Question about Vivitar ViviCam 5355 Digital Camera
When I insert batteries to use camera and I switch it on it switches of again
  • 3 Answers
Remove the memory card if you are using then try, if it works without the card then your memory card is defective and it has virus.. if it doesnt then camera has the problem. you need to check with local tech :)
Posted on Nov 06, 2010
Err99 when taking pics in sun. Taking in side with flash fine, pics outside at night are fine?
Error code 99 indicates detection of a system malfunction. Try switching on the camera and while it is still switched on remove the battery. Leave it for about 30 secs then re-insert the battery once powered up switch the camera off wait 30 secs then switch it on again. This action sometimes will remedy this problem but failing that it may need a visit to the repair shop.
Sep 20, 2014 | Canon EOS-20D Digital Camera
Mi camera digital Nikon D 60 got a messaje: ERROR PRESS SHUTTER RELEASE BUTTON AGAIN Cant anyvary help me to fix it
It is nothing to lose to try this:
1. Remove the battery (the charged and good working battery),
2. Switch the power to ON position,
3. Press the shutter button for 5 seconds.
4. Switch the power to OFF position,
5. Insert the battery,
6. Switch the power to ON position,
7. Try to take a picture.
Please post the result here.
Mar 03, 2014 | Cameras
Will not switch on with new batteries
I wonder what batteries you use? The best would be two AA rechargeable NiMH batteries. But a new CR-V3 lithium battery should work also.
When you have rechargeable batteries, you should check if they are charged. And when inserting, check if you did out them in correct. Only the CR-V3 is protected for inserting it wrong. when you have two batteries, you can put them in the wrong way. Then, if you did not use the camera for a long time, please make sure all contacts in the battery compartment are clean and shiny. If not, try to clean them, with a clean cloth. Never use anything sharp in or close to a camera. Contacts, could be rubbed with a little electronic contact oil, but the oil must be removed afterwards. As strange as it may sound, even the contact oil can be cause of oxidation on contacts.
When the batteries are in, make sure the battery door is correctly closed.
If you checked everything and you are sure the batteries are in correct, just try switching on and of several times, by opening and closing the lens barrier. Also while the lens barrios is closed, press the play back button on the back side of the camera. If both don't work, then again the batteries are under suspicion.
Feb 14, 2014 | Olympus Camedia C-150 Digital Camera
Unable turn on canon 60D i was reviewing the photo
Remove the battery and memory card, switch the power switch on for a few seconds and then switch it off. Make sure the battery is fully charged, re-insert the battery and try to switch on again without the memory card in.
Oct 24, 2013 | Canon EOS 60D Digital Camera
My camera turns on and I can only switch from the camera to play and back again none of the buttons work what so ever and I can not take a picture, and when I switch from camera to the play button it is...
If you could get into the menu, I would tell you to try a camera "reset". Since you can't, you could try a manual reset. Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Nov 30, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Eos 40d error 99
Error 99 can mean many things. Have you installed the latest firmware for the camera (version 1.1.1)? If you don't have, download it here (for equipment purchased in USA or Puerto Rico):
http://web.canon.jp/imaging/eosd/eos40d/eos40d-firmware-e.html
If you have the latest firmware, try this:
  1. Switch off the camera and remove the CF card and battery
  2. Keep the camera idle for 30 min
  3. Clean all the contacts of the camera (battery contacts, lens contacts etc) with an eraser. Do this keeping the camera facing down so that no debris fall into the camera.
  4. Attach the lens and insert the battery.
  5. Switch on the camera
  6. Insert the CF card
  7. If the error persists, format the card again
  8. If this does not work, try using another CF card.
Feb 06, 2009 | Canon EOS 40D Digital Camera
Nothing happens when I use the camera buttons and switches.
There could be 2 reasons for that: 1. Camera malfunction - Remove the battery or AC adapter once and retry. 2. The Mode dial has been moved to another setting - Remove the battery, re-insert them and try again.
Sep 15, 2005 | Toshiba PDR-M3 Digital Camera
Vivitar ViviCam 5355 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
