Question about Ricoh Office Equipment & Supplies
Ricoh1035p\r\ncopy is faded at top about 1/2"
  • 126 Answers
Clean the target glass of the copier. open the front cover. just below the toner supply unit ther is slot where a glass goes through. pull the **** glass slowly and clean it because toner must have gone onto it on one side.
Posted on Oct 01, 2010
I have a bizhub 300C. When I print a pdf the top inch is faded
Mike does this happen with all prints? does it go away if you change the orientation of the paper. portrait to landscape? Happen when you copy ? Try different file type does that change?
Jan 29, 2014 | Konica Minolta Bizhub C300 All-In-One...
I have a HP 7590 printer and it sometimes skips line or some of the lines are faded when printing black .
Perform the following steps to reduce or eliminate faded or grainy lines:
  1. Print at a higher quality setting.
  2. Verify that the paper you are printing on will lay flat. Paper that is not laying flat can cause banding when the paper transitions over the rollers or cause the print cartridges to scrape across the surface of the page. Check the top sheet of paper by removing it from the all-in-one and placing it on a flat surface. If the paper does not lie flat, bend it in the opposite direction to straighten it. Figure 3: Faded or grainy bands in print caused by paper that is not flatc00178858.gif 1 - Faded or grainy bands due to roller transition with paper that is not flat. 2 - Faded or grainy bands due to print cartridge scrape on paper that is not flat
Jan 06, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
HP Deskjet printer 6940 clearly prints only top half of a page. The lower half fades and some lines fade completely. Many thanks for your help!
This problem is mainly due to driver corruption
1. Reinstall the driver or scan for viruses and remove it.
2. Remove all temp files from the drive.
3. Try removing corruption in OS or reload OS.
4. Try connecting to another system and take print out.
5. Chipset on the printer may be having problem, get it serviced.
Sep 05, 2010 | HP Deskjet 6940 InkJet Printer
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Apr 01, 2010 | HP LaserJet 4 plus Printer
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
May 27, 2009 | Compaq Presario M2000 Notebook
The toner colors fade out on the top 1/3 of page, black is better
Maybe you have some dried ink on the cartridge. You see the silver-ish strip on it? try whipping it down with a rag because I dont think you want that ink on your shirt. Try that and if not let me know.
-Ryan
-Please rate
Feb 18, 2009 | HP LaserJet 8500 Color Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
27 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
