Question about Asrock P4V88 (P4V88 RAID) Motherboard
I get beeps every 2-4 seconds when i launch a game. and some time i get beeps when the pc is just turned on... Eny solution my motherboard is P4V88
Asrock p4v88 9 beeps
http://pcsupport.about.com/od/fixtheproblem/tp/ami-beep-codes.htm
THE MOTHERBOARD HAVE GIVEN YOU THE CODE OF
CHECKSUM ERROR.TRY CLEAR CMOS IF THAT NOT HELP
THE MOTHER IS IMPOSSIBLE TO FIX.
Feb 15, 2014 | Asrock P4V88 (P4V88 RAID) Motherboard
Boot usb P4V88
Hello download the manual here:
http://www.asrock.com/mb/VIA/P4V88/?cat=Download
http://www.asrock.com/mb/VIA/P4V88/?cat=Manual
You have to enter the bios boot settings, and select to boot from the usb drive, as first boot device .
The file on the usb, must be a iso file so the pc can boot from it.
When you have installed your operating system, you can change the selection again (harddrive as first boot device) to prevent damage to the new install.
The iso file on the drive, can also be burned to a disk.
Here is a great program for the job:
http://cdburnerxp.se/en/download
Its free.
But do select the lowest possible burn settings to prevent damage to the operating system.
Best of luck
If you do this you have to select the cd/dvd drive as first boot device, in the bios settings.
May 08, 2013 | Asrock P4V88 (P4V88 RAID) Motherboard
My pc doesnt start,is unable to start.it said is unable to start windows 7
Hello here is the homepage:
Your mainboard is too old to run windows 7.
Continue using windows xp, or buy a new mainboard that supports windows 7.
Good luck
Feb 22, 2013 | Asrock P4V88 (P4V88 RAID) Motherboard
Does asrock p4v88 motherboard support low and high density?
Hi, you can download a user manual here:
http://www.asrock.com/mb/manual.asp?Model=P4V88
Here you also find drivers.
And remember to select your operating system.
Please unzip the file before installation.
Aug 29, 2011 | Asrock P4V88 (P4V88 RAID) Motherboard
Hi, my pc don't start and repeat 3 long beep. Sometime start windows but next crash with blue screen or simply restart with the 3 long beep and black screen. I tried to remove video card and change with...
the blue screen problem causes is:
1- bad files in windows (re-install windows )
2- bad data cable ( replac it )
3- bad sector in hard disk ( repair)
4-bad ram (replace)3 long beep
5- bad power supply (change)
best regards
Apr 04, 2011 | Asrock P4V88 (P4V88 RAID) Motherboard
I want raid driver for asus p4v88 motherboard. ( win xp )
hey here. copy the link below and click for your desired driver.
just choose from the sites were you want to download your driver.
http://www.asrock.com/MB/download.asp?Model=P4V88&o=XP
hope this helps..
Good day.. :)
Jan 29, 2011 | Asrock P4V88 (P4V88 RAID) Motherboard
Dual channel Mode willnot work over 2 gb's of
Hi, please read page 12, section 2.3 in your manual. Dual channel memory must be connected per manual specs.
(Correct colored DIMM slots)
Link to Asrock manual; ftp://174.142.97.10/manual/P4V88.pdf
Main web site provided by Asrock; http://www.asrock.com/mb/overview.asp?Model=p4v88
Once the memory is installed into the correct colored DIMM slots your system should see up to just under 4GB if 4GB is installed while using windows XP. (Refer to Asrock's web site).
Hope you find this helpful and working.
Mike
Aug 01, 2010 | Asrock P4V88 (P4V88 RAID) Motherboard
Asrock Motherboard problems with SATA HDD
It is possible that you are trying to use a SATA II HDD in a system that supports SATA. SATA II devices are not backwards compatible usually,
Dec 20, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
Constant Rebooting and System Error Messages
I suspect you could have a heat sink fan not working remove side of case and when you turn computer on check fans heat sink and video card are working
With computer OFF
remove heat sink fan and check that the heat sink is not clogged up with fluff and dirt.
I regularly clean both fan and heat sink every 2 months also check the fan in power unit and blow it out
Aug 16, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
Asrock P4V88 (P4V88 RAID) Motherboard Logo
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
