Question about Dishwashers
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of buttons: Normal Wash Heated Dry Normal Wash Heated Dry Normal Wash After that ? all the lights are lit up as follows: Smart Wash, Pots Pans, Normal Wash, China Gentle, Turbo Zone, Hi Temp Wash, Sani Rinse, Heated Dry, Sanitized (Green light ? not a button), Lock on (Red Light ? not a button), 4 Hour Delay, Cancel and Start. All the buttons, lights are red ? with the exception of Sanitized which is green as noted above. After this I hit Cancel ? only the cancel light is on (which is also the drain function). Then I hit cancel again ? that light goes off and you are able to re-run the machine.
  • Bill Holtkamp Apr 09, 2012
    I did not hit the Cancel button after following your instructions and the washer started in the middle of the cycle where it had left off. Thank you very much for the insight!
  • 11,896 Answers
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Posted on Oct 06, 2010
3 Suggested Answers
SOURCE:
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
  • 70 Answers
SOURCE: remains on Gentle/China mode
unplug the unit from power and plug it in back after may be minute or so.if it works, fine otherwise control panel has to be chgd.it comes as complete assly(top black part) and it is very easy to chg.
Posted on Aug 18, 2009
My Kenmore 110-46462501 washing machine stopped mid-cycle
Can you hear the pump running? It might be plugged or not running
I’m happy to help further over the phone at https://www.6ya.com/expert/pat_7f6b46a4565f904d
Oct 20, 2017 | Kenmore HE2 Plus Front Load Washer
Hello, my kenmore dryer just stop working, light inside is still on but will not turn or come on Mod# 110.c66492500
Is the door completely shut? Did it stop working right in the middle of a cycle? Are you drying shoes in this load? I'd turn it off, and try it again. If this doesn't work, try it on another drying cycle. If this doesn't work, feel free to contact me again. I hope this works for you. Good Luck! Jim
Mar 30, 2010 | Kenmore Dryers
Washer will stop in middle of cycle
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Washing Machines
Won't stop cleaning to go to dry
I have not worked with this Kenmore model, but:
It would be good to check the heating element to make sure it has not failed. Some dishwashers will wait forever for the water to come up to temp before it goes to the next cycle.
If the heating element checks out:
-IF it has a knob/dial that you turn to start the dishwasher on any cycle, that timer/controller has most likely failed.
-If your dishwasher does NOT have a dial as described above, then the main controller card (PCB) has most likely failed.
May 05, 2009 | Kenmore 16072 - Multiple Color Built-in...
The dryer was running then in the middle of the cycle it stopped. Cleaned the vent and tried to restart it and nothing? Please help me????
most of the time when that happens it's from a weak motor,it overheats and shuts down till it cools off then will start again,how old is the dryer?mike
Apr 19, 2009 | Kenmore Dryers
I have a Kenmore Elite Washer that does not complete the wash
The timer should be checked/replaced.
Jan 12, 2009 | Kenmore 22422 Top Load Washer
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Dishwashers Logo
815 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
