Question about Hotpoint Dishwashers
I have a Hotpoint undermount dishwasher very basic model #HDA1200G00WW. I live in a building and it is leaking thru to the unit below. Which part could it be?
4 Suggested Answers
  • 93 Answers
SOURCE: hotpoint build in dishwasher will not drain hose not frozen or pl
hello sir you must have a clog at the drain valve or tubing where it enters sink connector alo makesure your drain tubing is not kink thanks from gilles
Posted on Mar 15, 2009
erpaalai
  • 999 Answers
SOURCE: water leaking from below dishwasher from below during cycle.
If you cannot see anything around the pump assembly there are a couple places where the pump attaches to the tum with seals that could leak, Look where the rack wheels attach to the tub also. A mirror and a flashlight are real handy for this. Depending on the cause for the leak will determine if it is worth repairing or repairable. Life expectancy of dishwashers is 7-10 years. Eric
Posted on Jul 02, 2009
heatman101
  • 43501 Answers
SOURCE: We hve a whirlpool dishwasher
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Aug 28, 2011
Dishwasher not cleaning
Remove the panel at the base of unit below door you should find the tech sheet which will tell you how to place unit into diagnostic, on the spray arms make sure the small holes are clean below the lower spray arm is a screen make sure it is clean not covered or cake with calcium build up if it clogged water cannot pass thru to enter the wash pump you can also remove the screws to take the upper halve apart to inspect the wash pump for any obstruction it is possible you could have a bad motor control or both you didn't mention after the unit fills do you hear the wash pump hum or click
Feb 07, 2014 | KitchenAid 24 in. KUDK02CRBS Stainless...
Hotpoint dishwasher 4th & 6th lights flashing
You will need to provide the model number of the dishwasher. However, the likely causes of the lights flashing are many, including water inlet failure, blocked drain filter, leaking seals causing flood switch to trip. You may want to go to the Hotpoint site and find the manual for your model.
Nov 05, 2012 | Dishwashers
GE Dishwasher Quiet Power III Dishwasher leaking
The average life of dishwashers is 7-10 ten years so it might just be dying but try this. If the leak is a small one that seems to always be near the left side of the dishwasher put a cup of white vinager in the upper rack and run the unit on pots & pans or heavy duty. This is caused by a build up of detergent that make the unit oversuds, when the suds turn back into water it leaks out the left front corner. The amount of water is not huge, one towel to clean up. If the leak is larger it could be the pump is leaking and you can order a new one with your model # from marcone.com
Nov 27, 2010 | GE Dishwashers
Leak on the side of the dishwasher - help please....
lets step back and take a look at this,this is the way a dishwasher works.1water in.2wash.3water out,that it.i just cant see this hose going up and down a rule the water goes straight out via the pump.let me stop you there and say follow what i have said and go back and have a good look and come back to me on this problem and i will help you.adrian,,,
Jul 02, 2010 | Hotpoint 24 in. HDA3400G Built-in...
My hotpoint aqarius dc26 dishwasher has stopped
this may be caused by a leak your dishwasher as a build in anti flood switch which stops water from entering when it leaks into the base of dishwasher . You may be able to check this for yourself by unplugging your dishwasher and slowly pulling it out and lean it back if water runs on to your floor you have had a leak .if at this point you turn it back on it might start to fill again .if it does start to fill turn it off again . it will need further examination to see why it leaking .if you feel you can't do this call your local engineer .
Feb 11, 2010 | Dishwashers
Water leaking from below dishwasher from below during cycle.
Jul 02, 2009 | Dishwashers
Water from ice makers leaks and builds up in botom of freezer
ice maker leaks are usually a sign of icemaker mold corrosion eating the lining off the icemaker causing it to leak. the only repair is to replace the complete icemaker. you will need a complete model number from the unit and the part can be ordered online thru whirlpool or some of the other appliance parts sites. you may even have a local parts warehouse where you live. hopw that helps peyton
Jan 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hotpoint dishwasher model BFI62
water leaking into base of machine. tip dishwasher back and drain out water. then check all seals intact, i.e. around arms, around salt holder etc
Dec 23, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Replacing the Gasket on the Dishwasher
My husband did not look thru the packaging that the gasket was sent in well enough. When a diagram or schematic did not seem to be forthcoming from the Internet and the manufacturer's website, that'prompted my husband to look thru the packaging more thoroughly.
Oct 04, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
Dishwashers Logo
32 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
