Question about Refrigerators
Dometic fridge 7401L repair/service manual - Refrigerators
3 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: Dometic RM763. Freezer=Yes,Fridge=No
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 21, 2009
  • 394 Answers
SOURCE: our rv has a dometic rm2600 fridge that smells of
Sorry to give you the bad news. The ammonia smell is the the refrigerant
leaking out. Dometic uses ammonia that is heated and then condensed to cool. It will all leak out and quit cooling.
The fridge is wrecked. There are shops that rebuild the units. Beings as ammonia is corrosive one must assume there may be other leaks ready to appear. There are RV salvage yards that sell good used units.
Again Sorry for your loss.
Posted on Apr 27, 2010
Repair to dometic rm361 fridge
Hello James Hunter,
Dometic: Enjoyed being here before...
40+ foot... (I'm guessing mid 1980's)...
As I recall... my neighbor had a magnificent "Beaverton, Oregon Coach. Didn't have a washer dryer... nor satellite dish... but pretty much everything else...!!
Dometic support staff documents & tech support were great.
More trouble than another house & a half (I loved it) ...
((all for a few tumblers of Jack, Old No. 7, ... Plus parts)).
I'm working on the ICE-MAKER name... but the FRIG was a
DOMETIC... really nice unit...
Only ever had two troubles with it... one was a simple power
issue... the other was a thermocouple...
Did have early Mobile Phone, ship-to-shore... & CB...
Everything was serviceable on it... He had ALL THE ORIGINAL parts lists... Awesome unit...
If you need to get any serious help trouble shooting this..
the trouble charts are in the manual.. While it was NOT LARGE it was great engineering!
Check out the MANUAL below for trouble shooting procedures.
http://www.bing.com/search?q=dometic+rm361&src=IE-SearchBox&FORM=IENTSR&pc=EUPP_
For the free PDF Manual - Go to:
http://webspace.webring.com/
Nov 07, 2016 | Dometic Refrigerators
I have a dometic fridge freezer model number RM2652 where can I get it repaired on the recall. I live in the Uk
go google and type in --authorized repair agents for dometic fridge /freezer equipment---
look for one close to where you are
contact the "contact us " area on the manufacturers web site
Sep 17, 2016 | Dometic Refrigerators
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Dometic service manual
Check the fuses in the main board on rear of fridge.
Jul 26, 2014 | Dometic RM2652 Refrigerator
Had a strong Amonia smell. Fridge wants to turn on but no cooling.
Strong Ammonia smell is dead give away for LEAK. Ammonia is the chief ingredient in the absorption type cooing system. Probably not economical to repair. For a second opinion, contact a Dometic Authorized Service Center.
Thanks for your question @ FixYa.com
May 31, 2011 | Dometic NDR 1292 Refrigerator
Our rv has a dometic rm2600 fridge that smells of ammonia inside and has a little bit of yellow residue in behind service panel. is the fridge wrecked or is it worth repairing. the rv is 27 years old.
Apr 27, 2010 | Dometic RM2620 Refrigerator
Dometic RV fridge will not stay on while traveling
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jan 22, 2010 | Dometic RM2652 Refrigerator
RM2401 Dometic propane fridge
Would you like a service manual and my help for free?
Let me know, Sea Breeze
appliancepartsoutheast@live.com
Aug 08, 2009 | Dometic WA3210 Compact Refrigerator
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
