Question about Sony Vaio S150P (VGNS150P) PC Notebook
LCD not displaying. it seems the computer is starting up properly.
Dell e178wfpc monitor shows power on light but no display.
You should check if the vga cable is tightly connected from monitor to cpu. If the cable is connected properly,then the problem must be with your monitor. Check with any other monitor. If you hear a beep beep sound, when you start the computer then your RAM has been damaged or not properly connected.
Apr 11, 2014 | Dell E178WFP Black 17 inch LCD Monitor
Harmony 880 display is backlit but menu won't display. It seems to still work (pressing the button I know to be "Watch TV" turns everything on ok). Is the LCD broken?
Sometimes the LCD screen fails on the 880/890 series. But, there are a few tricks you can try that have brought the LCD back to life.
Some LCD problems have been solved by updating the remote's firmware while the remote has been placed in 'safe mode'. To do this, launch the Logitech Remote software on your computer and click on "Downloads" (on the top menu bar). Then, take the battery out of your remote and at the same time you connect the USB cable to your remote (it should be already connected on the computer end) press and hold down the Off button at the top of the remote. This will put the remote in "safe mode". Continue to hold down the Off button until you see the message "safe mode requested" on the remote's screen and the screen starts blinking. Now, since your screen is not behaving properly, you may or may not see this message, but after about 5 seconds you can release the Off button. Now, go back to your computer and click on "Firmware". If the software is able to communicate with the remote, an update to the remote's firmware should be executed. This has solved many a 'blue screen of death' problem. Good luck!
Feb 27, 2010 | Logitech Harmony 880 LCD Remote Control
New hp computer not communicating with Insignia LCD TV monitor
before starting keep press f8. then choose safe mode then if you are in ur desktop try to ressetting your display 800x600 then finally done......
Feb 13, 2010 | Computers & Internet
Cant get size from display settings for external 19" Samsung Sync Master 931B cant see start button everything to large
See if you can pull up the menu on your monitor. If you can reset it to factory defaults.
If you still can't see the screen properly then you need to on your computer. Go into the device manager and make sure its seeing your video card properly. Look underneath display adapters and be sure its seeing something other then standard display vga.
If not then your display adapters are missing so once you install those, the computer will recognize your monitor.
Dec 18, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Displays 'Input Not Supported' at start up om black screen
Seems that you have set the resolution on your graphics card to a setting higher than the maximum resolution supported by your monitor.
Try to boot into Safe Mode & lower the resolution of your graphics card. If not possible, go to Device Manager & remove the graphics card from it, then reboot your computer. This will reset the resolution.
You can then re-install your graphics card drivers & get it to work properly.
Sep 20, 2009 | AOC LM 720 17" Flat Panel LCD Monitor
My monitor isn't showing a picture properly. It is on and working because I can see the picture very dimly and the green power light is on. The frame around the screen was recently damaged - the screen...
I'm assuming you already tried the brightness adjustment.
From your description, the LCD screen itself seems to be intact. The problem seems to be backlighting which could very well have been damaged by a perimeter impact.
If it's still under warranty, contact the manufacturer. Tell them it just stopped working. Don't elaborate on the details.
If not, find an accredited computer repair shop. It's not a big deal to fix as long as the fix is performed by a trained professional.
Sorry, I wish there was a magic button to push.
Best regards,
Mike
Aug 17, 2009 | ViewSonic VA721 17" LCD Monitor
Top Portion of Screen not displaying/updating images correctly
The problem could be with the controller board in the back of the monitor, but more likely the LCD itself though. Could be the flat ribbon cable connecting the LCD to the controller, rather unlikely but I have seen them lose contact.
Jan 14, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor stops display
Hi...there,
It's seems your LCD Monitor backlight inverter it burnt out. Need a new inverter. Have a nice day!
Sep 06, 2008 | Computers & Internet
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Kodak v550 easyschare camera
As long as the pictures look fine it is something going on with the lcd display.
If it was taking pictures the same, it could be a special effect that is turned on or the CCD is bad. It sounds like the LCD display is bad. Some cameras can be repaired at a reasonable price with a new LCD display.
Have you replaced the batteries in the camera? That might take care of the problem.
Jun 15, 2008 | Kodak EasyShare V1003 Digital Camera
Sony Vaio S150P (VGNS150P) PC Notebook Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
