Question about RCA HD52W59 HDTV Projection Television
The Power button comes on three times but does not remain on after that. Is it the transformer?
  • RCA Master
  • 5,138 Answers
Look on the Deflection board for 3 Bad Capacitors CP150 2200uf 16v use 25v CP114 CP120 if CP 150 is vented or puffed up on Top replace all 3 caps.
Deflection board is bottom left hand side with FBT .
Posted on Sep 27, 2010
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Will not power on, tries 2 times then off
actually it has a 3 strikes and out feature--will try three times and if does not make it on shutdown.
most issues with these are bad solder connections around the High Voltage transformer.
Nov 27, 2012 | RCA Televison & Video
52 Inch RCA D52W17 BYX1 projection screen tv cuts off when i TURN ON
The set literally has a 3 strikes and you are out where it will try three times and go to shutdown.
The common issues this set has are bad solder connections under and around the high voltage transformer and also in some cases the High voltage splitter block (located way up front behind lower grill below screen unit and behind a removable inspection plate).
The transformer rarely fails but can--photo of what is general appearance of this type of part is attached.
Oct 26, 2012 | Televison & Video
What's your problem?i have a rca tv model number d52w14 and it will not turn on just the power button comes on and goes off three times?
The set actually has a "3 strikes and you are out design".
It will try three times and if fails shut the set down.
This model is prone to bad solder connections at and near the high voltage transformer---also to bad parts in that same area which include: the transformer, the sweep transistor near it, and the high voltage splitter block it feeds.
6_12_2012_3_08_16_pm.jpgTypical high voltage transformer that is also called a FLYBACK.
Jun 12, 2012 | Televison & Video
Don't know access code. Bought used control panel
2. Unplug the transformer and disconnect the battery.
3. Simultaneously press and hold Cancel, Clock Set, and
Minutes +.
4. Restore power to the panel with either the battery or the
transformer while pressing these three buttons. The
panel announces “Hello. System XX OK.” Release the
buttons.
5. Connect the remaining power source to the panel.
- AlarmProfessor.net
Jul 16, 2010 | GE Security Simon 3 Wireless Home Security...
Push power button and lold it in green light blinks one time and then nine times fast and then cuts off light try a few seconds later and green light comes on for a few seconds and off it does this three...
Hi:
You are in HV shutdown mode, Have the Horizontal output transistor replaced as well as the Horizontal output transformer. These are the most common failure for this problem, The three blinks indicates Delfection problem, and these parts are part of the main High Voltage Deflection circuits.
Dec 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pushing on power button three green lights come on for one secone
click here you would find the details for led codes. you may select any laptop. codes remain the same.
Sep 24, 2009 | Dell Latitude D600 Notebook
Wont come on green light comes on three times
Check hori output Transistor if it is shorted set will not come on Part # NTE2324 if it is ok CK second ribbon connector on the deflection board going to board on right. make sure it is in good if it isnt set will make noise and not come on,
Dec 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv won't turn on. power indicator light comes on then goes off after about three seconds, then retries twice more then locks out.
That is what these sets will try to do if the power supply detects a short. The set will try three times to come on then shut down again till you pull the plug or press the power again. It is not really a diagnostic code. Most likly your problem is the horizontal output transistor and or the flyback transformer. Very common problem for this set. good Luck Please do not forget to rate this thread.
Dec 15, 2006 | RCA HD52W56 52" Rear Projection HDTV
POWER PROBLEMS????????
If the set trys to turn on and makes noise three times then you hit the switch again and it will try to come on again churping three times , its a shorted horizontal output transistor and a bad flyback transformer. And Im sorry to tell you the transformer is no longer available according to RCA. Its a shame. I just threw out a 56" and a 32 " set that needed a flyback and could not get them.. Well good luck ps please rate this thread.
Oct 19, 2006 | RCA P52835LV 52 in. Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
37 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
