Accumulated dirt on the fan blades - Heating & Cooling
    President:
  • 1,515 Answers
Hi, I am not sure what kind of system you have but I can help you and tell you why this happens. This is the blower motor, and you also have a return air side on the front of the unit. The air is pulled back through the motor, that the filter doesn't catch, and collects on the blades. This takes place over time. If this is a window or wall unit, you may be able to turn off power and reach in with a brush of some kind to break loose this dirt. What happens over time is the dirt will collect on the windings of the motor causing it to overheat, so you want to clean this the best that you can. Even if you had a small air compressor it would be hard to get the dirt off the blades, but would be good to blow out the loose dirt. If this is a central air unit, you can remove 2 screws in front and slide the assembly out and clean the blades this way. So, find a way that is easy for you and clean as best as you can. Be sure you change your air filter on a regular basis. Please don't forget to rate me on this as I know you will be kind. Please keep me posted if you need my help.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Posted on Sep 27, 2010
The cooling fan is on
Usually the fan stays on because your PC is overheating! First try and see your PC has at least 5 cm (2 in) space all round.
2. Dust
You computer fan may have accumulated a lot of dust, which causes the fan to run continuously. Purchase compressed air spray and spray the computer fan to loosen up any dust that may have accumulated. Most computer fans are exposed, so accessing the fan should not be a challenge. Brush the blades with a soft artists brush if the dirt is still on, but GENTLY
3. Technical issues
In some cases, your computer may have either a defective fan or thermostat. Some Computer providers allow you to purchase a new fan and replace it yourself. For thermostat issues, you may have to contact a computer repair professional for assistance.
4. Computer is overworked
Depending on the age of your computer multiple programs that are running can cause it to overheat. Watching a lot of DVDs, playing video games, and listening to music on your computer also can cause overheating. Considering closing some of your programs and rebooting your computer.
May 03, 2014 | Acer Aspire 5600U all-in-one desktop
Laptop fan making noise
You need to clean the fan blades to stop it. Due to blades getting covered by dirt your fan cannot throw out the heat. thus it runs more fast and makes noise. also the heat sink gets covered by dirt unable to radiate heat . thus your laptop gets heated fast. clean those dirt and the problem will be solved. thanks.
Feb 19, 2012 | MSI EX620-1W1US (9S7-167414-1W1) PC...
Side by side doors overheating and also the center panel
Check your coil under the fridge to see if dirt is clogging the coil. Also see if the fan is running down there. If so check to se if any dirt on fan blade. Belive it or not if the fan blade has even a small amount of dirt on it it can cause it not to work. I hope this helps.
Aug 23, 2011 | Refrigerators
I am getting a loud noise from the freezer compartment of my older, Kenmore refrigerator.
The noise may be a failing evaporator fan, but it's more likely to be ice that has accumulated around the fan and the fan blades are hitting it.
You will need to access the fan behind the cover in the freezer to check this out. The unit should be off so the blades aren't moving when you check.
Mar 19, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Fan blade is not rotating but there is noise
The rotor is stuck and the fan blade will not rotate then a humming noise can be heard. It is due to a bushing problem. It may be stuck due to a hardened accumulated dirt.
  1. Remove the fan blade guard.
  2. Remove the fan blade.
  3. Remove the 4 screws holding the stator assembly.
  4. Pull out the front plate of the motor and the rotor.
  5. Clean the bushing and the rotor.
  6. Lubricate the busing and rotor assembly.
  7. Reassemble in reverse order.
Nov 27, 2009 | Lakewood 16" Stand Fan
Condenser fan is not running. coils are hot and the compressor sounds like its working. the evaporator fan is working. The refrigerator is not as cold as it should be
Spin the fan by hand and see if that helps. The condensor fan is causing head pressure to rise and the compressor is fighting it. This in turn will affect the cooling effiviency.Vacuum the cobwebs and dirt that has accumulated and vacumm the fan motor yhrough the vent holes on its end opposit the blades. Spin the fan blades with a pencil to protect your fingers. If the fan still won't turn, it may need to be replaced Good Luck_Ned_
Nov 07, 2009 | GE GSL25JFR Brushed Steel Side by Side...
Hoover f5915
Since the Steam Vac does not have any belts... the logical issue is Switch setting (Hi, Low, Off) on the base cover. The only other is dirt collection on the air intake for the brushes (unit uses air passing over plastic fan blades to spin the brushes). To clear the dirt problem, remove the clear plastic cover located just in front of the brush Switch. You can now use your finger nail (or an old tooth brush) to clean the filter screen located just below the Switch. Don't tear it, just gently remove the accumulated dust/hair.
Brushes should spin once you reassemble and power it up!!
Aug 14, 2009 | Hoover F5906-900 Upright Steam Vacuum
My pc keeps on shutting down every 10 minutes or so
THE VIDEO DRIVERS ARE CORUPTED
WWW.DRIVERSHQ.COM
Mar 14, 2009 | HP Pavilion dv6000z Notebook
Toshiba Satellite Fan Control
Try unplugging your CPU and wiping any accumulated gunk which may have oxidized there, causing heat buildup. You have, of course, cleaned all the accumulated dust off your fan blades?
Apr 05, 2008 | Computers & Internet
Hitachi HDP J 52 Projector
These small fans are prone to failure; try to access the blades to see if they are being impeded by accumulated dust and also push gently on the blades, left then right, to see if there is any wobble of the shaft.
The fan probably has a sleeve bearing and these are prone to wear and also to stick.
Mar 16, 2008 | Hitachi PJTX100 Multimedia Projector
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
