProductNumber=22456CAO
Posted on Mar 02, 2010
SOURCE: how do i put the
HELP!!!!!!!!!!!!!!!! SAME PROBLEM, I CANNOT PUT IT BACK TOGETHER........
Posted on Dec 31, 2010
I cannot get the straps to tighten anymore.
Without the model/make it is hard to say what your exact problem is but normally the manufacture's site has links to the user guide. I do have three areas you may want to look over: First the sholder straps themselves sometimes have loops or labels attachted. Make sure these are not preventing the straps from moving through the slots. Second have you attachted the sholder straps to the splitter, a metal bar attachted to the adjustment strap, if it exists on your model. Have you attachted them correctly. Third see if the splitter is stuck on something in the back.
Mar 20, 2010 | Baby Gear
Graco nautilus 3 in 1 car seat need help with strap installation
Yeah its a bit tricky. ON the fron of the car seat there is a strap that goes intot he seat and has a button to lossen it. Press it down to lossen that strap then flip seat over and on the bottom you will find other end of the same strap and it has a brass t-fitting. Take it and pull it up the back side of seat and the shoulder straps fit into the brass fitting then tighten by pulling strap in front of chair.
HAve fun ;)
May 08, 2009 | Graco Nautilus 3-in 1 Car Seat
Someone removed all harness from my Cosco, Summit car seat. I cannot figure out how to get them attached and will not do it without knowing I have done it safely. Help!
My daughter has a car seat just like this one, and I wash it about once a month so I hope I can explain this detailed. First, at the base there is a metal rod that will need removed. When you take this rod out the base and seat will seperate. Set base aside and turn seat upside down. Take your strap and put an end into each slot. Turn seat over and pull your straps even. Put the two black pieces for your latch on (one on each side) then put you chest pieces on and run straps thru slots on back of seat. Turn seat around and make sure the straps go OVER the silver bar in back (this allows you to adjust shoulder height) Secure to the metal piece that runs to front for tightening adjustment. Sey seat back on base and replace rod. Hope this was helpful.
May 04, 2009 | Cosco Summit 22260 - Houndstooth
Harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Mar 08, 2009 | Century Encore 5-point Harness
Need instructions on putting together
Here's a link to a photo of the Century Breverra. From the photo at this website, I was able to figure it out. http://www99.epinions.com/review/Century_Breverra_Ascend_Sport/content_22722481796
First, thread the strap through the piece that clicks into the crotch point. Then, thread the strap through the **** on the seat just to the side of the crotch lock. Run the strap under the chair and through the **** on the opposite side of the bottom of the lock. Then, run it through both sides of chest lock, up through the shoulder points and lock it in the back. You're done!
It's not very eloquent but hope it helps!
Dec 30, 2008 | Baby Gear
Britax Car Seat First Class SI
i took the cover off the car seat and straps to wash the cover but have no clue how to put them back on.
Sep 03, 2008 | Britax Eclipse Si - Paris Convertible Car...
Taking apart for washing
disconnect the belts and snaps, it takes a little time to figure out how everything disconnects but it all comes off and you can wash it
Jan 23, 2008 | Eddie Bauer Lightweight Travel System...
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Carsear Straps
Nov 01, 2007 | Eddie Bauer Deluxe Convertible
Eddie Bauer 22-859 Logo
50 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Nikki  Mclean
Nikki Mclean
woodzowl307
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
