Question about Nuvico NVJV-4000N Video Recorder
Trouble connecting to remote cameras (I have a static IP http://192.168.1.251:7000/), but am having trouble connecting. I use the program CMS LITE to connect.
I have a cctv camera installed in my office i want to access it i don't know how to access it. someone says that there is a website 198.168.1.100 login
Could be anything as IP address, like 192.168.xxx.xxx , so you need to talk to the IT guys. If this is not an option try to install this freeware "Advanced IP scanner" from http://www.snapfiles.com/freeware/network/fwscanner.html and run a scan. Hopefully you will see something like "CCTV" or "camera" next to an IP address. Then you can open a browser and type "http:// ipaddress you found" (example http://192.168.1.100).
Mar 16, 2011 | Computers & Internet
I have just installed my Uniden UDW20553 Video Surveillance System. I was under the impression that I would have remote access to view my cameras from anywhere in the world on my laptop. Have looked high...
The only solution I have found is using Remote Desktop Connection and running the Uniden application. On my Iphone I found that using Pocket Cloud Remote Desktop (RDP Itunes download application) works best. You must also download a free application named "Pocket Cloud Companion" on the PC your Uniden software is running. Pocket Cloud Companion must be running for connection to made through 3G, Edge or Wifi networks. Also, you have to configure your remote connections by using your PC's IP address rather then the name of your pc, particularly if making connection on 3G network.
Feb 12, 2011 | Uniden Wireless Security Surveillance...
Hi, I'm having trouble with changing the IP address on the SecCam
you can try this http://www.whoisxy.com/ ,here i got the details about the dns query ,ip to domain ,domain to ip etc........you can get more about the ipadress......
Jul 13, 2010 | D-Link DCS-5300 Network Camera
Unable to ping static IP from remote desktop when
Does PING works on the same location where Camera's are located?
Usually, RDP connections uses the same PC on LAN and that should work fine. Please check Camera's configuration; make sure they have valid IP address, SM, Default gateway and DNS servers. Make sure that PC with enabled RDP can PING computers on the LAN either by IP address or Computer name. Make sure they're part of the same WORK GROUP.
Hope this helps! Please provide additional information so I can further assist you.
Mar 28, 2010 | D-Link DI 514 Wireless Router (DI-514)
How to connect to remote camera
To create new Camera Window
  • Click New Camera from the File menu.
  • Camera Setting dialog box appears.
Camera Setting dialog box helps you control selected video source. To open the Camera Settings dialog box, select Camera Settings from the File menu.
Set a preview rate in the Preview Frame Rate box. It indicates the number of frames per second in the camera window. The default value is 10 frames per second. This value doesn't interfere with broadcast or record frame rate.
Remote Cameras
Remote camera is another Active WebCam program with enabled Remote Access launched on remote computer. Both programs use UDP protocol to communicate each other. If connection with Remote camera goes through firewall, make sure that the IP address of your computer, local and remote ports are opened on the firewall, and the UDP protocol is enabled.
To connect to Remote Camera
In the Device tab click to select Remote Camera.
Specify the computer address in the IP address box. Don't place the protocol prefix (like http://) in the address, just four digits of IP address delimited by dots, like: 192.168.1.101. You can find out the remote computer IP address by clicking Get Computer IP Address from the Tools menu on the remote computer.
Type port, which is opened on remote computer for remote access in the Remote Port box. This value is specified in the Port box in the Broadcasting | Remote Access properties on the remote computer.
Specify port, which will be used to receive data from remote camera, in the Local Port box. If your network uses firewall, make sure that Local Port and computer's IP address are opened in the firewall. Use the Check the Port Availability button to make sure that this port is not used by another program.
If the remote computer requires authorization, enter user name and password in the appropriate boxes. The authorization could be set in the Broadcasting tab in the Camera Settings window in the Remote Access Additional Settings window on the remote computer.
If the Remember Password check box is checked, the user name and password will be saved among the session parameters.
Cycle through cameras
If you have multiple cameras you can set up a cycler to have the program to change cameras automatically.
To configure the Camera Cycler:
  • Click Camera Settings from the File menu.
  • Select Cycle through cameras to activate cycler.
  • Type cycler interval in seconds.
Select cameras to cycle.
Jul 13, 2009 | HP USB Web Camera
Port Forwarding not working on Port 80 from our website
The best way to test this is to forward it to a test webpage on another PC or server first to make sure it is working correctly, before trying the unix/linux php server.
In my experience external addresses do not work internally, unless you have your ISP allocate you moe than one external static ip
Please post your results, the provider and whether you already have multiple static ip addresses purchased
Feb 09, 2009 | NetGear RangeMax WPN824 Router
Wireless router install on cable modem w/static ip address set
Connect a computer to linksys lan port 1-4, point browser to linksys http://192.168.1.1 under Setup->Basic Setup->Internet Settings choose "Static IP" and fill in the fields below... the field for gateway should be set to the static ip of your cable modem. the field for netmask should probably be 255.255.255.0. It may help to turn on DHCP for local network so that lan hosts can get their ip's from the linksys.
May 15, 2008 | Linksys WRT55AG Router
Having a prolem accessing a Hawking wireless camera from the internet.
Also In order to connect to your camera you may need to get access from your computer. I would ask a friend to send a signal from there computer to your computer and see what happens on your end. That may solve your problem.
Hope This Helps
All The Best,
RCF
Apr 22, 2008 | Microsoft Windows Server Standard 2003 for...
Static ip
goto start menu -> accesories -> remote desktop connection
after that a window will open asking for ip.... if u give the ip it'll connect to that system and ask for username and password of the system to be remote accessed....
Mar 01, 2008 | Computers & Internet
Nuvico NVJV-4000N Video Recorder Logo
559 people viewed this question
Top Nuvico Televison & Video Experts
Electro Med Services...
Are you a Nuvico Televison and Video Expert? Answer questions, earn points and help others
