Question about ZT Group Cisnet PC Desktop
I need a RAID driver for CA-3002M - ZT Group Cisnet PC Desktop
How to installed xp2 in server hp proliant ml 350 my hard drive ok
You may need raid controller driver for HP proliant ml 350. Copy raid controller driver in flopy disc, insert it in flopy drive, insert cd in cd driver, boot server from cd and start installation process, as soon as you see Press F6 if you need to install third party scsi drivers or raid controller, press F6 and follow the instruction. It will then ask you to select RAID driver file and then will continue to windows xp installation.
Regards,
Kaushik Patel
Aug 24, 2013 | Computers & Internet
Intel Raid Card axxrmsll040 configure problem
need to download driver for raid driver https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Server%20Board%20s1200bt%20Family
May 05, 2013 | Intel Computers & Internet
Raid 1 needed to replace single IDE disk
go to hp.ca you can download ide driver updates
Jan 12, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
How to install windows 7 on Satellite A205-S5880
To install Windows 7 no need for RAID driver. If you face issues in installing Windows 7 disable RAID in BIOS, install Windows 7 and then install RAID driver.
How To Manually Upgrade from Vista to Windows 7 - Satellite A200/205:
http://cdgenp01.csd.toshiba.com/content/support/downloads/PSAF3U-PSAF6U-Win7UpgradeInstructions.pdf
Windows 7 Drivers page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2060003&rpn=PSAE3U&modelFilter=A205-S5880&selCategory=3&selFamily=1073768663
Dec 31, 2009 | Toshiba Satellite A205-S5880 Notebook
I have a toshiba labtop with 2 hard disks working as raid. but I have formated my computer and now I lost the raid technology , so how can I restore it. I have the recovery CD and it should do it...
u will need a os setup disc which contains sata/raid support. u can make this setup disk. find out which sata/raid text mode drivers needed (i can't tell u which txt mode driver is needed as i don't know the model no. of the laptop)
find textmode driver needed for your model no. using google.
copy os setup disc(windows) on to the hard drive. use nlite to integrate textmode sata/raid driver. burn a bootable disc.
Recovery disc wont work as u have already formatted the drive.
Oct 06, 2009 | Office Equipment & Supplies
Gateway e-9425r was setup to boot via PXE. I want to boot off a raid. Have 2 250gb sata drives in system. Loading raid driver from gateway site on floppy. Windows install and bios don't detect raid or...
Copy RAID driver to mini diskette.
Boot server using Windows Server 2003 CD
The moment you see the blue setup screen press F6
After the setup runs for a little while it will ask you if you have any additional drivers you need to install
Then insert your mini diskette with the RAID driver and respond to prompts to load it.
Windows should no recognize the RAID controller and let you complete the installation.
Aug 10, 2009 | Gateway Computers & Internet
About operating system
That depends on how you want to set up your system. If you want multiple hard-drives to work together as one, yes, you will need to load RAID drivers during startup. If you do not want multiple hard-drives to act as one large hard-drive then no, you will not need to load RAID drivers during startup.
I would not recommend loading RAID drivers if you only have one hard-drive. RAID is for two or more hard-drives in the same computer.
Feb 18, 2009 | VIA MSI K8M NEO-V K8M800 Chipset 800MHz...
Raid failure
Not a lot of details, but here is some basic information, assuming you have a Dell with Integrated RAID
Dimension 9150/9200 and XPS systems have RAID, depending on the model the exact troubleshooting differs. At boot, after the Dell screen, you should get the RAID status listing. RAID 0 will either be normal or failed. Raid 1 can be normal, degraded for failed.
If the RAID array was RAID 0 and one of the drives failed, then all data is lost and you'll have to create a new array then reinstall Windows and drivers
If the RAID array was RAID 1, then you may need to add the new drive to the Array, CNTL+I or CNTL+N at boot (Depending on the system model) add the new drive to the array and reboot. If the system still will not boot to Windows, then you may have a software error too with the OS.
If during troubleshooting, the array was broken in the RAID BIOS, then the array will need to be recreated and Windows/Drivers reinstalled.
Jun 11, 2008 | Dell Dimension 2350 PC Desktop
I need Abit BL7-RAID Motherboard driver
Download drivers from following link
http://drivers.softpedia.com/progDownload/Abit-motherboard-BLRAID-Download-906.html
Jun 08, 2008 | Abit BL7-RAID Motherboard
RAID Driver
It can happent for 2 reason :
1) You have a problem with RAM MEMORIE OR
2) U need to install driver for HDD ( raid driver )
U should olso dust Power Suply and Cooler onto procesor!
To install Raid driver u need to have ORIGINAL CD OFF MOTHER BOARD .If u haven't tell me i will help u!
Oct 10, 2007 | Intel Motherboard
ZT Group Cisnet  PC Desktop Logo
46 people viewed this question
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
Nerd Rage
Nerd Rage
didi2005
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
