Question about Ertl 580 Super M Series II Tractor
What transmission fluid do i use - Ertl 580 Super M Series II Tractor
    Problem Solver:
  • 5 Answers
Use hy-trans from your local case dealer
Posted on Oct 10, 2010
Transmission hard shift
follow this troubleshooting section for oil transmission.
n automatic transmission depends on the transmission fluid for transferring engine power to the wheels, shifting gears, lubricating moving parts and cooling down the transmission. Check the transmission fluid when your car is serviced and change it as recommended. Different cars have different ways of checking the transmission fluid level; some require the engine to be shut off (e.g. Honda), some cars don't have a transmission dipstick at all and the fluid can only be checked in a repair shop. Check your owner's manual for proper procedure. This is how the transmission fluid checked on most cars: transmission-fluid1.jpg After the vehicle was driven for a while to let the transmission fluid warm up, place your vehicle on a level ground. Set the parking brake. Make sure the transmission is in "P" (Park) position. Leave the engine running. Find the automatic transmission dipstick (your owner's manual will tell you where it is located). Pull the dipstick out.
transmission-fluid2.jpg Wipe the dipstick off with a clean lint-free rag. Insert it back fully. Pull it out again and check the fluid level. A transmission fluid expands when warmed up, so if the car has been driven for a while (20-30 minutes), the transmission level should be between "HOT" marks. If the vehicle is cold, the level should be between "COOL" marks. Check the fluid condition: a very dirty fluid with strong burnt smell is a warning sign of transmission problems. Normally the automatic transmission fluid should be clean and transparent, as in these photos.
transmission-fluid3.jpg On most cars the new transmission fluid comes red (photo on the left). Over the time it becomes brownish, as in the photo below.
transmission-fluid5.jpg This is how the synthetic transmission fluid looks after two years of driving - it's still clean and transparent. If your fluid looks very dark or dirty, check your owner's manual, maybe it's time to change it. Some manufacturers require to change the transmission fluid at 30,000 or 50,000 miles others specify that you never have to change it - check what's your car owner's manual says.
transmission-fluid4.jpg If the transmission fluid level is low, you can top it up, but be careful not to overfill it. Overfilling the transmission can cause problems. It's very important to use only specified transmission fluid type - check your owners manual or simply visit your local dealer, they always have proper transmission fluid in stock. Incorrect fluid type can damage your transmission. How to top up the transmission fluid: Using a thin funnel, add a small amount of the fluid through the dipstick pipe. Wait for a few minutes - let the fluid drain down. Recheck the level again. Don't overfill
Sep 30, 2013 | 2001 Hyundai XG300
Transmission shifts hard
see the chart troubleshooting and proceed according. God bless you
How to check automatic transmission fluid. An automatic transmission depends on the transmission fluid for transferring engine power to the wheels, shifting gears, lubricating moving parts and cooling down the transmission. Check the transmission fluid when your car is serviced and change it as recommended. Different cars have different ways of checking the transmission fluid level; some require the engine to be shut off (e.g. Honda), some cars don't have a transmission dipstick at all and the fluid can only be checked in a repair shop. Check your owner's manual for proper procedure. This is how the transmission fluid checked on most cars:
Sep 30, 2013 | Hyundai XG300 Cars & Trucks
Where do you add transmission fluid for a 2007 chevy hhr
Chevrolet recommends that the transmission fluid be changed every 50,000 miles, but Chevy intended the transmission to be serviced only by authorized repair shops. For this reason, the HHR does not feature a transmission fluid dipstick. However, the HHR's transmission fluid can still be checked without exotic tools.
It is important to check the fluid level only after the fluid has circulated throughout the transmission by shifting through the gears. Failing to allow the fluid to circulate will result in a false fluid level reading. Turn the engine on and shift through each of the transmission's gears with the brake pedal depressed and the parking brake applied. The car should be allowed to idle in each gear position for approximately five seconds. Turn the engine off, then climb underneath the passenger's side of the vehicle. A small plug is located on the passenger's side of the transmission. Remove this plug with a wrench. Turn the engine on and observe whether any fluid drips out of the transmission plug's opening. If fluid does begin to drip from the plug opening, the transmission does not require additional fluid. Turn the engine off and install the transmission plug.
If fluid did not begin to drip out of the transmission's plug, transmission fluid must be added. Turn the engine off, then remove the black breather cap from the top of the transmission. The circular breather cap twists into the transmission. Twist the cap in a counterclockwise direction until it detaches from the transmission. Because of the lack of clearance between the breather cap's opening and the bottom of the vehicle, transmission fluid cannot be poured into the breather cap opening. Attach a fluid pump to a quart-sized container of new transmission fluid. Insert the pump's hose into the transmission through the breather cap's opening. Turn the engine on, then actuate the pump until fluid just begins to drip out of the plug's opening on the side of the transmission. Screw the breather cap onto the top of the transmission, then install the plug with a wrench.
