Question about LG 42LG70 42 in. LCD HDTV
I have an LG 32LG70 LCD TV. I use it primarily for gaming now. I have had it for 2 yrs. The screen has packed in... I can only see a few vertical lines on the screen and pick up no signal or picture from the TV menu or the game console
4 Suggested Answers
SOURCE: 42" LG Plasma with 4" vertical lines at each end
LG service is non- existent . The only solution that I can suggest is "Give a wide berh to LG products. Dont ever touch any"
Posted on Mar 09, 2008
gopakumarg43
  • 74251 Answers
SOURCE: LG - 32LD350 - 32" LCD TV - 720p is the type of tv
Hello
It has been permanantly damaged, and is not repairable. To get it work perfectly, you have to replace the screen. OK.
Posted on Aug 03, 2011
nielbales
  • 9 Answers
SOURCE: ive been using my ps3 on my lg 42'' lcd tv for 3 yrs now perfectly then this past few when playing a game i keep getting lots of lines distorting my picture after about 5mins of that it goes b
Sounds like a blown capacitor on your board to me. Its a common problem in Samsung TV's and is typically an easy fix, but I think in the LG's its a bit more expense and not as easy as swapping out a Capacitor. I think the main board may have to be replaced there. What actually happens is the capacitor bursts at the top and oozes liquid that solidifies, its caused when the capacitor that is used is underrated for the application (basically some engineer's solution to making us have to buy a new tv in 3-4 years, a slightly underrated capacitor will have a shelf life of use, kind of like a timer, they all do it belive me) eventually the set will not rendure any picture at all and the board will have to be replaced.
Posted on Mar 01, 2012
Fixing an LG TV model 32LG70-UA. TV has banding lines present on screen. All the capacitors look okay on the main power board. Should I just replace the entire board?
if you mean lines on the screen, white or black then the problem is the screen connection, this is not a job for the faint as it involves removing the screen casing and the screen is very delicate. on the screen connection there are strip thats connect the screen to the screen boards there is 2 boards in the screen they can come away. sometimes and they would need the padding changed and reseted, so the screen contacts properly.
Jul 25, 2017 | LG Televison & Video
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
My 32LG70 won't turn on and the screen remains blank.
Try resoldering everything back onto the power board.They become brittle sometimes.
That doesn't do it then buy a cheap cap meter off ebay for around a tenner and firstly pull off every single electrolytic then ceramic capacitor and test.
Very easy to test,look on YouTube for videos.
Replace faulty&marginal caps and your problem should be gone.Remember m8,take your time,don't rush these things.
Jun 05, 2010 | LG 37LG30 37 in. LCD HDTV
LG 37lH20 LCD Aspect Ratio Problems
Not ur tv it the dvd format,tries it with other dvd.
Nov 23, 2009 | LG 37LH20 37 in. LCD HDTV
Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
May 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
LG 42LG70 42 in. LCD HDTV Logo
91 people viewed this question
Computer Repairing
Computer Repairing
