Question about Samsung SyncMaster 173P 17" LCD Monitor
Monitor keeps shutting down computer, I have tried it on two computers and the same result, what does this mean
  • Samsung Master
  • 17,130 Answers
There is an error voltage on the monitor connection- VGA port- is coming on to cut off the PC .This stray short in the monitor circuit is returning back to the VGA port of the PC andshutting it off.
hence do not connect it further until the fault is solved, it can be the interface section of the monitor.
Posted on Sep 27, 2010
Since new monitor, computer shuts down dislpys
try adjusting your herz default is 60hz most of the time
Have you tried a old display again and worked?
mabe just bad Monitor try on dif computer see if you have the same results.
another thing would to be update the driver for the video card mabe compat. issue with older card newr monitor
Dec 21, 2009 | Cars & Trucks
Screen comes on says Acer then No Signal, and goes out. if shut power off and then back on get same result.
This means the monitor believes it's not connected to the computer. Verify the cables first of all. Then try booting in safe mode (F8 key at PC startup) in order to verify that the PC is sending data to the proper video port (you might have a dual VGA / Digital output, for example, and the monitor might be connected to the wrong PC port). Quite often, a "bad signal" will be the same of "no signal"; and you can have a bad signal if the monitor resolution on the PC is set too high. This could happen if you installed a high-resolution capable monitor, and then replaced it with a not-completely-plug-and-play, lower resolution one. The PC would keep sending hi-res signals to a monitor which can neither interpret them, nor tell the PC "please slow down". To check this last possibility, reboot your computer while the monitor is ON. When PCs reboot, they usually drop back to standard VGA signaling, which all monitors understand. If the monitor abruptly comes to life and displays a boot screen, then goes No Signal again after several seconds, you've got a resolution issue; get in Safe Mode with F8 key at boot, and modify the screen properties (right-mouse button on the desktop, then Properties).
If everything else fails, try also connecting the monitor to another PC or laptop, to see if it works there.
Dec 04, 2009 | Acer AL2223W 22" LCD Monitor
My DELL LCD monitor keeps flashing after the computer shuts down
Try to set the monitor in the factory setting this will discharge the monitor and restore it in the factory settings.
Nov 23, 2009 | Dell E173FP 17" LCD Monitor
Screen seems to be not working properly
try using a different monitor, borrow one if you have to, if the monitor works on your computer, then it simply means you need a new monitor. As far as the computer shutting down, it may be recording the bad monitor as an error in the loading process and automatically shutting down.
Mar 15, 2009 | HP TouchSmart IQ770 PC Desktop
LCD Shuts down
The monitor screen may be OK, but the monitor electronics are not. YOu state that the comuter works fine with a different monitor. That leaves out the video card. If you reall ywant confirmation of a bad  monitor, Try it on another computer ansdI am willing to bet that it  will again shut off.  Take it to a shop for repair or replace it.
Feb 01, 2009 | X2Gen MG19MY 19" LCD Monitor
OSD Main Menu
because of moiture pushbutton switch were conduct there for replace pushbutton switch and see result
Aug 15, 2008 | HP Pavilion F1703 17" LCD Monitor
Monitor will not come on after power failure
most probably your monitor broke down during the power failure due to current surge!
May 31, 2008 | LG Flatron L1710S 17" LCD Monitor
Fujitsu-Siemens Monitor problem
usually shut down when idle(idle means no key or mouse activity).........left click mouse in any space on desktop,select properties,in properties window select screensaver and lower in the screen youll see power settings..select it...in power schemes change time best suited or select never.
Feb 24, 2008 | Computers & Internet
Monitor not powering down
Do you mean the computer is sutting down but on the monitor showes different colors if so you might have a problem in the system you might have to reinstall you OS if the computer does shut down but the monitor stays on and flashes different colors you have to shut the monitor down manually with the power button on the monitor.
Feb 14, 2008 | Dell Dimension 3000 PC Desktop
Gateway lcd monitor
First, narrow down the problem to either the monitor, or to the computer itself. Either try the monitor on a spare or friend's computer, or try a known working monitor on your computer. I'd guess your computer is where the issue is at- it isn't booting the Operating System (MS XP or whatever O/S is present on the hard disk. if the computer is the issue, try booting from the CD which came with the computer, (assuming you have that CD). Or, you could see if some computer tech savvy person has a bootable floppy diskette. Basically a "no-boot" problem, can point to a number of problems: hardware issue (bad hard drive etc.), or an operating system problem.
Jul 10, 2007 | Gateway FPD1810 18.1" LCD Monitor
Samsung SyncMaster 173P 17" LCD Monitor Logo
109 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
