Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Rotator brush not spinning. Handle is not in the locked upright position. Says it's beltless, so is this likely an interlock switch or drive motor problem ?
  • 1 more comment
  • masong271 Sep 27, 2010
    Read again it again! The handle IS NOT in the locked upgright position.
    So again I ask: which is more likely - a dirty or defective interlock switch (handle in the down position not closing the switch), or a defective Rotator brush motor ? How would I find out?
    Read it again. Handle is not locked in the upright position.
    On the top of the carpet nozzle housing there is a Reset switch (overload protection). Check it closely to see if it has tripped and its yellow plunger is extended. If it has tripped, reset it by pushing the plunger in.
  • 2,382 Answers
Hi, the brush roll will only spin when your handle is not in the locked upright position, once the handle goes upright - the brushroll de-activates
Posted on Sep 27, 2010
Why did the brush roller stop spinning?
With the cleaner unplugged, turn the unit over and look inside the opening where the brush is located. Do you see the clogging of the brush with lots of hair? If so, you will need to disassemble it to remove the hair. In any case, you will probably need to take off the cover to see if there is an obstruction jamming the brush. Also, check to make sure that motor for the brush is getting power. If there is an electrical cable on the outside connecting the brush housing to the rest of the vacuum cleaner, check if it is disconnected. When you have the cleaner on, do the lights glow? Do you hear the motor running? Try the above and report back.
Jul 21, 2015 | Kenmore 31913 Progressive Direct Drive...
Cord got into brush area. pulled cord and now rollers will not turn. Beltless drive Vacuum kenmore 3 years old 11635922500
Greetings,
Your Kenmore Beltless Drive upright model 116.35922500 has an overload protection system designed on it. This will prevent anything from damaging the brush motor, or your roller brush if you were to vacuum up something in it (i.e. your cord).
The reset switch can be found in this below diagram as item # 3. This would be the first thing I would try. Simply just push down on the red switch actuator while the vacuum is on, then recline the handle down. Did this fix it?
If this doesn't fix it, please let me know by requesting a clarification request, or by adding a comment to the repair here on Fixya. I think from how you explained it that this should fix your vacuum cleaner. I hope this helped you. If this was helpful, please be sure to rate the repair solution as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Thank you very much,
Chris Jones
GoVacuum
Mar 23, 2010 | Vacuums
The rotator brush stopped turning. it turns fine
The brush roll will only spin when your handle is not in the locked upright position, once the handle goes upright - the brushroll de-activates
Dec 22, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore Beltless Vacuum brush will not spin. Everything else works.
there is a reset button on the side of the lower base of the machine, plug in the unit turn on the switch to the brush and vacuum are both engaged hit the reset button, remember the roller will not engage when the handle is in the upright position, release the handle and your ready to go.let me know if that helped you . thanks renevacdoc
Jul 23, 2009 | Vacuums
Vacuum roller stops turning
with cleaner plugged in and turned on, push the little reset button on the side of the lower base of vac. Remember that the brush will not turn in the upright position. release your handle and you should be in business. hope this helps. please let us know. thanks renevacdoc
Jul 22, 2009 | Kenmore 31913 Progressive Direct Drive...
Beaters stop when vaccuming rug...didn't when new
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jim
Jun 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a kenmore beltless upright the beater brush dosetn spin
If it is direct drive then the motor or the wireing to the motor are bad. If it is gear driven then the gears are probally stripped.
Apr 11, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
No suction
Are you saying that the motor runs but there is no brush rotation ?
If yes then firstly switch machine on then when you pull handle back as if to vacuum the carpet the clutch drive dial must turn to (drive, start, on,) position if it is stuck on (park, off. Stop, p,) position rotate it to drive etc as you pull handle back providing the clutch & both drive belts are ok the brush will spin.
The clutch drive dial knob is situated looking from the front of machine lower left hand side approx 50mm or 2” in diameter.
Please do this test & let me know results
Regards Chris..
Sep 28, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Non spinning brush
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=632342
Generic problem for all Vacuums
Non spinning brush
Posted by tillie14 on May 29, 2008
I have a Kenmore upright beltless that suddenly, the brush stopped spinning. Do you have an answer for this?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. On the Kenmore upright the belt is broken and needs replacing and you can take it to Sears / Kenmore or a local vac dealer and they can change it for you or you can attempt to do it yourself, usually it just takes a screwdriver and either a flat or a geared belt for less than $10.00 to $15.00 is an estimate.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Vacuums
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
176 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
