Maintenance of a hp deskjet 3650 printer
I want to do the maintenance on this printer`It Printage is not clear and it prints not as fast as usual, and I have no manual to indicate me which adjustment I have to change
    Sergeant:
    Champion:
  • 347 Answers
Hi fern
Here you will find a link to your product.
You can find the user manual,view the FAQs of that product or contact HP service if you feel you need to.
http://search.hp.com/query.html?charset=iso-8859-1&lk=1&la=en&nh=10&st=1&rf=0&qs=&hpvc=sitewide&uf=1&qt=HP+Deskjet+3650+Color+Inkjet+Printer&ocoldqt=3650+printer&oc=304536
Posted on May 23, 2008
  • 6 more comments
  • Santiago Vallejo
    Santiago Vallejo May 31, 2008
    Haha, sounds so technical...
    http://h10025.www1.hp.com/ewfrf/wc/docum...
  • Santiago Vallejo
  • Santiago Vallejo
    haha, sounds so prossesional..
  • Santiago Vallejo
  • Santiago Vallejo
  • Santiago Vallejo
  • Santiago Vallejo
  • Santiago Vallejo
    Genius:
  • 3,422 Answers
Please CLICK HERE to view the user manual.
If you need anymore help then let me know.You can post a comment over here.
  • 3 more comments
  • Priya darshan May 23, 2008
    Please Follow the below steps to troubleshoot slow printing in XP:
    1. Press the Power button (
      ) to turn the product on.
    2. Press and hold the Resume button (
    3. When the product starts printing, release the Resume button (
    Solution two: Check the power supply
    1. Unplug the power cord from the back of the product.
    2. Remove any devices in between the product and the power outlet, such as surge suppressors or power strips.
    3. Plug the power cord directly into a wall outlet.
    4. Repeat the steps in Solution one to determine if the issue is related to the power supply.
      • If the page prints in
        less than or close to 30 seconds
        , the problem is related to the power supply. Replace devices in
        between the product and the power outlet, or leave the product
        connected directly to the wall outlet.
      • If the page takes
        significantly longer than 30 seconds
        , continue to the next step.
    Solution three: Check the print cartridges
    1. Turn the product on and open the cover to view the print cartridges.
    2. To make sure the cartridges are compatible with the product,
      click here to review the cartridge compatibility chart for your product
      (bpa00585) (in English).
      If the print cartridges are not compatible, or are refilled or remanufactured, replace them with genuine HP cartridges.
    Solution four: Perform a hard reset
    Follow these steps to reset the product.
    1. Turn the power off.
    2. Unplug the power cord and the data cable from the product.
    3. Unplug the power cord from the wall outlet.
    4. Reconnect the power cord to the product and wall outlet, and then turn the power on.
    5. Print a sample page again and check the print speed.
    If the page takes
    Solution five: Clean the electrical contacts on the print cartridges and the print carriage
    1. Gather the following materials:
      • Distilled water (tap water can contain contaminants that can damage the print
        cartridge)
      • Cotton swabs or other soft, lint-free material that will not stick to the electrical contacts
      • Clean sheet of paper
    2. Open the cover on the product.
    3. Wait until the print carriage moves to the center of the product and is
      idle and silent.
    4. Press
      down lightly on the end of the print cartridge to release it, and then
      slide the print cartridge out to remove it. Repeat this step for each
      print cartridge.
    5. Place the print cartridges on a sheet of paper with the copper strips
      facing up.
      CAUTION:
      Do not leave the print cartridges out of the product for more
      than 30 minutes.
    6. Lightly moisten a cotton swab with distilled water and squeeze any excess water from
      the swab.
    7. Gently wipe the print cartridge copper contacts with the cotton swab.
      Figure 1: Ink nozzles and copper contacts on the print cartridge
    1. - Ink nozzles (do not touch)
      2 - Copper contacts
      CAUTION:
      Do not touch the ink nozzles. Doing so results in clogs, ink failure, and bad electrical connections.
    2. Repeat this process until no ink residue or debris appears on the swab.
    3. Unplug the power cord from the product.
    4. Clean the contacts in the print carriage inside the product.
      Figure 2: Electrical contacts inside the product
    1. Either let the contacts sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
    2. Slide
      the print cartridge into the product at a slight upward angle until you
      hear a snap indicating the cartridge is positioned correctly.
    3. Close the cover and plug the power cord back into the product.
    4. Print a sample page again.
    If the page takes
    Solution six: Make sure the correct driver is installed
    The
    driver for your product might need to be updated or reinstalled. The
    automated tool on the HP Web site checks whether the driver for the
    product connected to your computer needs an update. It also makes sure
    that the product is set up correctly. If the product is not set up
    correctly, the tool automatically fixes some issues. The tool also
    updates, uninstalls, or reinstalls the driver if necessary.
    Solution seven: Adjust the print settings
    Print settings can affect print speed. Follow these steps to check the settings for paper type and print quality.
    1. Open the
      Printers
      folder.
      • Windows 2000: Click
        Start
        , point to
        Settings
        , and then click
        Printers
      • Windows XP: Click
        Start
        , click
        Control Panel
        , and then click
        Printers and Faxes
      The
      Printers
      window opens.
    2. Right-click the icon for the product, and then click
      Printing Preferences
    3. Click the
      Paper/Quality
      tab.
