Question about Kitchen Ranges
Was doing self clean and cancelled because I left shelves in. Oven door would not open for a long time. Fianlly opened and I removed shelves. When I tried to reclose door the locking device was set and I could not close door. I tried the "bake time" & "stop time" pads at the same time to cancell the lockout. Nothing happened. I tried to turn the device by hand and it would not turn.
  • 4 more comments
  • joe_wilcox Sep 27, 2010
    Unplugged for almost 2 hours. Plugged in and waited 10 minutes, pressed "cancel". Nothing happened. Waited another 10 minutes and pressed "cancel" again twice. Still nothing.
  • joe_wilcox Sep 28, 2010
    Unplugged over night. Plugged in this morning, waited 20 minutes and pressed "cancel". Nothing again. Can not even turn the lock manually so can't close door or use oven.
    Please provide another solution.
    Thanks
    Joe
    There is no button like this.
    Can't run the clean cycle because the oven door will not close due to lock being stuck
  • joe_wilcox Sep 29, 2010
    My original request
    Was doing self clean and cancelled because I left shelves in. Oven door would not open for a long time. Finally opened and I removed shelves. When I tried to reclose door the locking device was set and I could not close door. I tried the "bake time" & "stop time" pads at the same time to cancel the lockout. Nothing happened. I tried to turn the device by hand and it would not turn
    Ms-shop suggested
    On these units they have a self resetting device that you will need to activate this is done by unplugging the oven for at least one hour then plugging it back in and wait for 5 min then press the normal cancel button or you might even hear a click sound then you will be allowed to unlock it okay and close the door hope this helps you out please rate this solution it helps get better results for our customers like you
    best regards mike.
    The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock.
    NOTE
    If the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
    Thank you and thanks for using fixya
    My reply.
    Unplugged for 2 hours, plugged in and waited 10 minutes. Pressed "cancel", Nothing happened. Tried again, still nothing. Tried unplugging for the night and then 30 minutes before cancel, still nothing.
    Woodchuk789 suggested
    Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
    or
    Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
    If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
    Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner
    My original request
    Ms-shop suggested
    best regards mike.
    NOTE
    My reply.
    or
  • joe_wilcox Sep 30, 2010
    Nothing worked. I am calling a service technician.
    Thanks for your help
    Joe
  • 2,299 Answers
Should be able to hold the lock button for about 15 seconds. And it should unlock. There should be a little icon of a lock on one of the buttons.
Posted on Sep 28, 2010
  • 4,059 Answers
or
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
    Genius:
  • 1,416 Answers
best regards mike.
NOTE
Thank you and thanks for using fixya.
Posted on Sep 27, 2010
  • 3,247 Answers
Might help if you are able to provide the oven make and model no. Cannot see that has been posted.
I do not see what suggestions have been made by other fixya consultants - but I will try to help you diagnose once you post the model no.
I am assuming you have already tried to turn the power off and on at the circuit breaker.
Posted on Sep 29, 2010
  • Sam Sep 29, 2010
    Looks like the lock solenoid is stuck in your oven.
    It might be a matter of shutting the power and opening the lock mechanism and release the spring from the solenoid.
    I cannot give you further instructions as somehow I cannot see the make and model no. of your oven.
    If it is a Frigidaire - then have you seen the instructions at this site. Sometimes the self-clean function damages the thermostat due to high heat required. If the thermostat has opened out it is likely it is giving incorrect signal to the lock mechanism.
  • Sam Oct 01, 2010
    As I mentioned before - cannot provide a specific solution if I don't know the model no. of your kitchen range.
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
Oven door won't open after self-cleaning. Open it
Unplug the range.
Remove the back panel.
Look for the long rod going from the back to the front of the oven.
Manually push on this rod to unlock the door.
May 10, 2010 | Frigidaire Gallery 30" Self-Cleaning...
When cleaning the stove i touched my accident the
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
My oven is locked and wont open. it is cold and wont unlock
Hi
Thanks for using FixYa. The locking of the oven is a safety measure while self clean function is activated. Once the oven has completed the cycle & has cooled down, then it will reset the door lock.
If a self clean oven door lock fails to open after the self clean cycle and sufficient cooling time has elapsed (approximately 1 hour), there are several things you can try.
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition or you were not using the self clean cycle, then, the lock must usually be accessed and moved manually to open the door—
In order to open the door you have to open the control panel and remove the door lock.
Remove the three screws from the bottom of the control panel. You'll heed a 1/4" open wrench. Pull the bottom of the control panel toward yourself and push it up to release from the upper tabs.
The door lock is secured by the three screws.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 25, 2009 | Maytag MER5775Q Electric Kitchen Range
How do I set the oven to self clean
The oven door must be closed and all controls set correctly for the cycle to work properly. After a Clean Cycle You may notice some white ash in the oven. Wipe it up with a damp cloth after the oven cools. If white spots remain, remove them with a soap- filled scouring pad and rinse thoroughly with a vinegar and water mixture. These deposits are usually a salt residue that cannot be removed by the clean cycle. If the oven is not clean after one clean cycle, repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to unlock.
While the oven is self-cleaning, you can
touch the TIMER/CLOCK pad to display the time of day.
To return to the clean
countdown, touch the COOKING TIME pad.
If the shelves become hard to slide,
apply a small amount of vegetable oil or cooking oil to a paper towel and wipe the edges of the oven shelves with the paper towel.
Using the self-cleaning oven.
How to Delay the Start of Cleaning
Make sure the clock shows the correct time of day. If your model has a latch, latch the door. Touch the SELF CLEAN pad. Using the + or or the number pads, enter the desired clean time. Touch the DELAY START pad. The earliest start time you can set will appear in the display. Using the + or or the number pads, enter the time of day you want the clean cycle to start. Touch the START pad. On models without a door latch, the door locks automatically. The display will show the start time. It will not be possible to open the oven door until the temperature drops below the lock temperature and the LOCKED DOOR light goes off. The oven shuts off automatically when the clean cycle is complete. When the LOCKED DOOR light is off, slide the latch handle to the left as far as it will go and open the door. If your range does not have a latch, the door will unlock automatically. n The words LOCK DOOR will flash and the oven control will signal if you set the clean cycle and forget to close the oven door or forget to latch the door on models with a latch. n To stop a clean cycle, touch the CLEAR/OFF pad. When the LOCKED DOOR light goes off indicating the oven has cooled below the locking temperature, unlatch the door (on models with a latch) and open the door.
Oct 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
the clean time remaining. It will not be
light goes off.
To stop a clean cycle, touch the Clear/Off
off, indicating the oven has cooled below
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
display.
Using the number pads, enter the time
to start.
light goes off.
a latch.
pad
After a Clean Cycle
oven cools.
soap-filled scouring pad and rinse thoroughly
repeat the cycle.
unlock.
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Door locked after shutting down cleaning cycle earlier than
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
May 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I need direction on how to start the clean cycle on my jenn air
CLEAN PAD
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
and
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
manufacturers.
TO SET FOR IMMEDIATE START:
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
desired.
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
opened.
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
TO CANCEL SELF-CLEAN:
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
clarkco
Feb 08, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
83 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
