Question about HP PhotoSmart 1115 InkJet Printer
No power, dead completly..does it have a fuse or anything that I can reset?
  • carc49 Sep 27, 2010
    Definitely it is the right cord and this printer was working properly. The only thing is that I stopped using it and when I came back today to use it, I noticed there was no power at all. I have no kids and I'm the only one using it so the printer looks brand new and never was moved from the original place since I bought it.
  • 823 Answers
Not that I know of. Are you sure that the power cable you are using is the right one for the printer? Just because it fits the connection on the printer does not always mean its the right cord.
Check the power ratings on the back of the printer and compare them with the ones listed on the cord. Do they match? If so, does the cord fit the back of the printer snugly without wiggle room?
Have you tried other outlets to make sure there is no issue with the one your using now?
The power supply in HP printers usually lasts a lifetime. I doubt that this could be your problem.
When this has happened to me in the past, the problem has always been the power cord I was trying to use. Some power cords have fuses in them that can be bad. Is your cord a two piece with a box? Or a single piece cord? If its a single piece cord, I would question that it is the right one meant for the unit?
If its a two piece cord, make sure the voltage is right for the machine and follow the cord from end to end to make sure there are no other issues causing a power connection problem. Plug it into the printer and see if there is "play" when connected to make sure that it has not been stretched out and fits where it is supposed to go correctly.
If its the right cord and the connection is snug ect., and it still does not power on I would suspect that the power cord itself has gone bad for one reason or another. There was a type of cord that was issued with certain models of HP printers that was recalled due to malfunctions causing over heating a few years ago. I have not heard of any current issues, but you never know. Try replacing the cord and see if the unit powers up. If it does not then it will be a first and the issue your having is out of my expertise. (I am in my last year of school for my bachelors degree in Computer networking and have about 10 years experience in this field. This should help you gauge my advice)
Posted on Sep 27, 2010
Car will not start, has not power
Have you tried asking someone for a jump, Maybe just a flat battery, otherwise you need to check the main ignition fuses in the engine bay fuse box. Does anything work? interior lights, headlights. Jon.
Dec 15, 2013 | 2006 Cadillac CTS
Roland ac 60 sudden loss of power. Is it the fuse?
If you mean it's completely dead, no lights or anything, then probably the fuse is blown. The question then becomes"what caused the fuse tio blow?".
If however, by loss of power you mean it's quiter but still producing sound, then the fuse is not blown.
Sep 08, 2013 | Roland Ac60 Acoustic Chorus Guitar...
Dead Dirt Devil Featherlite
1. Power cord not firmly plugged into
outlet.
1. Plug unit in firmly.
2. Blown fuse or tripped breaker. 2. Check fuse or breaker in home. Replace fuse/
reset breaker.
3. Needs service. 3. Take to service center or call 1-800-321-1134.
4. Thermal Protector activated.
4. Unplug cleaner. Allow to cool for 30 minutes
Nov 03, 2012 | Dirt Devil Featherlite Bagless Vacuum...
Wired outlet incorrectly and breaker tripped. dryer will not come on. there is power in the outlet. no beeps or anything, completely dead. model number gleq2152es
hello if it striped the breaker theres a dead short somewhere in the dryer something on the power supply board could have shorted to ground check the glass fuse on the power board of the dryer if blown make sure you use the same rated fuse also check the capaitor next to the motor these can go short circuit hope it helps
regards
shaun
Jan 04, 2011 | Frigidaire GLEQ2152ES Electric Dryer
My typewriter is completely dead. I plugged anoth...
If this is a WW1500 the power supply is self resetting, It probably needs a power supply or a function board. First look on and under the PC board for debris and hope if there is some that there wasn't any damage. If you send it to us I'm sure we can fix it for under 200.00.
DickyO
Cleveland Business Machines
216-241-0027
May 19, 2010 | Lexmark Wheelwriter 1500 Typewriter
No power
there are six screws in the base and two in the back of the unit. After taking off the top I saw a red button on the front that was a little pushed out - I pushed it in and I got the led lights back :)
Jun 22, 2009 | Sharp XR-10X Multimedia Projector
Sharp R1420B Totally dead. Power to unit is ok.
Most of these have internal line fuses inside of the casing. Once you remove the housing that covers the top and sides, follow the wires from the cord and they should lead you to the fuse. They are usually on the front rh side looking at it from the front. Be careful, even though unplugged, this unit still stores alot of electriacal energy in the capacitor.
Oct 26, 2008 | Microwave Ovens
Problem
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Mar 06, 2008 | Sony SLV-D360P DVD Player/VCR
CS- 40503 No Power
There is no external reset, and if the set is completely dead (not even a click when the power button is pressed) then there is probably an open main fuse or defective stand-by power supply. If the main fuse is blown then there is usually a heavy short in the main power supply, and either way the set should be looked at by someone with experience in Mitsubishi sets.
Jul 04, 2007 | Mitsubishi CS-40503 TV
HP PhotoSmart 1115 InkJet Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
