Question about SanDisk Sansa E280 MP3 Player
My e280 says free up 90 megs of space. but devive won't allow me to do anything to it . Format or delete any files. I think device has no head room. thanks Jean
  • 3 more comments
  • kakima Sep 27, 2010
    Disconnect from the computer if connected. Remove the microSD card if one is installed. Press and hold the power button for fifteen seconds. Does this do anything?
  • YourZEN
    YourZEN Sep 27, 2010
    Hello, are you able to connect the player to your computer, seeing the player as a removable disk ? Next link might help :http://kb.sandisk.com/app/answers/detail...
  • jcabral19 Sep 29, 2010
    Nothing happens computer sees device but can't format or manipulate files. thanks jean
    no thing happens can' t format or delete any files. thanks jean
  • YourZEN
    YourZEN Sep 30, 2010
    Can you switch USB mode connection to MSC mode and then try again ?
    See next link: http://kb.sandisk.com/app/answers/detail...
    How to force MSC mode, consult next page: http://kb.sandisk.com/app/answers/detail...
Try this. I found it on another forum, and it was the only thing that worked for me. Note: Be Patient! The chkdsk function takes a LONG time to finish. I went away from the computer and did something else and came back. Thanks to neutron_bob on the sandisk forums for this:
The database fault you are encountering is a sign of a corrupted music file causing the database refresh operation to halt.
No worries! You can manually enter MSC mode, run chkdsk, and even the nuclear option, a device format, if you wish.
Let's start with the simplest. Start with the v2 family device off (Yes, this will work for the Fuze or Clip too, one of the advantages of the new device family). Slide the HOLD switch to the orange position on the e200v2, to the right.
On your computer, press [Windows key] + E and open a Windows explorer window, or use "My Computer".
Back to the v2: hold the center button down while connecting to the PC. In a few seconds, voila! Your device will be visible as E: SANSA E200P.
Okay, I know the salty dogs out there are thinking, "Bob listed the wrong button again!" but I'll let you in on a secret: the v1 is different, and forcing MSC mode involves the
Now, why not try a simple fix of the music files in the hope of getting it running.
Press the [Windows key] + R to get the Run box open. Enter cmd and you'll get an MSDOS command line box. Enter chkdsk E: /f where E: is the drive letter for the internal memory E200P shows up with. The /f toggle tells the utility to fix the errors found. Tell it to discard (don't save) the garbage found.
Turn the HOLD switch back, and disconnect. See if your Sansa boots and runs normally.
What happened then? If the wee beastie is still being troublesome, let's go to step two, but be forewarned, this method will erase all media from your Sansa, and it will have to be reloaded. Plug in again in MSC mode as above.
In the Windows explorer box, right click on the Sansa, select Format, and DO NOT use the Quick Format option. Select FAT32. This is the nuclear option. Unplug, reset the HOLD switch, and you should have a "naked" Sansa, ready to go.
Let's take advantage of a few things at this point. Go to Settings > Info. If your trusty e200v2 has firmware earlier than 03.01.16, update to this latest version via the thread here. If you have a Fuze or Clip, the firmware is available for each in their respective forums. The v2's earliest firmware, version 03.01.11, had issues with the database refresh hanging. Worse than that, it had no USB mode option in the Settings menu.
Installing the firmware is as simple as unzipping the file, dragging the e200pa.bin file into the root directory, and unplugging. The firmware will install automatically.
As a footnote, the Sansa works best with the memory formatted with 32KB clusters for the file allocation table. After all is said and done, there's an atomic method for this too. On the e200: Settings > Format > Yes.
Posted on Oct 05, 2010
I cannot delete songs from my Sansa e280. I have tried using both USB settings - MSC and MTP. When I try using "My Computer" it says it is deleting the files but they are still on the...
They are probably corrupt files. You will never be able to delete these unless you format your device, which unfortunately will delete all of your songs.
To format: Connect it to you computer, go to my computer, right click on Sansa and click on format. Once the format process has started don't interupt it. You will have to re-load all of your songs back on to the player, but at least your corrupt files will be deleted.
Mar 13, 2011 | SanDisk Sansa E280 MP3 Player
Not enough space for music DB Please free 90 MB
all you have to do is format the drive and that can be done by clicking my computer on a pc then right clicking on the device and format it only bad part is that you have to put all the music back on it. I think it is the same for mac I am not sure
Jan 28, 2011 | SanDisk Sansa E280 MP3 Player
When I turn it on it says I need to free 90 mb of space, but even when on the computer i deleted everything on the machine it still said I needed to free space.
the best thing to do is to format the memory with your computer.it is probably filled up with files you cannot see ordinarily so what you do is this
1.connect it to your computer via usb
2.go to my computer and locate the device
3.right-click on the device and select format
4.select quick format and carry out other simple processes
5.click on format
let me know if it still gives you trouble
Sep 23, 2010 | SanDisk Sansa Fuze MP3 Player
I need to recover deleted memory
Try re-installing the drivers or updating it online :)
Apr 27, 2009 | SanDisk Sansa E280 MP3 Player
Added music, but can't listen
I experienced a similar problem caused by corrupt files saved on the internal memory of my e280.
(I could not delete/remove the files) I had to format the internal drive of the e280
and re-copy the files back on to the unit. Works great now. When formatting the device
use the command from windows. (ie right click on the internal memory icon and select format)
Note: Formatting will remove/delete all the files (eg music,photos..) from the e280 so make sure that
you have backups.
Cheers
Nov 30, 2008 | SanDisk Sansa E280 MP3 Player
Can't do anything without message
It has to make a library file of the contents on the player. It uses that file to display the titles and artists when scrolling through the menus and what not. You'll have to format your player in order to clear it up. This will erase everything and then you can put your songs and stuff back on it. Just make sure that when you do you leave at least 4 megs of space for it to make that library file. Here's a link to the manufacturers instructions on how to format the player.
http://digiblue.com/customer-service/faqs/disney/mixmax/06.html
Mar 06, 2008 | Disney Mix Max Digital Media Player
File format error - Transcend T.sonic 610(1gb)
I had the same problem. I had formatted the player's drive using Windows explorer and the got this error: "File Format error" while trying to play any mp3 file.
I went to the command prompt. Deleted all files:
E:\> del *
Then I copied the MP3 files again in the T.sonic MP3 player. All MP3 files played fine after this.
Jan 29, 2008 | Transcend T.sonic 612 MP3 Player
Sansa e280- files added via WMP10 or Windows explorer, but don't show up on player
No limit on the Genres.
If you keep adding music in different modes, Windows Media Player and Windows Explorer will not show the correct free space.
Theres a good chance you have too music music on your device and the device does not have enough free space to create the Database, or the songs, artists, album, etc.
Try deleting a few songs from the device with Windows Explorer and disconnect the player and let it restart.
If that doesnt work, you can FORMAT the device to remove all of the music and start over.
To format in My Computer>Device name (e280)>Right Click and select FORMAT.
Best of Luck.
Nov 14, 2007 | SanDisk Sansa e270 MP3 Player
Sansa 280 with 8 gigs
The message says it needs 6MB of space for the MUSIC DB ( the database, the artist names, etc).
You need to delete some of the recordings off of your device to free up some space.
You can manually delete the files while connected to your computer from My Computer>Device Name (e280)>MUSIC Folder.
Best of Luck.
Nov 09, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
136 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
