Question about Pioneer PureVision Pro-800HD 43 in. Plasma HDTV
My pioneer plasma display PDP-433PU model, is stuck on standby and the television wont turn on, when i press power button it turns green for a second and then blinks red a few times what do i do?
  • 84 Answers
SOURCE: monitor on switch goes onto
Thats a Factory shut down .... caused by a fault usually the power supply
Sorry it's a factory repair issue
make sure all the connections are tight
and try one more time .... sorry
LB
Posted on Sep 19, 2008
SOURCE: I have a Pioneer PDP-R05G
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
http://www.pioneer.owner-manuals.com/PDP4360HD-service-manual-PIONEER.html
service manual link above,
as an aside here, sometimes things in storage can quickly degrade especially big low value capacitors, these increase in internal resistance, and all sorts of problems ensue, this is why, say, military things are cycled at least weekly when in "Moth balls" to prevent exactly this.
Posted on Mar 12, 2011
  • 6 Answers
SOURCE: pioneer pdp 435PE plasma panel fault
You have to count how many times the red light flashes, this will determine the fault code.Then we may have a better guess at how much it may cost. Modules typycally cost 200-400 dollars.
Posted on May 09, 2008
SOURCE: I have a Pioneer pdp-433 plasma with a media
Alas, the powerblock has gone.
Common problem on this model.
Only solution is replacement powerblock.
Pioneer used to repair this for nothing even out of warranty (they did for me), but they may not be so willing now, as your tele must be at least 6 years old. Unfortunately, it will be cheaper to buy a new TV than to pay for a contractor to fix it.
Brian
Posted on Jul 27, 2009
tvservice306
  • 458 Answers
SOURCE: my pioneer pdp-434hde will turn on for about 3
check y board and power supply
Posted on Oct 25, 2009
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
Tv won't come on...light in corner just blinks red
OK Its your power supply and it can be fixd for free due to a recall.
PLEASE READ BELOW what I found out.
Here's the whole notice:
Important: Free Power Supply Replacement for Certain Pioneer Plasmas
Pioneer is continuing to offer a free, in-home power supply replacement for certain of its second and third generation plasma models listed below for consumers who experience a problem with the original power supply. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded in your home at no charge.
Consumer Plasma Models (12 listed):
PDP-505HD
PDP-503PU
PDP-5030HD
PDP-5031HD
PDP-433PU
PDP-4300
PDP-4310
PDP-4330HD
PRO-800HD
PRO-800HDI
PRO-1000HD
PRO-1000HDI
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
We apologize for any inconvenience, and we thank you for your cooperation.
Apr 02, 2010 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Green spots/pixels at top of TV screen
I have a 50" Pioneer PDP-503MXE with the same problem - the fans don't run. It appears to be a problem with the temperature sensor that controls the fan speed. However, the fans can manually be switched to MAX.
To do this, put the display in standby. Press the 'Menu' button and within 3 seconds press the 'Power/Standby' button. The 'Integration Menu' will appear. Select the 'Option' tab on the right. Scroll down (next page) to the 'Fan Control' option. It will most likely be set to 'Auto'. Press 'Set' to change it to 'Max'. Within a few seconds the fans will run.
At Max the fans are a bit noisey but it will cool the unit down.
May 05, 2009 | Pioneer PureVision PDP-503CMX 50 in....
I cant get the fans to turn on!!!!!!!!!!!
Call up the 'Integration Menu" - the fans can be switched between 'auto' and 'full speed'.
To do this switch the display into standby. If the standby light flashes 4 times it is indicating a fault in the Thermal Sensor Assembly which will explain why your fans aren't working. With the display in standby press the menu button and within 3 seconds press the power button. The display will turn on with the integration menu. Select the option tab and scroll down until you see 'fan control' - press 'set' to toggle between 'auto' and 'max'. When you select 'max' the fans will run at full speed within a few seconds. The fans are a bit noisey at full speed so you may want to look into replacing the sensor eventually.
Feb 19, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Loud pop and tv went off...
Here is a solution from the Pioneer web site:
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Important: Updated Information Regarding Free Power Supply Replacement for Certain Pioneer Plasmas Pioneer is continuing to offer a free, in-home/office power supply replacement for certain of its second and third generation plasma models listed below for customers who experience a problem with the original power supply. If a model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded at your residence or office at no charge.
Plasma Models (15 listed):
  • PDP-505HD
  • PDP-503PU
  • PDP-5030HD
  • PDP-5031HD
  • PDP-433PU
  • PDP-4300
  • PDP-4310
  • PDP-4330HD
  • PRO-800HD
  • PRO-800HDI
  • PRO-1000HD
  • PRO-1000HDI
  • PDP-433CMX
  • PDP-502MX
  • PDP-503CMX
Anyone with questions can call Pioneer's toll free hotline at 800-421-1404.
We apologize for any inconvenience.
Aug 09, 2008 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer pdp 502mx goes to standby no picture after power on
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
May 23, 2008 | Pioneer PureVision PDP-502 50 in. Plasma...
Pioneer pro800hd plasma just made a loud pop and then went to black the power button(red led) is flashing. power supply??, flyback xformer??? any ideas. worth fixing??
The affected models of consumer plasmas are listed below. Anyone who owns or uses one of these models may contact Pioneer through its toll free hotline at 800-421-1404 to arrange for the free, in-home upgrade. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken. If consumers are not sure if their plasma is affected, they should call the toll free hotline for confirmation.
Consumer Plasma Models (13 listed): PDP-505HD PDP-4330HD PDP-503PU PDP-4300 PDP-5030HD PDP-4304 PDP-5031HD PDP-4310 PRO-1000HD PRO-800HD PRO-1000HDI PRO-800HDI PDP-433PU
Dec 30, 2007 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer PureVision Pro-800HD 43 in. Plasma HDTV Logo
671 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