Sep 27, 2013 | 2006 Chevrolet HHR
2003 mitsubishi outlander rough idle won't stay on and wont run with load
p0134 - Bad O2 Sensor or faulty sensor wiring
p0132 - Bad O2 sensor (Bank 1 Sensor 1)
p0401 - Exhaust Gas Recirculation insufficient
p0113 - Defective intake air temperature sensor/ clogged air filter/ faulty Mass Air Flow (MAF) sensor.
p0101 - Vacuum leak/ defective MAF sensor/ damaged intake manifold gasket
p0107 - Faulty Barometric Pressure sensor or its wiring system
p0758 - Low transmission fluid/ Dirty transmission fluid/ Shift Solenoid B wiring problem or its valve
p0753 - Low transmission fluid/ Dirty transmission fluid/ Shift Solenoid A wiring problem or its valve
p0736 - Transmission problem/ Low transmission fluid/ Dirty transmission fluid/ Shift Solenoid wiring problem or its valve/ Transmission hydraulic control circuit
p0735 - Transmission problem/ Low transmission fluid/ Dirty transmission fluid/ Shift Solenoid wiring problem or its valve/ Transmission hydraulic control circuit
p0732 - Transmission problem/ Low transmission fluid/ Dirty transmission fluid/ Shift Solenoid wiring problem or its valve/ Transmission hydraulic control circuit
p0720 - Damaged speed sensor/ its harness/ connector
Jun 12, 2013 | 2003 Mitsubishi Outlander
How do i drain transmission fluid and replace trans-filter 1996 chevy suburban 4x4 454
Finding where to put transmission fluid can be a bit of a challenge on some cars. In fact there are some transmissions that you can't even add fluid to.But that's not the case on your vehicle.
First confirm the level of fluid before filling it.==========For exact transmission fluid replacing/filling procedure.Go through the list of help links below:-----its having complete step by step procedure.Click the link :----
HOW TO CHECK AUTOMATIC TRANSMISSION FLUID LEVEL
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
HOW TO CHANGE AUTOMATIC TRANSMISSION FLUID AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
HOW TO REPLACE A TRANSMISSION MOUNT
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-transmission-mount.html
How do you change transmission fluid on Pontiac?
http://schematicsdiagram.blogspot.in/2012/03/how-do-you-change-transmission-fluid-on.html
Filling Transmission fluid on 2001 Volvo c70?
http://schematicsdiagram.blogspot.in/2012/02/filling-transmission-fluid-on-2001.html
2002 Isuzu trooper Transmission fluid fill up?
http://schematicsdiagram.blogspot.in/2012/02/2002-izusu-trooper-transmission-fluid.html
AUDI V8 TRANSMISSION FLUID
http://whoisbyme.blogspot.in/2012/07/audi-v8-transmission-fluid.html
Where to fill Transmission Fluid on 2001 ford focus
http://technoanswers.blogspot.com/2012/10/where-to-fill-transmission-fluid-on.html
Transmission fluid gets into radiator?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fluid-gets-into-radiator.html
How to check Transmission fluid on 1996 Chevrolet Camaro?
http://schematicsdiagram.blogspot.com/2011/12/how-to-check-transmission-fluid-on-1996.html
Transmission fault light on car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
Filled T-IV fluid instead of WS transmission fluid?
http://repairhelpcenter.blogspot.com/2012/01/filled-t-iv-fluid-instead-of-ws.html
How to Add transmission fluid on 2002 Isuzu AXIOM?
http://technoanswers.blogspot.in/2012/02/how-to-add-transmission-fluid-on-2002.html
2003 Toyota Prado Diesel Engine: Transmission Fluid Refill?
http://whatisbyme.blogspot.in/2012/05/2003-toyota-prado-diesel-engine.html
-------------These details will help.Thanks.
Nov 27, 2012 | 1996 Chevrolet Suburban
I want to remove my trasmission
Yes the engine has to be out,its not a easy task to replace transmission.You will required professional tools and wrench/ratchets.
Also its very time consuming.
For your help,i suggest you few help links with accurate solutions,showing how exactly to replace transmission and other transmission components.
Click the link below:-----
HOW TO REPLACE A MANUAL TRANSMISSION
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-manual-transmission.html
HOW TO REPLACE TRANSMISSION COOLER LINES
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-transmission-cooler.html
DSG automatic transmission problem
http://whatisbyme.blogspot.in/2012/07/dsg-automatic-transmission-problem.html
Transmission problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-problem.html
2004 Chrysler 300m: Transmission Relearn Procedure?
http://repairhelpcenter.blogspot.in/2012/06/2004-chrysler-300m-transmission-relearn.html
Coolant enters in transmission on Toyota Land cruiser?
http://schematicsdiagram.blogspot.com/2012/01/coolant-enters-in-transmission-on.html
Engine stumbles and shuts off in forward gear on Toyota Land Cruiser?
http://schematicsdiagram.blogspot.com/2012/01/engine-stumbles-and-shuts-off-in.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
Manual Transmission Clutch System Failures?
http://repairhelpcenter.blogspot.com/2011/11/manual-transmission-clutch-system.html
Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Dodge Anti slip System is not operating?
http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
Manual transmission very hard to shift from one gear to another?
http://repairhelpcenter.blogspot.com/2012/01/manual-transmission-very-hard-to-shift.html
Bell housing and transmission will not come apart on 1996 Toyota Tacoma?
http://repairhelpcenter.blogspot.com/2012/01/bell-housing-and-transmission-will-not.html
Chrysler Cirrus Auto Transmission Swap?
http://whoisbyme.blogspot.in/2012/06/chrysler-cirrus-auto-transmission-swap.html
Thanks.
