Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
It is a hoshizaki model # DKM-500BAH and in the servicing postition and the 2nd swich on drain it will not actually drain. it has not been cleaned in a long time. how do i unclog it or go about fixing it? it dose actually sound like it is trying but no water comes out.
  • Hoshizaki Master
  • 1,078 Answers
Http://www.hoshizakiamerica.com/manuals/DKM-500BAH_serv.pdf
go to this web site and check out your manual. The 2nd switch is for the finish timer on the defrost cycle. Check out the service manual and then let me know if I can help you any further.
Posted on Dec 20, 2010
I worked on a hoshizaki km-500mae when i turn it on the first cycle it makes good ice but after the first cycle it makes little pieces. why?
time the cycle. if it is only running about 5 minutes and going into harvest, look for sump loosing water. Look at where the unit drains (like a floor drain) while the unit is running to see how much, if any water is draining. does not take much to make an early harvest. also, sump may not be filling up completely but with just enough water to satisfy the float.
Feb 16, 2015 | Hoshizaki Freezer Commercial Ice Machines...
Wont drain after cleaning
remove the drain tube in the sump. be careful not to loose the o ring at the bottom.
Jan 02, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine continuously drains a large amount of water into sewer drain
sounds like a bad water valve. I say this assuming that the unit is not a water cooled unit. any further info would be helpful.
Sep 05, 2012 | Hoshizaki Commercial Freezer KM-500MAH
Hi i have km-320-mwh hoshizaki ice machine, this machine is discharging water in drain continuesly except when it is dumping ice is this normal ...too much water is being lost please help many thanks...
By looking at the model number it is a water cooled unit. It will dump water down the drain continuosly as that it how it cools the compressor. If it was a MAH it would be air cooled and no continuos dump of water.
Aug 09, 2011 | Hoshizaki Freezer Commercial Ice Machines...
KM-500-MAE Hoshizaki Problem huge cubes, alarm code three beeps
Might need to clean float switch, or water inlet valve bypassing water. Deep clean Hoshizaki.
Sep 30, 2010 | Hoshizaki Commercial Freezer KM-500MAH
We need help cleaning our Hoshizaki ice machine. Our boss does not know how to clean it and he told us to figure it out. That's where you come in.
k well that will depend im not really an expert on it but i did clean 2 freezers so im thinking that theyd be pretty much the same...hope i can help. first of take all the ice out of the machine. since it looks nice and new im thinking that the put thought of cleaning into making it.so i think theres a drain in there. not sure how clean you want it just take a scrub pad and soap(if you find the drain) the rinse it out. not sure y you would want to clean it though.
Jan 28, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine with constant beeping every 2 seconds
turn it off and on and check the drain line and see if its draining water. some times the check valve needs taken apart and cleaned. the problems corespond to water related problems. usually because its taking too long to freeze. good luck
Dec 27, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki ice machine model KM-250BAF SERVICE MANUAL
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
Jul 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Harvest cycle on ice machines
My ice machine Hoshizaki km-500 mah is cycling to fast. Causing poor production of ice it's real small and it doesn't produce enough ice aswell. Wha seems to be the problem.
Jun 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
115 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
