Question about Cuisinart DCC-1200 Coffee Maker
On switch works sporadically - after waiting a day, it might come on
    President:
  • 512 Answers
You have a short in the switch. These units have a 3 year warranty. Call cuisinart 1-800-726-0190 they will replace unit for a $10 shipping charge. Very easy to deal with. If your unit is older that 3 years, try taking switch apart and cleaning and stretching spring.
Posted on Sep 28, 2010
I called Cuisinart. Very helpful. The sensor inside might be calcified. If the switch will not turn on, unplug the device for 1 hr. Plug in and see if it turns on (if not, unplug it over night). Then mix 6 cups of white vinegar with 6 cups of water. Run the mix through the machine to clean the sensor. Then run 12 cups of water to rinse the machine. If this does not fix the problem, call them for a repair.
Posted on Jan 08, 2011
J'ai resoudé le cavalier J17 sur la carte électronique de la façade
I have weld jumper 17 on electonic card in front
Bon Café
Posted on May 06, 2011
Radio switches on sound system of my 2008 Honda Goldwing work sporadically
Hi, Mark for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Radio problem
2002 1800 Goldwing radio problems
Honda GL1800 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Goldwing GL1800 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 24, 2013 | 2008 Honda GL 1800 Gold Wing
My Maytag MER5570ACW coil range burners sporadically run away and get red hot. If I turn rhe burner off, wait a few seconds, then turn it back on again it solves the problem until next time - maybe the...
It is not a common occurence so their is no service bulletin the only fix indeed to to replace the switch the parts# are
LARGE BURNER 7403P238-60
SMALL BURNER 7403P239-60
I hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Maytag Kitchen Ranges
When I first started using this modem, it worked great and easily worked well with my Belkin router. One day when I came home, the modem was only flashing the "power" light was flashing and I had...
Flashing power light on Router is sign of hardware failure As mentioned, you have already reset the router
You can try to hard reset the router one more time
Follow this procedure
1. Press the reset button with some paper clip 2. Wait for 10 Secs 3. Turn of Power to the router (While Reset button is still pressed) 4. Wait for 10 secs 5. Power on router 6. Wait for 10 secs and then release the Reset button
While doing this make sure reset button is pressed continuously start from Step 1 - 6
Check if Power light still blinks
If No - you can setup router like before and it will work If yes - Buy a new router or get it replaced if under warranty
Jun 29, 2011 | Arris SURFboard SB5101 Cable Modem
Subaru Forester 2001. Parking lights stay on when car is turned off. Lights go off only when fuse removed. Light switch on steering column was changed to no effect. Separately, AC, fan and heater...
I have had the parking lights on my 1998 forester stay on w/ no way to turn off. Used the remote door lock to lock and unlock car and the lights went off?????????? This has happened twice with the same solution
Nov 26, 2010 | Subaru Forester Cars & Trucks
1997 venture van. Fan for heat and A/C not working
Check the fuse and then the switch it self, if the fuse and switch is good. Then check the blower resistor and blower motor it self. I'm leaning towards the switch it self since you mentioned that it was sporadically and on the highest setting would by pass the blower resistors. Good luck and if it's not the switch then it's going to be the blower motor it self. Auto Zone has them in stock and can give you the step by step instructions for you to get the job done with common tools.
Nov 12, 2009 | 1997 Chevrolet Venture
2008 Chrysler 300 sporadic electrical problem at ignition
sounds like a short or loosening wire somewhere - have any "after- market" accessories been added ??? new stereo or amp ?? check these item and there wiring if so. It could also be the ignition switch itself......unfortunately - you may have to wait for a permanent failure to find the cause
Oct 24, 2009 | 2005 Chrysler 300
The fan doesn't work (most of the time)
when waiting a year to try it out , you get what you got and can not complain about it . try a new battery
Oct 18, 2009 | Playskool Busy Ball Popper
Please Help !!! my Motorola RAZR V3i is automatically shutting down ...
take the phone and have the firmware reflash this should correct the issue that you are having
Jun 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Cuisinart DCC-1200 Coffee Maker Logo
1,901 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
