Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
No picture my tv tuns on and off but no picture, sound is good up and down but still no picture. Is the bulb gone?
  • bree1031 Jun 12, 2008
    tv turns on and off has sound but no picture. channels change the screen is black
  • Philips Master
  • 8,617 Answers
Most likely the vertical output IC needs to resolderd. When the picture goes out if you press menu can you still see the on screen displays?
Posted on May 24, 2008
The picture went blank on my tv but I can still hear the sound. How can I get the picture to come back? All plug ins are tight. Thanks
When was the last time you changed the bulb for the projector? has this gone bad? If the bulb needs changed, consult your manual for instructions and if the bulb is good let us know.
Mar 24, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
Fluttering sound when trying to tun set on, never comes on and shuts down. Sounds almost like a motorboat sound, but not quite. Recent bulb change. Made sure all vents and air filter were cleaned. Took the...
Maybe the fan is going out. Since you said bulb change I assume your tv is a projection tv. If so I think those tv's have fans to help keep it cool. If the fan is not working properly or failing, the tv may be shutting itself off so further damage does not occur. Check the fan. What is the model number of your tv?
Mar 08, 2010 | Hitachi 43FDX01B TV
My tl3222 norcent whent black.Good sound.any ideas? Tv will display channel number and shows audio type (mano) when channel is tunned.It takes a while for the standby light to go green.you have to turn the...
This sounds like a problem with the power supply. Usually capacitors on the power supply board tend to dome, bulge or dry up. The damaged ones can be seen on the power supply circuit board when the back is removed. The dry ones have to be removed and tested. The caps can be replaced at a repair shop for around $200, but if the power supply board has to be replaced it can cost a little more. It all depends on the shops repair fees. But you could also have a bad main/control board which is where all the input jacks and tuner are mounted. These boards are more expensive, but not sure of the actual cost.
Sep 07, 2009 | Norcent Technologies LT-3222 32 in. LCD...
My hitachi turns on and has a red/green glow, but no picture on it. It sounds like it is running, but there is no picture or sound. It recently had a power surge go through it. What could have gone wrong...
have you checked the bulb in the tv? sounds like the bulb is no good they are around 40-60 bucks...make sure tv is off and unplugged before checking and dont touch it just look to see if its blown
Jun 04, 2009 | Hitachi 60V500 60" Rear Projection...
Toshiba 50H81 Sound but no picture
if you heard a pop that would be a capacitor unable to take the voltage, hopefully no other damage, you will need to identify the capacitors that have gone and replace the parts with the same number ie 40v 300uf 105c remember don't touch the 400v or 200v capacitors as they will still have power in them, discharge them by placing a metal object over the + and the - on the capacitor and then the board will be safe.it could also be the bulb has gone. you would need to check this as if the bulb has gone the tv will shut down. and flash but usually there is an led that flashes to tell you bulb failed.
May 28, 2017 | Toshiba 50H81 50" Rear Projection...
Philips magnavox big screen tv that has sound but no picture
the picture driver has gone bad, look on ebay for one,make sure it looks just like the one you have, or it could be the verisitor has gone bad it's a kool fix
Nov 21, 2017 | Philips Televison & Video
TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
Feb 25, 2009 | LG 32LG30 32 in. LCD HDTV
When i turn on tv it no picture just sound
Hello, This is a DLP projection tv so most likely the bulb has gone out. Usually there is a place in the rear of the tv to open & replace the bulb. If you try a new bulp & it dosen't work then it could be that the power supply that runs the lamp has gone bad. You may want to see if you can get a bulb from a place that will let you return it just encase the problem is the power supply. Light bulbs are usually between $200 - $400 & you can usually find the part number on the lamp, On the tv, or in the manual. I have had good luck finding deals on http://www.topbulb.com & on ebay.
Hope this helps,
Bryan.
Dec 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sound
WOW never heard this one . You might check the volume down button on the tv to see if it is depressed in . What is the model # and do you clean the picture tube with windex ? Maybe some of it has seeped down onto the control board and has gummed up the volume down button. Good luck
Mar 03, 2008 | Sony KV-27V42 27" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
