Question about Bosch Axxis WTA 3510 Electric Dryer
I have a Bosch Axxis WTA 3510 dryer. The dryers heating coil stopped working. While looking on line I was able to fix the problem by using the reset button at the top of the heating coil housing. The dryer seems to work fine now. I hope to find out what made the button "trip" to where it needed to be reset. Does something need replacing? I don't want to pull the rear cover and reset the button all the time.
  • 205 Answers
Hello- The first thing to check, if you haven't already, is how well the dryer is venting. Make sure there are the flexible duct from the dryer to the wall is not crushed or crimped in any way. As well, with the dryer running, go outside and locate where the dryer exits the wall and feel how much air is coming out. Is should be blowing strong out of the vent. If not, and if the ducting travels a long distance through the walls you may want to have a duct cleaning service out. If there is a lot of lint build-up in the vent then the dryer will have trouble evacuating the hot air and the unit can overheat causing the thermostat to trip. If all your venting is ok but the thermostat is still tripping then replace the thermostat. Hope this helps, best regards.
Posted on Sep 27, 2010
Heating stop working. drying without heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 23, 2010 | Bosch Axxis WTA 3510 Electric Dryer
THE DRYER WILL NOT HEAT UP
Needs new heating element can do yourself but is a pain I would call someone not very expensive to have fixed
Nov 19, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Bosch AXXIS dryer # WTA 3510 uc slipping / grinding sound when drum reverses direction. Difficult to turn drum by hand. Belt or motor?
drum baring or rollers if you can get belt off try to turn drum if it still hard to turn you will know its not the motor may be something in blower give it a try
Sep 30, 2010 | Bosch Axxis WTA 3510 Electric Dryer
The dryer runs but does not heat up
Depending on your heat source (gas or electric), your problem could be one of the following:
* if electric: heat element, thermostat or timer
* if gas: gas coils, radiant sensor, thermostat or timer
Note: In either case, check to ensure that the dryer is receiving the proper amount of electricity (110 volts for gas & 208-220 volts for electricity).
Feb 19, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer. I changed the fuse but it won't turn. Could it be the motor because I don't hear any sound?
there is a switch next to the belt tension arm behind the motor that needs to be reset push the switch needs to be pushed to the right andthis should get your unit running as long as you have power
Sep 16, 2009 | Bosch Axxis WTA 3510 Electric Dryer
No heat in my Bosch dryer. everything else works
If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Hope this helped and best wishes.
Sep 09, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Service Manual
Based likewise on your Premium Problem/Post here, I tried looking for a service manual but only found a possible source of the wiring diagram, have you tried here. Unfortunately, you need to be a paid member to access the files to my understanding.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 25, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Dryer misfunction
Check the fuse. This is a German unit, so every part including the light bulb is 208/240 volts. If the fuse for the dryer on the back is open the unit will not start.
Nov 18, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
216 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
