I have panasonic kx-ft981 fax machiene. If i dial a number or fax, it response after picking up the reciever.
4 Suggested Answers
  • 168 Answers
SOURCE: Panasonic KX-FM220 fax machine does have a dial tone
I would double check your phone cord. There is usually 2 jacks in the back of the fax machine. 1 is for Line, and 1 is for phone.
Your phone cord should be hooked up in the LINE jack that goes to the wall.
I would also double check your phone cord on another phone to make sure the cord is good.
If you look at the clear connector that you plug into your wall and fax machine, does it have 4 copper/gold color wires contacts imbedded in the clear plastic connector?
Another thing to try, if you fax machine has a Line and a Phone connector, try plugging in a phone in the PHONE connector. Then hook up another phone cord going from the LINE to the WALL jack.
If you get a dial tone on your Phone, then you know you have it connected correctly. If no dial tone, then I would go back to the phone cord.
check those things and get back to me and I will see if I can help you with more suggestions.
Good luck.
Mac =)
Posted on May 02, 2008
SOURCE: panasonic fax model KX-FT981
the machine showing memory full . how clean memory
Posted on Feb 13, 2011
SOURCE: Using the fax machine of Panasonic KX FT981, how
Panasonic KX FT981
I am unable to rcv fax message because memory full messsage is diplaying.
How to delete memory
Pls help
Posted on Apr 01, 2011
Panasonic kx-ft981 ,no print out and copy.
Panasonic kx-ft981 ,dark print out and copy.
Jun 23, 2012 | Office Equipment & Supplies
Problems with panasonic kx-ft981 fax machine
my panasonic kx-ft981 get trouble with paper jam, i change with different paper fax it still paper jam... plz help
Mar 17, 2012 | Office Equipment & Supplies
Panasonic KX-FT981 our Fax phone has no ink any more. where do we get ink and hoe to put it in the fax phone?
Maybe I'm missing something here, but your machine appears to have a thermal printer. If this is so, there is no ink to replace. One simply buys a roll of thermal printer paper from your office supply store, or order it online. A search for 8.5 inch thermal paper turns up several listings for the paper. If this is another type machine, sorry.
Oct 21, 2010 | Panasonic Lands Phones
Panasonic fax model KX-FT981
Jul 15, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Cant change the nite mode to a day mode
On the phone press PROGRAM, press the original DAY button, dial the number 2, dial 781#, press AUTO DIAL STORE, pick up and drop the handpiece.
May 21, 2010 | Panasonic KX-T7730 Corded Phone
Using the fax machine of Panasonic KX FT981, how can i add a contact (including its number) into the phonebook ?
Panasonic KX FT981
Pls help
Feb 24, 2010 | Office Equipment & Supplies
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
My Laser Panasonic Fax won't pick up papers when sending faxes
There is a sensor in paper tray .u will see just its lever at the other end of lever there is a sensor .i think it is dirty .just clean it properly.now when u will put paper u will listen beep.now sensor is working .fails to pick up mean that fax try to pick paper but not pick the paper .there is a ruler justclean it with cloth and some licquid.and properly check this ruler is movi ng or not moving.
Nov 16, 2007 | Panasonic KX-FL521 Plain Paper Laser Fax
118 people viewed this question
k24674
jasbo
jasbo
