Question about OfficeMax 0M96431 Shredder
How do I unjam my shredder? - OfficeMax 0M96431 Shredder
    Sergeant:
  • 270 Answers
Unjamming the shredder is sometimes complicated by what was put thru in the first place.
Run the shredder in reverse to pull out the offending material.
If there remains parts of the debris still obstructing the blades, run it forwards then backwards several times (like rocking a car out of mud)
If you need to remove the debris manually, UNPLUG the shredder first even though it has a safety catch when it sits on its bin.
Posted on Sep 27, 2010
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
How do I unjam it?
Sometimes the only effective way to unjam a shredder is to turn it upside down (with power disconnected) and pick out the jamming material bit by bit. It is a tedious, messy job.
Aug 12, 2015 | Techko SH1524CP Shredder
My Executive Machines EPS 1200X shredder works in reverse, but does not shred.
there should be a forward/ reverse switch that is used to unjam paper being shredded. check that
if it is automatic then check for paper stuck in the shredder causing the reverse action.
May 12, 2015 | Shredder Office Equipment & Supplies
HOW DO I UNJAM SB 99C SHEDDER
Try spraying some WD40 into the cutting blades then turn it on to forward it may unjam itself.
Aug 25, 2014 | Fellowes SB-99Ci Shredder
How to unjam shredder spl-mc1809
See this... http://www.wikihow.com/Unjam-a-Paper-Shredder
Jul 08, 2014 | Office Equipment & Supplies
My royal paper shredder is jammed. How do I unjam the shredder?
Normally try to run it in reverse while pulling the paper back out to assist the motor. If it won't even run in reverse then you will have to take it apart to manually clear the jam.
Sep 10, 2010 | Royal 15MX Shredder
My shredder is jamed.
Take the shredder off of its bin, turn upside down, make sure it is unplugged, and pull any pieces of shredded paper out of the shredder teeth, If the reverse mode did not unjam it then you might try opening it, by the inside of the shredder, and unjamming it that way, may I add that there is a sticker covering one of the screw holes that will say "if removed warranty is not good anymore".
Aug 11, 2010 | Aurora Electronics AS662C Shredder
Shredder jammed
For any jammed shredder..try the following.. pull backwards on the paper while you switch the machine into reverse. Try not to tear the paper as if there is nothing to hold onto then you can't help the motor.
If this dosn't work then you will have to take the top cover off(after unplugging of course.) and the try to force the paper backwards out of the machine by turnings the cutting blades or gears in the reverse direction.
Jun 04, 2010 | Royal 150MX Cross-Cut Shredder
Jammed shredder
First UNPLUG THE MACHINE.
Unscrew four (4) screws, two in front underneath top cover and two in back of top cover. BE careful not to disconnect any wires.
Rotate motor gear or belt in reverse to remove jam. Do not put oil on paper because it expands the paper thickness and only makes it worse.
Sep 02, 2008 | Fellowes Powershred 480 Shredder
OfficeMax 0M96431 Shredder Logo
289 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Steve
 Bob Buchholz
Bob Buchholz
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
