Question about GE Washing Machines
I have a model GE wbsr3140goww Washer it does not spin fast enough to extract the water. Just started doing this, sounds like a switch might not be working?
SOURCE: Washer spins but not enough to extract water from clothes or tub.
I have a MAH5500AWH and experienced the same problem twice. Both times the R11 resistor on the control board was burnt up. The board is behind the cycle selector dial. To check, remove the outside screws holding the metal backplate for the user control console. Do not remove the inside screws as these hold components to the backplate. My advice is to replace the whole board. You can buy a new one (expensive) or try and get a used one from a repliance repair/parts center.
Posted on Aug 18, 2006
Cyril J
  • 45 Answers
could be a loss belt or a kinked hose, since you say it feels weak i would think it is not getting up to speed which would be a loss belt or drive train issue, of course it could just be to big a load or on slow spin speed setting
Posted on May 22, 2008
  • 686 Answers
SOURCE: spins slowly in stackable washer dryer
sounds like your spin brake is not releasing when the spin starts
Posted on Jan 08, 2009
  • 82 Answers
SOURCE: Washer spins but really really slow, not fast
it can be the pump if it does not get the water out fast it will slow spin best way to check put it on spin with nothing in and watch it if it does the same then the moter is faulty change it try ebay for replacements
Posted on Jul 29, 2009
wiringlunati
  • 576 Answers
SOURCE: ESTATE TOPLOAD WASHER MODEL#TAWX700JQ3, DOES NOT
Check if the belt is good and tight enough. If that washer uses a spring tensioner on the belt, make sure it travels freely and applies sufficient tension.
Posted on Jan 01, 2010
Testimonial: "very appreciative of the immediate response and suggestion from Guru, i will try my best."
Atf6000fs2 does not fast spin to remove water only slow spin /checked it on all spin speeds
Either the motor cannot turn over fast enough to power the pulley system, or there is an issue with the pulley system.
Sep 04, 2012 | Frigidaire Affinity ATF6000F Front Load...
Kenmore Automatic Washer Model 110.24642300 - problem is that spin cycle is not fast enough to get the water out, so clothing is sopping wet and loose at the bottom of the tub instead of plastered to the...
Your transmission is starting to go bad. It is not creating enough power to spin the clothes fast enough to dry them. It is cheaper to look for a new washer . To fix the transmission will cost you over 400 I would do light loads until your able to get a new washer
Jul 12, 2011 | Washing Machines
I have a kenmore 80 series and its not spinning out the water.
does it drain out the water and spin but the clothes are still wet or is it not draining or spinning?set the timer to spin,open the lid and stick a screw driver into the lid switch hole and see if it spins and drains,also if it doesn't push down and let the switch up,or close the lid down and open it a little do this a few times,you should hear the switch make a clicking sound,if it doesn't click you have a bad lid switch.if the machine is draining and spinning but the clothes are wet,do the same thing with the lid switch and watch it spin with the lid open,is it spinning fast,if not you have a bad transmission and it's not spinning fast enough to remove the water out of the clothes or you could have a kink in the drain hose or something in the pump and it's not draining all the way.let me know what you find and send the model number off of the washer,the number should start with like 110.
Apr 14, 2011 | Kenmore Washing Machines
ESTATE TOPLOAD WASHER MODEL#TAWX700JQ3, DOES NOT SPIN FAST ENOUGH TO EXTRACT SUFFICIENT WATER FROM CLOTHE
Jan 01, 2010 | Estate TAWS800JQ Top Load Washer
Washer spins but really really slow, not fast enough to extract water
Jul 28, 2009 | Speed Queen ATS90AWN Front Load Washer
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Spins slowly in stackable washer dryer
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
GE wpse4200aoww washer won't stay in spin mode
Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
Aug 23, 2008 | GE WHRE5260E Top Load Washer
Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
Feb 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
51 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
