Question about Zodiac Baracuda G4 Automatic Pool Cleaner Ne221
Won't move properly , vacuum setting ok - Zodiac Baracuda G4 Automatic Pool Cleaner Ne221
  • 44 Answers
Your Diaphragm is probably bad. they go out quickly if the suction is set too high.
Posted on Sep 28, 2010
My F250 fan diverter won,t work
The vacuum supply line to the climate control unit could be broken if it is gas engine. If ti is a diesel engine the vacuum motor or pump ,depending on the set up, is not working properly.
Feb 23, 2015 | 2003 Ford F250
Why won't the blower blow air on the floor?
Check vacuum lines, as most will use vacuum assist to move the damper doors, they should connect to your intake manifold or a shared vacuum block.
Apr 14, 2013 | Cars & Trucks
Ok can any one help me I have aidi 80 1993 the brakes only work when im sitting still and rev the engine
Check your vacuum assist braking vacuum line. Hose maybe loose or blocked.
Oct 24, 2012 | 1993 Audi 80
Car won't pull back speed when foot off accelerator
Very possibly a vacuum issue. Maybe a line that needs vacuum for the trans is on an inlet that effects the throttle. Not sure how old your vehicle is.
Aug 23, 2012 | Jaguar Cars & Trucks
Hi. My vacuum won't power up. The plug-in is OK. Is there a re-set on the motor I can try? Thank you, Vic
Need to know which vacuum it is. The more reasonable vacuums will not have a reset. You probably are missing a filter that needs to be cleaned. Your cord could be bad or even the plug on it. Depending on what it is worth and how much you like it, you should take it to a vacuum shop.
Jun 20, 2011 | Bissell 6596 Bagless Upright Vacuum
Refridgerator is not working will not get cold
Here is the basic idea on how to keep the refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved by an electric fan or blower in order for that product to work properly. If air movement is blocked the fridge won't get cold, the central air conditioner won't cool enough, the vacume cleaner won't clean as well. Check on your fridge's air movement by inspecting the bottom of the fridge for dust and cob webs. Remove the front bottom clip-on plastic grill. Or also even access the lower back of the fridge by removeing the screws holding up the heavy cardboard cover to see inside. Blockage of air flow will prevent a fridge from getting cold. Just like a vacume cleaner stops working when the bag is filled with dust and fibers.
The air could be blocked by the accumulation of dust and fibers. Look under your fridge if it is cloged, it will look just like the stuff on a dirty central air filter.
Dust and fiber buildup blocking the fridge's air movement from back to front (or visa-versa) of your fridge will slowly (years) prevent how good it cools. The build-up of dust and cobwebs prevents your fridge from cooling (more specifically prevents the heat to disapate from the metal heat disipating fins attached to the metal tubes to be blown off by the fans air). OK! Remedy for a vacuum cleaner REPLACE THE CLOGED VACUUM BAG.
Remedy for your fridge manually REMOVE THE CLOGING DUST AND FIBERS FROM UNDER YOUR FRIDGE. SORRY fridge manufacturers do not provide a dust filter like the vacume cleaner and central air systems manufacturers do. You have to figger out the best way you can clean it. Possibly vacuum with a crevice tool, or use a small brush than vacuum. The extreme would be unplug the fridge ( so you won't get electrocuted) bring a water hose into the kitchen and spray water at cobweb buildup at the bottom fridge, than wet vac the floor then wait 20 minutes to dry before pluging the fridge back into the electric outlet.
When you stand in front of your fridge and you hear the fridge electric motor turn on, the fan will blow air.The fridge
May 30, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freeze and ice maker quit making ice and prevent it to keep food frozen
Here is the basic idea on how to keep the refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved by an electric fan or blower in order for that product to work properly. If air movement is blocked the fridge won't get cold, the central air conditioner won't cool enough, the vacume cleaner won't clean as well. Check on your fridge's air movement by inspecting the bottom of the fridge for dust and cob webs. Remove the front bottom clip-on plastic grill. Or also even access the lower back of the fridge by removeing the screws holding up the heavy cardboard cover to see inside. Blockage of air flow will prevent a fridge from getting cold. Just like a vacuum cleaner stops working when the bag is filled with dust and fibers. The air could be blocked by the accumulation of dust and fibers. Look under your fridge if it is cloged, it will look just like the stuff on a dirty central air filter.
When you stand in front of your fridge and you hear the fridge electric motor turn on, the fan will blow air out the bottom.The fridge
May 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Vacuuming
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=725106
Vacuuming
Posted by egarcia on Jun 30, 2008
It is hard to move forward when vacuuming, ok when moving back
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds like you have a Kirby vacuum and there are a few things you may want to try. #1. Change the belt on the vacuum every 4 to 6 months for the best cleaning and the belt also helps you with the movement, and to store the extra belts in a Ziploc bag in the refrigerator. #2. There is an adjustment on the brushroll on each end of the brushroll by turning the screw heads and ½ to 1/3rd turn on each side. #3. if the belt is changed and the brushroll has been adjusted then on the height adjustment, try this… raise the height adjustment to the highest level and then adjust is down one step @ a time until you hear the tone change, that is when the brush hits the carpet and the vacuum head creates a seal. Then try to vacuum the carpet – if you feel like it is doing a good job then you have got it adjusted correctly, if not adjustment one more down and the setting should be complete. If the setting is all the way down on the floor the vacuum cannot do its job properly. Also it a good idea to change the vacuum cleaner bag; and to clean the inside of the cloth bag. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Kirby G5 Bagged Upright Vacuum
Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Logo
83 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
