Question about Intel DG31PR Motherboard
My monitor doesn't get any signal.i've checked all the other hardware and software and there is no problem whatsoever with them.also i need to change the sata ports from sata0 to sata1,2,3,4 and reinstall the jumper in alternate mode for my system to work.also there is no probolem with the data cable.
Did you update/downgrade your bios version....
Posted on Sep 28, 2010
Hi I've got an all in one PB one two M, with
YOU MIGHT CHECK WITH TECH SUPPORT FOR THAT DEVICE AND GOOGLE THIS DEVICE FOR ISSUES OTHER MIGHT BE HAVING YOUR SAME PROBLEM(S)...?WITH AND YOUR MANUAL MIGHT NEED TO BE CHECKED FOR SOLUTION(S)...?
Jun 14, 2013 | Televison & Video
My Insignia Monitor doesn't work with my laptop, I've tried everything, from pc settings to cables, etc, i only receive a NO SIGNAL ad
Usually you have to toggle the display output on the laptop. The FN key + one of the F# keys with a monitor icon on it. Toggle it until it outputs to the monitor. Your getting "no signal" because no signal is being sent to the monitor or you have the monitor on the wrong input if it has multiple inputs.
Dec 24, 2012 | Insignia Computers & Internet
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
No signal to monitor
Try disconnecting and reconnecting the monitor and powering off the pc for 1 minute. Power back on. If that doesn't work, try borrowing another monitor to verify it's not the monitor. Next, try reinstalling the software.You may need to acquire another video card.
Apr 22, 2012 | Computers & Internet
Hi, I've just purchased a Hanspree SV32AMUB for my Dell monitor. The TV doesn't pick up the signal even though the PC is connected to the HDMI-1 port, and I've set the input to HDMI-1. C
I assume HANSPREE SV32AMUB is an external monitor and you want to watch what is on your laptop PC transferred to your TV. If this is the case Toggle the Fn key on your laptop.
EXPLAIN IN DETAIL WHAT YOU HAVE AND WHAT YOU WON'T TO DO. I'M A LITTLE CONFUSED
Apr 07, 2012 | Computers & Internet
I m new beginner in hardware field guide me how i check signal fault in any mobile guide me sir pl
Hi Buddy,
Signal has a wide range field or area in diagnosing a network problem,it depends the situation on what happen to the phone,weather it was watered damage,drop off the ground or suddenly lost network.
Let's start with the Software Problem
* check your network settings if set to DUAL mode,it means you've 2G or 3G signal,if this mode is far away from your area or out of coverage,you will experience signal dropping, If you are not using 3G signal,better switch to GSM mode and it will stick the signal along your area.
For Hardware Problem
* Base on source and latest issues about signal problem is by replacing 2n2 capacitor,before reheating or removing some main parts like PA (Power Amplifier) and other IC,better focus on this capacitors,Here is a illustration and have a look were it is located
* For no access,change the upper part.
* For no network coverage, change the lower part.
For the meantime,just stick with this solution before doing hardware modification,If you have some questions,don't hesitate to reply,i will give more ideas regarding signal problem.
Thank you for visiting FixYa.
Jul 24, 2011 | Nokia N70 Cellular Phone
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
Problem in monitor
Hey vinay i guess its hardware problem ... coz software doesn recognise u hitting it ,,, ; )
Nov 28, 2007 | LG L1520B 15" LCD Monitor
Monitor port not working
if you have'nt already, try changing motherboard setup configuration.
Mar 25, 2007 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Intel DG31PR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
