Question about KitchenAid K45SS Classic Stand Mixer
Oil leaking, sounds like the problems folks are having with the K55 model
Do You have a manual, and is this something I could tackle at home.?
  • 1Gooch Sep 01, 2008
    Exact same thing happened to me. I have an Artisan.
    Did you get any resolution as to type of grease/oil to use and how to install?
    Thanks,
    Gooch
I've got the same problem, I put my mixer in a box when I moved and it must have gotten tipped over cause there was oil all over it that spilled out from inside. How can I crack this thing one and refill the oil and what oil spec does it need?
Posted on May 24, 2008
    President:
  • 2,712 Answers
Could you please describe the issue in more detail? Thanks.
In the meantime, I will see if I can locate a service manual.
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Have an A901E model and there is oil leaking from the head, does anyone have a repair manual, so that I can figure out how to repair it?
My chef A901 started to smell and leak oil. I started to dismantle it but found that a service manual is needed. Kenwood will not supply this for "Health an safety" reasons. can anyone help please.
Sep 01, 2010 | Kenwood KM800 Major Classic Stand Mixer
Leaking oil from the mixer head. Occasionally find a drop of oil has collected on the end of the mixer shaft. What is the cause of this problem and can parts be ordered so I can fix it at home?
This is the end seal of the motor, you can get parts from manufacturer. you will need a service manual, OR go to the manufacturers web site and contact them.
Mar 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Moved our mixer to another packed on its side, not
Hi AQUACLAY. For starters, for your next move remember to tell your packers to pack the mixer upright...J
OK, to answer your main question, your KA mixer’s internal gears are factory packed with enough grease to last a 'lifetime', whatever that means? Depending on the age of your mixer, where it’s been stored and how long it's been idle and/or how heavily it’s been used; these factors all will eventually cause the grease’s base oil to separate from its additives, with the resultant oil seeping from openings beyond the gasket and generally following the path of least resistance down to the lowest point, i.e., the agitator shaft. Gravity can be very insidious. Of course, laying our mixer on its side offers a whole bunch of other exits points for the oil. With that much oil lost, you definitely want to replace the transmission gear grease at some point in the future.
The good news is that this can accomplished quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person, and feel adventurous and your mixer is not under warranty. Before you start to disassemble your mixer, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your KSM5 mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. Besides replacement grease you might consider replacing the Transmission Case Gasket (Illus. No. 26) and “O”-ring (Illus. No. 53), too. I’d also check to make sure there is no oil residue lingering where the oil leaked when it was lying on its side during the move; particularly if it leaked out of a brush hole on the side of the mixer head. Oil and electricity don’t mix, so here’s the opportunity with your mixer apart to wipe down the path the oil took to ‘escape’.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
Once apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
Good luck, I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Jan 09, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Oil leaking from mixer head
This is a fairly normal problem and as long as there isn't a lot of oil leaking it doesn't usually indicate a problem. this oil is cause by the normal function of the machine and only requires time to time cleaning. since there is a gear inside the planetary it does usually have oil on it as well. However if you are getting more than desired leakage of if it is alot it could be the inner seals. There are 4 located inside the unit. and if broken or worn may have to be replaced. I can give you part numbers if you can supply a proper model number.hope this helps
Thanks
Oct 14, 2009 | KitchenAid Food Mixers
Oil leaking from hobart d300 mixer
DEFINITELY contact the manufacturer (Hobart) on that one. Sounds like you're having some sort of an internal problem with it (something might be cracked), and in this situation, the best way to go is to contact the manufacturer rather than try to repair it yourself. If you're still under warranty, and you try to open the machine up to fix it yourself, you could wind up VOIDING the warranty, and if you're out of warranty, most repair places won't touch a machine that you've messed with already--too much of a liability.
Just give Hobart a call, and they should be able to help you (if you're in warranty, sometimes even for free!). Their phone number (according to their website, www.hobartcorp.com ) is 1-888-4HOBART (1-888-446-2278)
Good luck! :)
Aug 27, 2009 | Hobart D300 Stand Mixer
Are attachments for a KitchenAid K5 compatible with the K55?
That would be incorrect. If the attachment is for a hobart kitchenaid mixer then it will fit all models of kitchenaid mixers including the brand new pro series because the attachment port and drive gear has not been changes since 1925 or 6 when it was first introduce by the Hobart company.
Apr 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Oil leak on A200
OK guys, let's try to solve your common problems first then the rest will become clearer.
The Hobart A200,,,,,,,, does not use oil! It uses grease! If you see oil, it's because the grease is separating the oil in the grease. Both machines have not been serviced for at least 5 years. That's about the lenghth of the lifetime of most greases. I recommend that you call Hobart and ask about their tech. rates. All bearings should be checked carefully for wear, as should the worm gear, seal, and the Bronze gear that it turns. The Planetary (mixing part), should be removed as well, cleaned. and inspected. Replace the seal on the planetary and on the mainshaft. Removal of all old grease is required, as it's no longer doing the job it was designed to do, will result in advanced wear, and is the actual source of your problems. The seals were designed to seal grease, not oil.
If Hobart is too pricey for you, and they are for many, try to find someone from a wholesale restaurant equip. place who has rebuilt these machines, or find a repair shop who have experience with this Hobart model. If you'd like to tackle the job yourselves, go to www.hobartservice.com. Register for free, then find the files that match your mixer model and ML # and download the parts files for it. These exploded drawings will be very helpful with your task.
Either way, these mixers need to be opened up to remove existing oil and hardened grease, especially the oil! The planetary must be removed to drain any oil out of it and to regrease it. If you can get the oil out of the mixer, a short fix would then be to simply regrease the the mixer and put it back into service, leaving the existing seals in place. Don't forget to wipe out the shiny ring on the planetary, if it too has oil in it.
There is no seal at the hub. No seals can be tightened. The oil leak underneath the mixer comes from the motor shaft seal at the transmission case where the pinion gear enters the trans., it flows down into the mixer support column and drips onto the floor or counter, again, because of the breakdown of the grease.
If you tackle the job yourself, find your local Chevron Distributor and get several tubes of the approved grease, namely, Chevron FM ALC EP NNGI 2. Chevron p/n 230204-000. If you've found this solution helpful, please rate it as fixya!
Good Luck! ricardok45
Jan 19, 2009 | Hobart A200 Stand Mixer
K45SS leaks lubricant
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Exploded parts views for all mixers are available at www.kithchenaid.com. Click "Customer Care" in the upper right hand corner of the main page, and then select "Locate Manuals and Guides." You will need to enter the unit's model number exactly as it appears on the bottom of the mixer. It will be listed on a white sticker.
Nov 03, 2008 | Food Mixers
The solution?...the oil leak is a very common problem with the kitchen aid mixer. If you don't use your mixer a lot the gasket dries out and the gear casing oil leaks. Doesn't that sound like a tasty ingredient to add to your cookies?? You'd think that a gasket wouldn't dry out so quickly...but it does. You'll spend about $125 to get it fixed at a shop. If you seach the net (consumeraffairs.com) you'll find hundreds of complaints just like yours....and mine. Kitchen Aid's response is basically tough luck, we got your money.
Sep 14, 2008 | KitchenAid KSM150PS Artisan Series Stand...
N-50's need restoration
im a hobart service tech and service these mixers alot.the usual suspect problems is the tumbler assembly.service manuals from hobart---good luck they dont release them.i can help you out,
Jan 18, 2008 | Hobart N50 Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
160 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
