Question about Emerson MW8107WA Microwave Oven
Loud pop with smoke
I plugged the microwave into a new outlet and i heard a loud pop. There was also a burnt smell. I opened the door and saw smoke coming from the vent behind the front panel. The inside microwave light still works but the front panel is blank and the buttons are not working. Is it toast or is there a fuse i can check? Where do i get replacement parts?
Thanks
  • Rick May 23, 2008
    Forgot to mention it is the black model. mw9107b
  • Rick May 26, 2008
    The outlet is in a new house I just moved into. New to me but a pretty old build. It probably is the outlet. I'll check it with my multimeter. I guess I need a new microwave. Thanks for the help.
  • 525 Answers
Don't know why just plugging it into a new outlet would cause that unless you have a problem with that outlet. Sounds like it may have burned out the low voltage circuitry. I would advise having the outlet checked and certified safe before plugging anything else into it. Also, it sounds like the oven is toast, (Sorry!)
You can get parts on-line from AppliancePartsPros.com/Parts
Posted on May 24, 2008
More life span
Whenever the door blows open you have some major problems. Maybe it is time for a new microwave oven.
Good luck
Dec 24, 2013 | GE Microwave Ovens
My microwave Maytag Model MMV4205BAB made a diferent noise and I opened the door once and I saw smoke and burning smell. I dare not plug the microwave again ... what could it be? What should I do?? Can be...
Make sure your microwave is fully cleaned out of any old dried food residue and that you are not using any kind of metal items in your microwave when you cook because this will certainly cause smoking and sparking inside your microwave.
Most like you had some corrosion or food particles stuck to your WAVEGUIDE COVER PLATE.
Here is a link to a short video that show you exactly how to replace the wave guide cover yourself:
http://www.youtube.com/watch?v=M0xsXjhefy4
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the video at the website indicated.
Thank you very much and good luck
Apr 19, 2011 | Maytag MMV4205 Microwave Oven
Lg micorwave, lam1180st refridgerator and microwave were plugged into the same outlet. i heard a loud pop. circuit breaker popped. i reset and the frige works fine. Microwave does not have power. the...
It is possible that the interconnection link(s) between the two sockets in the duplex outlet have blown apart. Turn off power at the electrical panel for this circuit, remove the outlet from it's box, and check the interlink on both sides. If obviously burned, replace the socket. A better option is to run another duplex cable from the breaker box to the outlet from a new breaker, cut the interconnections on the new socket, and wire the new cable to the isolated part of the socket. This supplies full power to each half and allows both units to run at the same time.
Oct 19, 2009 | LG 1.2 Cu. Ft. Mid-Size Microwave -...
Saw sparks and heard a pop noise when we hit ''start'' on microwave
We just had the same problem - spark, loud noise, and then dead. At first I replaced the ceramic fuse and the same thing happened immediately. A local appliance store tested the transformer and found it was "bad." I purchased a used transformer from the store for about $35. I installed both of these myself with little effort.
Sep 08, 2009 | Dacor DMO24SS Microwave Oven
Kenmore over the range microwave 721.63684300 - nothing works
you must remove the MW take off the cover then look for a large metal can (capacitor) and a white (ceramic) fuse...look and, smell and, you should find the cause
Apr 02, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Intermittant loud "pop" when starting my microwave
Clean well the inside of the oven, if you keep having the problem and the inside is clean, then the magnetron is starting to go.
Jan 28, 2009 | GE Microwave Ovens
Constant humming sound
the most common problem with ALL microwaves is the magnatron
Dec 29, 2007 | Samsung SMH7178STD Microwave Oven
Emerson MW8107WA Microwave Oven Logo
305 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
