Question about Hotpoint NBXR463EBWW Electric Dryer
How do I open the front of my GE DBL333EA0WW dryer to get to the bearing?
  • 205 Answers
Hello- First, BE SURE the dryer is unplugged, and then be sure again. If you are referring to the front felt bearing with the 3 teflon glides then you will need to release the two retaining clips that attach the top the the front. They are located under the front of the lid a couple inches in from each side. The best tool is a putty knife or something a flat paint scraper. Place the tool between the top of the front panel and the lid and pry up a little bit in order to see the clips, they are about an inch wide. You have to press hard right into in (its like a flat metal spring) and pry up at the same time and the lid should release. Repeat on the other side. They can be a bit tricky but just don't force it too much. Once the clips are released the top hinges towards the back. There should be a wiring harness that goes to the timer and switches and one that goes to the door switch, these have plastic connectors that should separate them as a unit so you can remove the front panel. There is one screw on each outside edge near the top of the interior of the front panel that holds it to the main dryer cabinet, take these out and pull the front panel forward and up and the panel should separate itself from the cabinet. You have to be careful when you put the front panel back on that it slides in on the bottom retainer clips and that the top of the drum is positioned correctly over the felt on the front panel. Just don't force anything. Hope this helps, best regards.
Posted on Sep 27, 2010
My ge clothes dryer started making a loud skreaching noise im positive its the drum rubbing on metal in the front of the dryer how do i replace what ever is in between that seperates the 2
You need to replace either the front bearing (plastic that drum rolls over) or the glides that go on the front bearing ( glides that insert into the plastic bearing piece that the drum glides on.I would change both, simply remove the top of the dryer then you will see two 5/16' bolts that hold the front to the sides just inside on the top, remove the two bolts and remove the front of the dryer and you will see the bearing and glides that I have described. Replace,reassemble and begin quiet drying again. Good luck!
Aug 08, 2015 | GE Dryers
Tip
Help my dryer is eating my clothes
This is a common occurance in Frigidaire dryers and GE dryers. The glides wear out and the drum usually scrubs to begin with. On GE dryers the glides are mounted on plastic bearing. So the noise is not so much but it will still begin to bind up and to pinch. To replace the glides is very easy. Open the door to remove screws holding down the top. Or use a putty knife to pop the top on some models. Then remove the front panel. The bearing pops off and the glades are fairly easy to replace. I have a repair page on GE dryer HERE
on Jul 23, 2011 | Dryers
GE Dryer DBVH512EF0WW vibrates/shudders excessively. Particularly with the top on. I've replaced the front top bearing, drum slides and felt seal. What is my problem?
The only thing I can think of is if you have plastic inserts built into the drum then maybe you installed the wrong kit in the dryer.
Their are basically 2 styles of GE dryers. Those that have a steel drum and a bearing with glides on the front panel and those that have felt on the front panel and the plastic glides mounted in the drum itself.
Oct 12, 2012 | GE DCVH515EFWW Electric Dryer
Dryer leaves what looks like brown burn marks.
Read the link below and see if it describes the problem you're having:
http://appliantology.org/topic/26104-ge-dryer-model-dbl333ea0ww/page__p__166074__hl__%2Bburn+%2Bmarks__fromsearch__1#entry166074
If not, please reply back with the make and model of your dryer, and we'll go from there.
Mar 26, 2011 | Dryers
Have a dbl333ea0ww spins slow or not at all makes loud noise and sometime clothes get stuck between the drum and the outside of the unit
Sounds like your rear bearing is completely worn out and has gound a slot in the bearing bracket which makes a gap between the drum and the rear panel at the bottom
Mar 25, 2011 | GE DBL333EA Electric Dryer
Iam hearing scraping sounds from my dryer.
Hello Friend, Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim.
Jun 25, 2009 | GE DBSR453EBWW Electric Dryer
GE Gas dryer squeaks
assuming you have a normal GE..open door remove 2-4 screws going up into top they are where the top of door was when closed. remove top..have you unplugged the machine yet? DO IT NOW ! remove screws holding front on. tilt out and lift off. you should be able to figure the rest out..I would look at the rear shaft bearing..to remove tub pull straight forward..should be a sleeve bearing with a small amount of hi-temp grease on it. teflon sleeve
Jun 13, 2009 | GE Dryers
Ge dryer squeeking
HI,
For a pictorial troubleshooting please open the link:
http://www.applianceaid.com/my_own_dryer.html
You will be looking at the front glides that the drum rides on, the glides are probably gone and the drum is rubbing on the plastic glide holder....if it is damaged will need to replace the front drum bearing/glide holder and all of the glides, usually about 4 of them.
If it is the drum front glides the noise will be from the front area, right behind the front panel at the top. If the noise is from the center rear of the dryer your drum bearing is gone, need to replace this also if you have to take this dryer apart..
Thanks
Apr 08, 2009 | GE Dryers
Squeeking noiseGE DCVH515EF
Replace front bearing-Felt bearing wears out drum rides on plastic frame.
Mar 08, 2009 | GE DCVH515EFWW Electric Dryer
Ge dryer
Hi Thanks for the question .Open the door,screws under top. remove screws. lift up top. 2 screws on the inside of front , remove. pull front away front bearings on the front support. . thanks the appliance doc. Please rate my answer thanks
Aug 27, 2008 | GE DCSR483EA Electric Dryer
Hotpoint NBXR463EBWW Electric Dryer Logo
106 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
