Question about Texas Instruments TI-89 Calculator
Volume of a cylinder on it's side
I have a fuel tank which I can measure with a dipstick marked in cm. I would like to convert the dip to a volume in that tank. How do I make a chart showing the volume of the tank at any given cm dipped.?
The dimensions of the tank are 121 cm dia x 216 cm long.
Go to www.arachnoid.com and you will find a solution for this and many othe problems!
Posted on May 24, 2008
What is volume in litres of a bag 230mm dia x 450mm long?
You give only two values for the dimensions, so it must be a cylinder with a radius r=230/2 mm= 115 mm= 11.5 cm
and a height of h= 450 mm =45 cm
The volume for your right circular cylinder is V=PI*(r^2)*h=PI*(11.5^2)*45 cm^3=?
Divide the result by 1000 to convert the volume to liters (1 L =1000 mL=1000 cm^3)
Jul 03, 2014 | Office Equipment & Supplies
Fxdb oil level check
Hi Anonymous, the engine oil dipstick on later models unscrews, on earlier models it just pulls out with moderate force, on Softail and Sportster models the dipstick is located on the right hand front side of the oil tank and the Harley Bible says, engine should be at normal operating tempurature, let idle on jiffy stand for two minutes. Shut off engine and hold bike straight up and dipstick all the way in, correct engine oil level will be at the top full mark. Do not overfill oil tank as this will cause engine breathing issues. On Dyna and Touring models The engine oil dipsticks are located on the right front top corner of the transmission and the engine oil pan is underneath the transmission. The engine oil level is checked in the same manner as Softails and Sportsters. If you are having oil carryover or breathing issues (dipstick launch) try running oil level half way between the add and full marks, running the engine at this oil level will not harm normal operation. Good luck and have nice day.
Apr 21, 2012 | 2011 Harley Davidson FXDB Street Bob
Were is dip stick
Hi Anonymous, the engine oil dipstick on Softail and Sportster models is located on the right hand front side of the oil tank and the Harley Bible says, engine should be at normal operating tempurature, let idle on jiffy stand for two minutes. Shut off engine and hold bike straight up and dipstick all the way in, correct engine oil level will be at the top full mark. Do not overfill oil tank as this will cause engine breathing issues. On Dyna and Touring models The engine oil dipsticks are located on the right front top corner of the transmission and the engine oil pan is underneath the transmission. The engine oil level is checked in the same manner as Softails and Sportsters. If you are having oil carryover or breathing issues (dipstick launch) try running oil level half way between the add and full marks, running the engine at this oil level will not harm normal operation. Good luck
Apr 04, 2012 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
Where is the dip stick on a 2003 harley ultra
Hi Anonymous, the engine oil dipstick on Softail and Sportster models is located on the right hand front side of the oil tank and the Harley Bible says, engine should be at normal operating tempurature, let idle on jiffy stand for two minutes. Shut off engine and hold bike straight up and dipstick all the way in, correct engine oil level will be at the top full mark. Do not overfill oil tank as this will cause engine breathing issues. On Dyna and Touring models The engine oil dipsticks are located on the right front top corner of the transmission and the engine oil pan is underneath the transmission. The engine oil level is checked in the same manner as Softails and Sportsters. If you are having oil carryover or breathing issues (dipstick launch) try running oil level half way between the add and full marks, running the engine at this oil level will not harm normal operation. Good luck and have nice day.
Jan 21, 2012 | 2004 Harley Davidson FLHTCUI Electra Glide...
How do you convert cm/hr to ml/mn. The cm here is centimeter and not cubic centimeter. Is this possible?
1ml is equal to 1 cubic centimetre, a centimetre is a measurement of area whereas a mililitre is a measurement of volume, they aren't interchangeable.
cm^3/h to ml/mn simply requires the first figure to be divided by 60
May 04, 2011 | Office Equipment & Supplies
What is the oil capacity for a 1987 FLHTC Electra Glide Classic
I think it's three quarts but the tank has a dip stick on it. After draining the tank and changing the oil filter, pour three quarts into the tank. The dipstick has two marks on it. Check the level with the bike on the side stand. The upper mark is "FULL HOT" and the lower mark is "FULL COLD". Top the oil level off to the lower mark and recheck once you've ridden the bike.
Goodl Luck
Steve
Aug 15, 2010 | Harley Davidson FLHTC Electra Glide...
How many litres in volume 1170 x 450 x 190
A litre is the volume of a cube with sides of 10 cm. So for every 1000 cubic cm you have 1 L.
If your 1170 x 450 x 190 is cm, then volume would be 100,035,000 cubic cm which is 100,035 L. If it's some other unit of measurement, you should be able to convert.
If this answer helped, please vote.
Jun 13, 2010 | Measuring Tools & Sensors
How to check transmission fluid on my yz 250?
The tranny oil fill screw should be a black plug on the left side by the kick starter. Open it and there should be a dipstick, if not, stick a straight wood/metal (wire) ensure it's clean and dip into the hole, pull it out ensure not touching the wall or filer mouth, measure about 2.0-3.0 cm, if within height you are OK, else add some more oil to reach at least 2.5 cm height. OK, good?
Mar 30, 2010 | Yamaha YZ 250 Motorcycles
Texas Instruments TI-89 Calculator Logo
314 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
