Question about Sony Playstation 3 (PS3) Console
1080p resolution question
I have mlb 08 the show for ps3 and it supports 1080p resolution but it won't display that on my tv........ now i have an hdmi cable for my ps3 and my tv is 1080p compatible.......... so i know that i have all the right equipment.....hope you can answer this question for me......thanks ,bob
    Champion:
  • 207 Answers
Hey bob do you by chance have a 20gb ps3, if you do then that option is not avaliable to the ps3, I know its crazy but its true if thats not the case let me know i have another Idea that might work but let me do a little more research on it!
Posted on May 27, 2008
How to set display to 1080p on Hisense F42K20E?
You don't. The TV has a resolution of 1920 x 1080 pixels; so it's already 1080p. The number of pixels can't be changed.
What you're probably getting mixed up with is the TV showing the resolution of the incoming signal when you change channels or go to a different source. Standard definition from cable might be flagged as 480i. DVD might show either as 480i, or 480p, or maybe 720p or 1080i or 1080p if you have a scaling DVD player and set it appropriately. HDTV on cable or satellite will show as 1080i or possibly 720p. Blu-rays and PS3/XBox 360 or PS4/Xbox One should show as 1080p when your TV is connected.
Whatever the source signal resolution, the TV will scale it up to fill the panel area of 1920x1080 pixels. So the TV is always using all the pixels, regardless of the resolution of the source signal.
Sep 07, 2014 | Televison & Video
Dynex HDTV says not supported when PS3 is connected via HDMI
Have you tried changing the video output settings on the PS3? It may just be on a setting that the TV does not support. For instance, if the poutput setting is 1080P, and the TV only supports up to 1080i, you would get a "not supported" signal. Hook the ps3 to a tv that it works on...turn it on, go to settings- display settings-output settings- select HDMI as the connector type- if it asks for 3D tv size...select the size- now you need to set the resolution...select all resolutions that the TV supports, since it is a dynex...it is likely a 720p TV. So I would start by selecting only 720p, and then hook the system to the Dynex TV and see if it works now. If it works, you can go back in and attempt to select 1080i or 1080p to see if they work... but again, being a Dynex, it is probably only a 720p TV... The PS3 is likely trying to output a 1080i or 1080p signal...which that TV doesn't support.
Mar 21, 2014 | Video Game Consoles & Games
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Out of range
Right i'm halfway to understanding what's going on.
It sounds like your ps3 is readjusting the resolution to something the new tv isn't compatible with.
Looking at the t.v (bravia v4000), it should be compatible with all resolutions upto 1080p.
What happens when you turn the ps3 on initially (plugged into the new tv) ? It doesn't go straight into the game, so what happens and what boxes in the display settings do you have the resolution set to?
You should only have 720p and 1080p ticked.
The 40v4000 supports 1080p so when the PS3 auto-detected the display settings it set the XMB to 1080p, the 32v4000 supports 720p but the PS3 still thinks its connected to the 40v4000 so it is trying to output 1080p which is out range of the 32v4000. Go to the display settings on the PS3 and auto-detect the display settings again
Feb 13, 2010 | Sony Playstation 3 (PS3) Console
MY PS3 DOES NOT SEEM TO BE WORK WITH THE HIGH DEFINITON CABLE IT CAME ON FORA FEW SECONDS THEN SCREEN COMES UP WITH NO SIGNAL????
This usually happens when you first buy your ps3 and try to use the HDMI connection immediately. The problem is that the ps3's default output resolution is set to 480i out of the box, and when you try to use an HDMI connection first, HDMI can't do that resolution. HDMI only does 480p, 720p 1080i and 1080p.
See :)
This also happens if you move your ps3 a lot. As it is, HDTV's are either 1080p (full HD) or 720p (including 1080i). If, for example, your tv is 1080p, when you set your display settings in the ps3 menu, it will set your XMB, or ps3 main menu to the max resolution of your tv, 1080p in this case. The resolution will automatically adjust when you start a game, and that game has a native resolution output. That's why, most of the time, games will play in 720p, because that's there native, or original, resolution. This is also the reason why sometimes people have no display on there TV, or a black screen, and when they play a game, that will actually display. That's because your tv can ACCEPT that resolution of that game.
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
My 42LG50 won't accept the 1080p output from my PS3 Plz help.
Most PS3 games do not support 1080p, so if u have a 1080p supporting game, only then can u do it.
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Just wondering if you could tell me the best way to set up the TH42PZ70BA LCD Television to get the best results from the PS3
This is very easy. Just hook up your PS3 to your TV via HDMI cable and set your TV and PS3 to 1080p resolution. On the PS3 all you have to do is click "Display settings" and then go to HDMI output AFTER you have hooked it up. Just click on 1080p and 720p because some games do not support 1080p resolution. Hope this helps!
Dec 29, 2008 | Philips 19PFL5622D/37 19 in. LCD...
Sony Playstation 3 (PS3) Console Logo
64 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
