Question about Lexmark X6150 All-In-One InkJet Printer
I want to Scan a page on Lexmark X6150. Please guide me how to set the Options and Select buttons. I pressed the start button after pressing the scan button. It does do anything.
  • 823 Answers
Find the "menu" button on your printers keypad and push it. Use the up and down areas on the printers keypad to advance from choice to choice. Find the option that says something similar to "scan settings" . Push the "ok" button or the "enter" button on your printers keypad to open this option. Continue scrolling with the up and down arrows and using the ok or enter keys on your printer and locate the "scan to" choices. Set up your software choice for scanning text documents and pictures. Most people want to open and edit text documents in software like "Microsoft Office" in your computer. Choose a photo editing software installed in your computer to send pictures scanned on your printer to. When these settings are set and saved, turn on both the computer and printer and try scanning from printer to computer again to check and see if the problem is solved. If you experience any other issues, pleas clarify what they are and I will try and help you solve this right now before I leave for work.
Posted on Sep 27, 2010
I have an x6150 and it had been working fine. I ran out of ink and replaced the cartridge not too long ago. I printed a few items (not much) and all of a sudden when I hit print, it acts like it is...
Print quality issues could be due to clogged or dirty print cartridge nozzles. Try the steps below to improve print quality on your Lexmark X6150 printer:
  1. Load paper in the All-In-One.
  2. On the printer operator panel, press Copy.
  3. Press Options until Maintenance appears on the display.
  4. Press the right arrow until Clean Cartridges appears on the display.
  5. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  6. Print your document again to verify that your print quality has improved.
You may also try to insert a different known working cartridge to determine if it's not a cartridge issue.
Aug 16, 2011 | Lexmark X6150 All-In-One InkJet Printer
X6150 printer worked fine until I was running out of ink. So replaced both 82 and 83 cartridges (new). Then got online help with 50C error message; moistened gold area on both surfaces of cartridges and...
Try to do the Clean Cartridge function using the control panel on your printer. 1. Press Copy. 2. Press Options until Maintenance appears on the display. 3. Press the right arrow until Clean Cartridges appears on the display. 4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles. 5. Print your document again to verify that your print quality has improved.
If problem continues and it's beyond return period, please contact Lexmark technical support for additional assistance.
Source: Lexmark X6100 Series User's Guide
May 17, 2011 | Lexmark X6150 All-In-One InkJet Printer
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
My Lexmark P4350 printer is not scanning images to my computer?
To scan a document, please follow the steps given below:
1. Go to "Start," "All Programs," Lexmark 4300 Series, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
May 11, 2009 | Lexmark P4350 All-In-One InkJet Printer
Default printer factory settings Lexmark X8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Apr 27, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
LEXMARK X4270 SCAN ONE PAGE NOT MULTI-PAGES
S:
1. Press "Copy" button.
2. Press "Options" till the display reads "Set Defaults."
3. Use the "Arrow (right/left)" buttons till the display reads "Use Factory."
4. Press "Select."
Also, let me know the error message while scanning the document.
Apr 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
I am unable to send faxes or recieve faxes
Please follow the steps given below to check wheather the error correction is turned off.
You need to disable "Error Correction," please follow the steps given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
7. Press "Select."
Please follow the steps given below to recieve the fax:
1. From the control panel, press "Fax Mode."
2. Press the "Menu" button once.
3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
6. Press left or right arrow to choose an option.
7. Press "Select."
If you want to set a schedule to turn "Auto Answer" "on" or "off:"
1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
2. Press left or right arrow until "On" appears.
3. Press "Select."
4. Press down arrow button to select the time for "Auto Answer On."
5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
6. Press down arrow button to select the time for "Auto Answer Off."
7. Repeat step 5.
8. Press "Return" button to save the settings and exit the menu.
9. Make sure the "Fax Auto Answer" light is on.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
Mar 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Won't scan legal documents properly
Make sure that you set the paper size in the setup menu for legal - 8.5 x 14 for the manual paper feed.
Jul 01, 2008 | Samsung CLX 3160fn All-In-One Printer
Hi, Remote Fax Error being displayed
As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX mode.
Press Select.
Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
Change the setting from Yes to No using the + (right arrow) button.
Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX.
Press Select.
Press Options 10 times until MAX SEND SPEED appears on the LCD display.
Change it to 9600 BPS using the - (left arrow) button.
Press Select.
Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
Press Select.
Press Options 11 times until ERROR CORRECTION appears on the LCD display.
Change the setting from On to Off using the + (right arrow) button.
Press Select.
Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes. The X6100 Series only supports 1-D MH encoding with the error correction. Fax transmissions without ECM and other ECM types can result in bad quality on the received page.
Dec 19, 2007 | Lexmark X5470 All-In-One InkJet Printer
NOTE this option may vary to printer try USING OPTIONS TO SET CHANGES
To resolve the problem, try the steps below. After each step, try to send a fax again.
1. As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
* Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
2. Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
3. Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
1. Press the Fax button, then press Options untill u see ADVANCED FAX mode.
2. Press Select.
3. Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
4. Change the setting from Yes to No using the + (right arrow) button.
5. Press Select.
4. Lower the fax transmission speed 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
1. Press the Fax button, then press Options untill u see ADVANCED FAX.
2. Press Select.
3. Press Options untill u see until MAX SEND SPEED appears on the LCD display.
4. Change it to 9600 BPS using the - (left arrow) button.
5. Press Select.
5. Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
1. Press the Fax button, then press untill u see to get to ADVANCED FAX.
2. Press Select.
3. Press untill u see ERROR CORRECTION appears on the LCD display.
4. Change the setting from On to Off using the + (right arrow) button.
5. Press Select.
Nov 16, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X6150 All-In-One InkJet Printer Logo
82 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
