Question about Kodak EASYSHARE 5100 All-In-One Printer
I need to remove the ink cartridges from my Kodak Easyshare 5100 All-In-One printer so I can recycle the printer, but I don't have the power cord. Is it possible to remove the ink without turning on the printer? The printhead seems to be stuck in place to the right where the opening is not big enough to remove the black cartridge.
  • 823 Answers
It is best to power up the printer before removing an ink cartridge. If that is not possible, then push the power button to release any stored electricity and then grab the cartridge and slide it towards you. The cartridge is in a holder that is connected to a bar that goes straight acrossed. It should slide when pulled? If it is locked down, then remove the screws that hold the top case and remove it to expose the cartride and remove it.
Posted on Sep 27, 2010
Kodak printer states printhead loose or missing, this error message came on when I replaced the introductory color cartridge, which occured 1 week after taking out of box.
To resolve this error:
  1. Open the printer access door.
    Disconnect the power cord
  2. Remove the color and black ink cartridges.
  3. Remove, then reinstall the printhead.
    • Unlatch the printhead:
      press the button in the upper-left corner of the carriage.
    • Lift the printhead out of the carriage.
    • Place the printhead in the carriage.
    • Press firmly against the target label on the printhead until it clicks into place.
  4. Install the color and black ink cartridges.
  5. Close the printer access door.
  6. Connect the power cord.
  7. Then follow the instructions on the LCD screen
Jan 23, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 series is not recognizing refill
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 Needs Both Cartridges To Print?
Unfortunately, you cannot used the printer if one of the ink cartridge is empty., compare to the other printers you can print a black text or gray scale if the color is empty or one of the cartridge is empty.
All kodak printers work the same both cartridges should have ink on ink before you can use It.
Nov 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300 shows "color ink cartridge needs replacing",even with new cartridge,and new printhead..Ink level display shows color cartridge empty,and its brand new..
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Sep 23, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
5100 blinks check color ink, but it won't scan or copy either. We did lose power for awhile and I'm thinking it needs to be reset. Possible? Any suggestions?
u can reset the printerby turning it off n removing the power cord for a while and then reinsert it and onthe printer.but if color cartidge is actully faulty thenu will hve to replace the cartridge to make it work.
Dec 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printer Kodak Easyshare 5300 Will not print black ink
They overnighted a new printer head and free ink. We already recieved it. AMAZING. Thank you Kodak. They are awesome.
Dec 17, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EasyShare 5100 All-in-one printer will not print ink
you most likely need to run a head clean and alignment, which is needed after each cartridge replacement.
http://tinyurl.com/6qcpgy
Jun 24, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300 Power
talked to kodak servcice and they are sending replacement.
Apr 27, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Prnter kodak easyshare 5100
just to check, is what specific lights is blinking is it the check color or just check black inks??
-to make sure w/ this one is it blinking too fast or slow and what is the color?? check if the on and off is also blinking
-check black ink and check color cartridges blinking fast means no printhead installed
-check black ink and check color cartridges blinking slow, no cartridges installed
-check black ink and check color cartridges blinking w/ on and off ready to calibrate
(in ready to calibrate if doing nothing, just press cancel and
-press photo and cancel on printer, if not doing anything
-remove printhead( the one that holds the cartridges) turn printer on and off, put printhead back to printer w/ cartridges, and check the lights that is blinking
-press photo and cancel again
-if not doing anything, contact manufacturer
-goodluck
Mar 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
59 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