Nov 26, 2012 | Cars & Trucks
Add fluid transmission
TRANSMISSION FLUID
Checking automatic transmission fluid
The 5R55N transmission does not have a transmission fluid dipstick.
Refer to your scheduled maintenance guide for scheduled intervals for
fluid checks and changes. Your transmission does not consume fluid.
However, the fluid level should be checked if the transmission is not
working properly, i.e., if the transmission slips or shifts slowly or if you
notice some sign of fluid leakage.
Transmission fluid should be checked and, if required, fluid
should be added by a qualified technician.
Aug 23, 2012 | 2001 Lincoln LS V8
What is the recommended millage for a transmission flush
Transmission fluid should be changed every 30,000 miles, or more frequently if the vehicle is used for towing or carrying heavy loads.
When replacing the transmission fluid, first the mechanic drives the vehicle to get the fluid warm and then removes the drain plug at the bottom of the transmission (if applicable), or removes the transmission pan allowing the fluid to drain.
The transmission is then filled with fresh fluid, and the engine is started. With the engine running and the transmission in "Park," the mechanic checks the level of the transmission fluid on the dipstick. Then the vehicle is driven once more, and the fluid level rechecked; if needed, more fluid is added.
Using the wrong automatic transmission fluid may invalidate the manufacturer's warranty and affect the shift characteristics of the transmission. Consult the owner's manual for information on the kind of fluid to use.
Many automatic transmissions have a filter that can be replaced when changing the transmission fluid. Changing this filter may allow a closer examination of the fluid for debris, which may be a sign that the transmission is about to fail.
Hope this helps.
Feb 09, 2011 | 2005 Hyundai Sonata
How do you know when you need to change your transmission fluid in my 2002 ford explorer
This is in the owners manual pages 269 and 270. TRANSMISSION FLUID
Checking automatic transmission fluid (if equipped)
The automatic transmission does not have a transmission fluid dipstick.
Refer to your scheduled maintenance guide for scheduled intervals for fluid checks and changes. Your transmission does not consume fluid. However, the fluid level should be checked if the transmission is not working properly, i.e., if the transmission slips or shifts slowly or if you notice some sign of fluid leakage.
Do not use supplemental transmission fluid additives, treatments or cleaning agents. The use of these materials may affect transmission operation and result in damage to internal transmission components. Checking and adding manual transmission fluid (if equipped)
1. Make sure the vehicle is on a level surface or level hoist.
2. Clean the filler plug or dirt and debris.
3. Remove the filler plug and inspect the fluid level.
4. Fluid level should be at bottom of the opening.
5. Add enough fluid through the filler opening so that the fluid level is at the bottom of the opening.
6. Install and tighten the fill plug securely.
Use only fluid that meets Ford specifications. Refer to the Lubricant Specifications in this chapter.
Nov 26, 2010 | 2002 Ford Explorer
No drive on a 1999 olds alero
CHECK TRANSMISSION FLUID SOUND LIKE VECHICLE SLIPPING DUE TO LACK OF FLUID. CHECK TRANSMISSION FLUID ON DIP STICK. WHILE ENGINE COLD FLUID LEVEL ON DIP STICK SHOULD FULL MARK.CRANK ENGINE LET VECHICLE IDLE TO WARM.THEN HOLD FOOT ON BRAKE SHIFT THROUGH ALL GEARS FEW TIMES CHECK TRANSMISSION FLUID LEVEL IF LOW ADD FLUID UNTIL YOU GET TO FULL MARK.IF YOU HAVE THE TRANSMISSION WITH NO DIP STICK.YOU NEED TO CHANGE TRANSMISSION FLUID + FILTER. YOU NEED 7 QUARTS OF TRANSMISSION FLUID.BUY DEALERSHIP TRANSMISSION PAN GASKET ITS THICKER MADE DIFFERENT WONT LEAK FLUID. THE TRANSMISSION GASKETS AT AUTO PARTS STORES TOO THIN LEAK FLUID BAD.
Nov 09, 2010 | 1999 Oldsmobile Alero
Ertl 580 Super M Series II Tractor Logo
796 people viewed this question
Top Ertl Toys Experts
Colin Stickland
Colin Stickland
Are you an Ertl Toy Expert? Answer questions, earn points and help others
