Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Our freezer is working, but the top is not cooling. Very warm behind.
  • Kenmore Master
  • 1,711 Answers
This is for a kenmore top mount Refrigerator/Freezer Model Number 25363712302. Refrigerator was not cooling properly - was warm. Freezer was working, but after a couple of days, freezer also started to...
Since you say that is isn't cooling properly, I would first start off by cleaning the condenser grill that is located under the cabinet. While this won't correct your problem entirely, it will help!
Most likely you have a defrost system malfuntion. The defrost system consists of the defrost heater (p/n: 5303918208) which is the long tube like thing that sits directly below your evaporator behind the panel in the back of the freezer (inside the freezer). It also consists of the defrost thermostat (p/n: 5303918202), which is located next to the evaporator. Both the defrost heater and defrost thermostat can be checked with an ohm meter - a non-open/infinity reading is good. If both of those check out and are good then it has to be the defrost timer (p/n: 215846602) which is located behind the plastic shield (with the light bulb).
Suggest you defrost the unit (making sure no ice or frost is behind the freezer panel then plug the refrigerator back in. If everything cools down then my diagnosis is correct and one of the components of the defrost system is bad.
Oct 03, 2011 | Kenmore Top Freezer Refrigerator
Frigidaire White 16.5 cu. ft. Top Freezer Refrigerator (FRT17HB3)- The freezer works, the refridge portion is warm, it started last week ans seemed intermitten, we turned the cooling higher and it was fine...
All of your cooling coils on this model are located in the freezer. If you are cold enough in the freezer your problem is air flow to the fresh food section.
- There is fan behind the back wall of the freezer, be sure that is running.
- Look for frost build up on the back wall of the freezer, if present we have a defrost problem
- look for the duct or channels between the floor and freezer and top of the refrigerator they could be blocked with ice, if so we have a drain problem.
Let me know what you find and I will help you from there.
Apr 18, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is icing up behind back panel, so fridge not cooling
There are two components that are supposed to take care of this problem. One is a heater that defrosts the system (not really frost free) and the other is a timer that turns the heater on and off at predetermined intervals.
If the heater or timer fails, the system will frost up and block the path of cool air not allowing the freezer to cool down.
Jul 20, 2009 | GALAXY Microsystems 63702 Top Freezer...
Fridge is warm and freezer is cooler than normal
Possible bad defrost timer. Locate timer underneath the fridge and manually turn the knob. Element should come on and start defrosting. If defrosting starts then the timer is bad. Check also the element and thermostat.
Jul 05, 2009 | GE Profile 21.6 cu. ft. Top Freezer...
Hotpoint frig,top freezer motor runs contiunally, thermostat set in middle of temp. control. side of frig stays cool all time.[does not get warm as it used to] is defrost thermostat bad or timer?
niether. is there frost on back wall of freezer? if no look behind back wall and see if there is frost on all the coils when running. if less than 80% is frosty...freon. or is there frost covering back panel..if so then defrost problem would be correct. but side would be warm so I think not.
Jun 12, 2009 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Bottom is too warm
Make sure your fan is working ,its in the freezer behind panel .If not the fan your passage area is probably covered with ice and the air cant get in freezer
Jun 14, 2008 | Frigidaire FRT15G5CS Top Freezer...
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
548 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
