Question about Proton MM2701VT 27" TV
Magnavox MS3252S431 The screen on my 15 month old Magnavox model MS3252S431 (chassis L01-1UAC-7638) 32-inch TV goes blank with a clicking sound. The green power light stays on. If I power off the TV and then power on again everything is fine.... sometimes for a few hours, sometimes the problem occurs again in a minute.I change the resister R 3340 still same problem plus first the volume bar will appear and sometimes lower the volume by itself. then the main tv menu will appear on its own and randomly move thru the menu. the 3rd stage is it will do all of this
Replace:
Q7461 C33725
O7463 C32725
C2455 47uF@50V
Posted on Jun 17, 2008
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Sep 14, 2009 | Samsung DLP HL-P5663W 56" TV
What is the Chassis # for this model?
Hi
the chassis number is located at the back cover of Tv, and to PCB.
Thanks!
May 29, 2008 | Philips Magnavox MS3252S 32" TV
Magnavox MS3252S431
Replace:
Q7461 33725
Q7463 32725
C2455 47uF@50V
May 22, 2008 | Proton MM2701VT 27" TV
JVC 32 INCH MODEL AV-32S585
is the bright line on the midle of the tv , if it's what u ia vertical problem also sometimes is the flyback , tv needs service ,
Apr 30, 2008 | Televison & Video
Screen is black
on that tv you have to check just for circuit of high voltage - check
transistor near flyback transformer - delfo
Dec 11, 2007 | Philips Magnavox 27MS343S 27" TV
Magnavox 32" tv ms3252s431 shutting off
Usually, the L01-1 chassis most common problem = weak
capacitors, such as C2455.Could be C2425......47mf/25v...
Check all caps around horiz drive xformer = an ESR meter
helps on this one + a skilled, experienced technician......T.
Nov 19, 2007 | Televison & Video
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Televison & Video
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Proton MM2701VT 27" TV Logo
346 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
