Question about ViewSonic VX900 19" LCD Monitor
Screen all white
When I turn on my computer and monitor, the screen is just all white. I have tried a new VGA cable and hooked up the monitor to another pc, and still the same problem. Any ideas what this could be?
  • 1 more comment
  • askladydi May 27, 2008
    It is an lcd. I would like to fix it if possible because it is an expensive monitor.
  • MalcolmP Jun 17, 2008
    white screen when turned on no picture on screen controls dont seem to do anything
  • john wasson
    john wasson May 11, 2010
    is it a crt, lcd, or a plasma monitor? it also sounds like there is a problem displaying the information to the screen, either of the monitors could be a voltage to the crystals in a lcd, in a crt it could be a vacumm tube problem try using a diff monitor or replacing it
Netrecov - you clearly did not read the original post, therefore explaining the lack of any usefull response from you.
Seeing as it is an LCD, it uses a backlight to illuminate the pixels. this is clearly working (you see white), but it is not displaying the image data over the backlit screen.
I would suggest looking at the inverter or at least in that area.
- TimeMeddler
Posted on Jun 27, 2008
I GOT THIS MONITOR/TV FROM DAUGHTER, I DON'T HAVE MANUAL. HOW DO I HOOK IT TO MY COMPUTER TO USE AS MONITOR. WHAT CABLES AND WHAT PORTS? THANK YOU
Tries Element website itself if ur LCD tv model still in the market u can download manual for free not look for their phone number like 1-800..call them pay them a fee they'll send out a copy of the manual to u.U have a LCD monitor now hook up to ur computer right now to used as a monitor now wright?Yes.Take that VGA cable out from ur computer and ur old LCD monitor VGA cable out of the VGA ports just take ur hand and unscrew the VGA cable.Used ur old LCD monitor VGA cable and hook up to the LCD tv VGA port and to ur computer VGA computer graphic card port or computer monitor port hook up the other end.Turn on ur Computer and tv on used the sides button of the tv find one that said INPUT push it a few times should find ur tv mode 1,2.3 ur computer is on as a monitor.
Aug 19, 2011 | Element Electronics FLX3210 32 in. LCD TV
I want to connect my dell inspiron 1525 to my lcd hd ready tv but have no idea how to? Does anyone have any advice?
The 1525has a a hdmi port which you can plug a hdmi cord into. This may not support the audio. the tv and pc should detect the new monitor automatically or you may have to toggle it by hitting F4 key.
Apr 22, 2011 | Dell Computers & Internet
How do I fix my hp w17e monitor that reads "VGA no signal"? I've tried unplugging my power cord and holding the on button for 30 seconds to a minute and plugging the power cord back in it still...
VGA no signal means "no signal" from the computer on the VGA (blue plug) cable... ...if the computer works check the cord for loose connection or get a new cord...if the computer is hooked to the digital cable (DVI/white plug)...set the signal source on the monitor to digital...
Feb 14, 2011 | HP w17e Monitor
I purchased a gateway HD2201 monitor all I see is white screen
Maybe your resolution is not set to the right settings for your new screen, set the resolution and refresh rate lower with the old screen attached and try again with the new screen
Jul 18, 2010 | Gateway HD2201 22" LCD Monitor
Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Jul 21, 2009 | LG 22" FLATRON LCD Monitor
Fuzzzy noise then blank screen....
Sounds to me like the power board may be bad on that monitor, espeically since it made funny sounds and usually bad transformers will make those types of sounds.
Make sure you don't have any bent pins on the vga cable and also hook up the monitor directly to a wall outlet to be sure a surge protector isn't causing problems.
Now hook up the monitor and also make sure your computer is turning on and booting up cause if the computer is not running properly then that could cause no video as well.
If you still have no video, then go ahead and hook up a known working monitor to the computer, if you get video with this monitor but not the original then you know that the original monitor is bad. If the new monitor gives you the same symptoms then it could be a problem with the video card or motherboard issue if your not getting any video from the computer at all.
Jul 05, 2009 | Hannstar I-Inc TW-191D Monitor
Monitor screen changes from regular color to a green tinted screen?
Looks like you need to purchase a new monitor. If it's too worn out then it's the outcome. I also had the same problem before and I ended up buying a new one. You should not experience that thing if it's new.
May 27, 2009 | Dell 1503FP 15" LCD Monitor
ViewSonic VX900 19" LCD Monitor Logo
83 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
