Question about JVC KABOOM RV-NB10 Boombox
What can be done about the rubber sides of the kaboom box that seem to be melting as when you rub your hand black material comes off in your hand. The same thing happened to the rubber volume and bass controls but I replaced them. The replacement s are in black plastic so they know their is a problem. Any suggestions? Thanks, Gene
2 Suggested Answers
The tapered lip on the rubber seal on spool of control valve for 1956 thunderbird power steering 2 seals each side i need to know in or out?
A general rule of thumb for oil seals is the way they are made.
Take a seal and look at it.
The rubber seal should attach to the ring on one side, and be on (rubbing) the shaft on the other.
Usually the side that is rubbing the axle tightly is the side with the pressure, as that side, when pressurized, rubs the shaft more tightly.
I hope I have described this for you .
God bless your efforts.
Jul 11, 2017 | Cars & Trucks
How can I clean the melted rubber seal from a Bialetti Top Espresso Machine?
I scraped off as much melted rubber as possible - using my thumb nail - then used a product called Goo Gone to melt the remaining rubber. I put Goo Gone on an old cloth and rubbed off the remainder of the rubber - again with my thumb nail.
Jan 08, 2013 | Bialetti 20-9 Stove Top Espresso Machine
Air filter change
3.1; 3.4; and 3.8 motor all have air box located in the same place. if you pop the hood and are staring at the engine, it is the black box that has a large rubber tube that comes off of it right on the right hand side...the square lays right next to the frame of the vehicle. there are either a few a couple of screws or a couple of clips. air box separates and filter comes out
Nov 13, 2010 | 2004 Buick LeSabre
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
My printer keeps on jamming, says I need to re-align the paper, which i've done but the paper won't feed through. Someone please help. Thank you! Anna
Try cleaning all the rollers with 90% rubbing alcohol, as well as any tight spaces on the printer... Use Q tips. Also inspect rubber rollers for wear and replace any worn ones (they're not expensive).
You may also have some paper jammed deep in there. taking the printer apart and cleaning everything with rubbing alcohol should solve that.
Apr 14, 2009 | Lexmark X5470 All-In-One InkJet Printer
Certain numbers on the hand held set do not respond when pressed. The nubers are 9 and, sometimes, 3 on the touch pad of the hand held. Why is this and how can I fix it? Thank you so much for any help you...
Sounds Like The Key Pad Backings Are Dirty This Happens With Time. You Can Fix It By Taking The Phone Apart And Accessing The Rubber Pad Behind The Numbers. Clean The Black Circles On The Rubber Pad With Rubbing Alcohol And A Q-tip Also Clean The Receiving End Of The Black Rubber Side Also Known As The Circuit Board. There Are Half Inch Or So Circles On The Circuit Board, Clean Them Off Using A Q-tip And Rubbing Alcohol As Well.
Please Note: Remove The Battery Before Attempting This And Find Any Screws That Are Holding The Device Together. After That Get A Small Flat Head Screwdriver And Work It Between The Gap Along The Entire Edge Of The Phone ( Starting With The Mouth Piece Is The Easiest) Please Take Extra Care Not To Break The Phone If You Still Cant Seem To Get It Apart Please Check Again For More Screws.
Jan 09, 2009 | AT&T 650530003417 Cordless Phone
The rubber armoring is "melting" or getting all sticky
It can be easily resolve, just go to the youtude, check for sticky melting solution. The sticky surface can be treated and back to normal.
Dec 11, 2008 | Bushnell Optics
Rubber Grip Has Developed "Sticky Spots"
The best and cheapest way I have found is to use 91% isopropyl (rubbing) alcohol...put a little on a paper towel, cloth, or cotton swab and rub the stick stuff off. I would also suggest putting on rubber gloves to keep the black stuff off your hands. Have fun.
Oct 03, 2008 | Nikon F65 35mm SLR Camera
JVC KABOOM RV-NB10 Boombox Logo
76 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
