Question about Maytag MTB1976HR Top Freezer Refrigerator
Refrigerator has sticky liquid on floor beside it and is freezing some things- and other things ot cold enough
the dr
  • 447 Answers
SOURCE: My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Posted on Oct 03, 2007
Master_Tech
  • 770 Answers
SOURCE: Refrigerator not cold enough
check the back wall of your freezer for a heavy frost build up rhis is an indication of a defrost problem also make sure the fan in the freezer is working
Posted on May 11, 2008
Krazytech
  • 725 Answers
SOURCE: amana side by side does not freeze nor does it get cold
first check you freezer back for frost if a lot of frost defrost the whole freezer ,,, then plug back in and see if it will work..
let me know
Posted on Jul 08, 2008
  • 291 Answers
SOURCE: Maytag freezer & refrigerator not coold enough
It's not cool If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator. I feel heat/warmth on the front edge of my refrigerator....why?
Older refrigerators had electric heaters on the edges of the refrigerator cabinet to help prevent moisture from building up, especially in the hot/hazy weather in the summer time. These electric heaters usually had a switch where you could turn them on or off...had words like..."switch here to prevent moisture"...switch here in damp weather".... in the picture it is in the top left of the control assembly.
Then along came the energy crunch. The manufactures stopped using the electric heaters and started running a pass of the hot condenser tubing on the edges of the cabinet where the electric heaters use to be. This is often called ayoder loop tube SxS version and the yoder loop tube Top freezer version. This has now replaced the electric heaters. If you feel heat/hot around the door opening of your refrigerator you should....
clean the condenser coils as a dirty condenser can make the tubing hotter than normal
- check/clean & replace if necessary the condenser cooling fan   ( # F ) motor, if the condenser fan motor is slow or has quit the yoder loop pass will get very warm/hot to the touch
- If the condenser coils are clean and the condenser fan motor is running ok, check the fresh food and freezer section temperatures...if the refrigerator is not operating well and the temps inside are warming up, you could feel more heat/warmth than normal
Posted on Apr 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 25, 2009
I just replaced my automatic ice maker in my Samsung french door refrigerator. Now the temperature is not cold enough to freeze the water which leaves the ice bucket with water not ice. Freezer works
Repair for a Freezer That Is Running But Not Freezing ...
homeguides.sfgate.com > ... > Other Types of Mortgages
This is the heat you feel blowing near the freezer when it's in a cooling cycle. ... Also, using a freezer to cool hot items or opening the freezer frequently will ... If you noticewater pooling on the floor when the freezer is running but not freezing, ...
Why Is My Freezer Not Cold Enough? - Articles - Networx
www.networx.com > ... > Electrical > Appliance Repair > Read Article
Sep 1, 2011 - Next, make sure the freezer isn't overloaded and that the evaporator fan ... are choked with frost, restricting the airflow that makes the freezer cold. ... In verycold weather, a freezer in the garage may heat up, since there isn't enough warm ...unit (even on automatic-defrost units, in case there's a lot of water).
refrigerator - Freezer is cold but not freezing at all - Home ...
Dec 20, 2015 | Refrigerators
Kenmore Model # 596.72253200 My freezer does not freeze it's cold but not enough to freeze and the refrigerator it's not cold enough I have it on couldest but it's not working well
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Refrigerators
My friend was going to wax her legs and was warming the wax up in the microwave when it bubbled over and made the wax bowl stick. Pulling to get it out she spilt it everywhere , in microwave , on my...
since it is a sticky wax and not paraffin or candle wax do not reheat it to remove it. Get an ice pack or stick some ice cubes in a ziplock bag and rub on the wax until it freezes/gets cold enough to crack. It should come off of all of those surfaces pretty easily once it has been cooled enough not to be sticky.
Aug 21, 2011 | Microwave Ovens
My samsung side by side stopped cooling and freezing. Found a stick liquid on the floor.
heatman101
Mar 28, 2011 | Samsung Refrigerators
Fridge is freezing all liquids freezer is turned down as low as possible and liquids are freezing
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 24, 2011 | Magic Chef CTB1922 Top Freezer...
Hello I have a frigidare refrigerator Model #GLRS64ZEB7 that doesn't get cold. I cleaned the condensing coiled. I tried it and it still didn't work??? The compressor is running the suction line is getting...
Unit is low on freon......
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 14, 2010 | Frigidaire FFHS2311L Side by Side...
Not getting cold, freezer freezes food but refrigerator cool..
The fridge gets it cold air from the freezer. There is like an air tunnel that goes from the freezer (usually in the back) to your fridge to provide cold air.
What probably happened it the tunnel is blocked with ice or another liquid. The easiest thing to do is unplug the fridge for 24 hour so the ice can melt.
May 30, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Things are not freezing
the gas is near finish in the system,or check out if the door is close firmly,no leaks
Jul 22, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator doesnt sem to be working right
Ice maker will not work if temp in freezer is not cold enough to keep activated
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting
Oct 08, 2007 | GE Profile PSI23NCR Side by Side...
Maytag MTB1976HR Top Freezer Refrigerator Logo
57 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