    4. In the
      Paper Type
      section, open the menu and click
      Plain Paper
    5. In the
      Print Quality
      section, click
      Normal
    6. Click the
      Services
      tab.
    7. Click
      Service this device
    8. On the
      Device services
      tab, click
      Print a test page
      , and time how long it takes to print.
    If the test page takes significantly longer than 30 seconds, continue to the next step.
    Solution eight: Make sure the computer meets RAM requirements
    The
    amount of available random-access memory (RAM) can affect print speed.
    Follow these steps to make sure the available RAM meets the minimum
    requirement for the product.
    1. Access system information, and note the amount of available RAM.
      • Windows 2000: Right-click
        My Computer
        , and then click
        Properties
      • Windows XP: Click
        Start
        , right-click
        My Computer
        , and then click
        Properties
      The
      Properties
      window opens.
    2. Click the
      General
      tab. The amount of RAM is listed in the
      Computer
      section.
    3. Refer
      to the system requirements for your product, listed in the product
      manual and on the box, to make sure your computer has enough available
      space.
      If the computer meets the requirements, continue to the next step.
    Solution nine: Close all unnecessary software applications
    Running
    several software programs at the same time can slow system performance.
    Closing the programs makes these memory resources available for other
    tasks. Use one of the following methods to close any unnecessary
    software programs.
    Method one: Close programs using the Windows taskbar
    If any programs or icons are showing on the taskbar, right-click the button or icon, and then click
    Exit
    or
    Close
    Method two: Close programs using the Task Manager
    1. While holding down the
      Ctrl
      and
      Alt
      keys on the keyboard, press the
      Delete
      key.
      The
      Windows Task Manager
      should open with a list of all running programs. If
      does not open, click the
      Task Manager
      button.
    2. Select a software program from the
      Applications
      tab and click
      End Task
      to close the program.
    3. Continue closing all open programs.
    Try printing again. If printing is still slow, continue to the next step.
    Solution ten: End any unnecessary background programs and processes
    Programs
    and processes run in the background even when no applications are
    visibly running. Follow these steps to end unnecessary processes and
    programs.
      Ctrl
      and
      Alt
      Delete
      key.
      The
      Task Manager
      button.
    2. Click the
      Processes
      tab.
    3. Select the process you want to close and click
      End Process
    4. If another window appears indicating that the program has stopped responding, click
      End Task
    5. Continue ending processes.
      NOTE:
      You will not be able to end critical system processes.
    6. Try printing again.
    Slow printing is usually caused by the following software or hardware problems:
    • An ink cartridge needs to be replaced with a new HP cartridge.
    • The cartridge contacts need to be cleaned.
    • The product needs to be reset.
    • The print driver needs to be updated or reinstalled.
    • The settings for print quality and paper type need to be adjusted.
    • The computer does not meet the minimum system requirements for the product.
    • Unnecessary software applications need to be closed to increase RAM.
    • Unnecessary background programs and processes need to be closed to increase RAM.
    I hope i've given you all the details for your problem..
    Goodluck..
My HP Deskjet F4488 printer's cartridge is not working . It slides only
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
Sep 15, 2012 | HP DeskJet Office Equipment & Supplies
My Hp deskjet F4235 is not printing very good. I can barely read what it prints out. My printer is telling me that the ink is full.
You may need to run the maintenance processes such as head cleaning and alignment. It should be one of the tabs under the printer properties. Right click on the printer, choose printer properties, Maintenance. It depends from printer to printer. The alignment most likely is the culprit.
Jun 30, 2011 | HP Deskjet F4235 AllInOne InkJet Printer
New color ink won't work
klick star, printer, hp printer, printing preferences, features, printer services
Feb 26, 2011 | HP Deskjet F2210 InkJet Printer
Intern page counter for hp deskjet 3650
Turn the printer on, Press and hold down the POWER button while holding down the power button Open and close the top cover four times and then release the POWER button
It will print a page and in that page just look for Line Number 21 which will say like - PX = XXX
XXX is the number of pages this printer has printed till date
Oct 16, 2009 | HP DeskJet 3650 InkJet Printer
Can i install hp deskjet 3600 software for hp printer hp deskjet 3650?
No, you have to install the exact software for HP Deskjet 3650 Printer model. HP Deskjet 3600 Printer model software doesn't support for HP Deskjet 3650 Printer model
For technical support call us toll free 1-888-249-8496 or visit 123 hp com Quick HP Printers Setup Easy Installation Guidelines
Oct 08, 2009 | HP DeskJet 3650 InkJet Printer
My hp deskjet 3650 printer can no longer print for me
reinstall the printer... delete it out of printers and faxes and then load it fresh
Nov 21, 2008 | HP DeskJet 3650 InkJet Printer
Hp deskjet 3650
Before printing a dialog box appears.
1. Click properties adjacent to the printer select drop down menu box/
2. Select Text and Image from the choices.
Your printer can now print both text document and photos.
Oct 18, 2008 | HP DeskJet 3650 InkJet Printer
Printer deskjet 3650
change your cartridge.
but i think your printer got more problems.
Mar 27, 2008 | HP DeskJet 3650 InkJet Printer
124 people viewed this question
k24674
jasbo
jasbo
