Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
MYFI XM2GO WILL NOT TURN ON. ALSO WHEN I PUT IN CRADLE WILL NOT SHOW CHARGING
I had the same problem. This procedure from the "Technical Questions" section of http://shopdelphi.com/consumers/support/faqs/myfi/ worked for me:
"My MyFi won't power up, how do I reset it?
To reset your MyFi, start by turning the receiver off and removing it from its (car, home, audio system) cradle. Then remove the back cover and battery. Using a small paperclip, press the reset button located on the top left corner of the battery compartment. Now plug the AC power adapter into a wall outlet and plug the power port directly into the bottom of the MyFi (battery stays removed). Wait 10 seconds and listen for a beep. After you hear the beep the message "insert battery" will appear. Cycle the MyFi to ensure it powers up and powers down. If the power cycle is normal, then turn off the MyFi, unplug the power adapter, and reinstall the battery. Re-plug the AC power adapter directly into the bottom of the MyFi. Wait 10 seconds and listen for a beep. After the beep you will see the message "battery charging". Leave the MyFi plugged in until it's fully charged. You will see the message "charging complete" displayed. After the MyFi is fully charged, turn it on and reset to the factory defaults. Unplug the MyFi from the AC power adapter and using the battery power leave it on until it fully discharges (approximately 2-5 hours). Plug the MyFi in using the AC power adapter to recharge the unit and resume normal use. If you need help at any point during this process contact us at 1-877-463-3574 for technical support."
I hope it works for you too.
Posted on Sep 28, 2010
The radio will not turn on ,not manually and not with remote
power suplay Transformer dies...
Try to find another suitable transformer and try running it
Nov 24, 2013 | Delphi Myfi Xm2go Portable Satellite Radio...
My Tao xm2go quit working. I've tried re-setting it. I've replaced the battery, I double checked that the charger is putting out the correct voltage with a multi-meter. it won't turn on, either with the...
Try plugging the power adapter directly into the bottom of the radio without using either base/cradle - wait a minute - then see if you get a battery indication.
Jan 18, 2010 | Tao XM2go Satellite Radio Receiver
My mifi XM2go radio will not turn on. I have
Sounds like a bad battery. Try plugging DC adapter directly into the bottom of the unit and turn it on - does it still act-up? If so, bad radio; if it works with adapter only, then battery and charging issue.
Dec 20, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
My delphi myfi xm2go will not recharge. What do I
New battery - make sure it's WHITE and not a black one as the black ones were recalled.
Nov 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
My delphi xm2go radio unit will not take a charge. Have tryed everthing! It starts to charge then goes dead!
I had the same problem, Based suggestion that the plug in the Radio is worn and not making contact, I used a small screw driver to shift the pin in the charger input hole from the center a little. That did it on both my Myfi;s. The now charge properly, and stay on as long as I need. Which needless to say, brings a smile to my face :) .
Apr 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi myfi xm2go
Replace the battery. Your Myfi will not work without it -- even if it is plugged into the charger.
Mar 03, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
MYFI does not powerup
You may not be getting power through the base because of a bad physical connection between the base pins and the receiver, and it won't power up because it has no battery charge. Try plugging the AC power adapter directly into the bottom of the receiver (not through the cradle). Push the adapter plug toward the back of the receiver to see if the + sign on the battery on the top right of the screen shows that it is now receiving power and charging. Alternatively, with the receiver in the base, try pulling the top of the reciever toward you to tilt the receiver forward on the pins to see if it starts charging.
Sep 04, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi myfi xm2go
I have the same problem. I finally was able to get Delphi Tech Service and found out that these units have a flaw. they have been going out after about 14-18 months and there is no known repair... neither does Delphi offer a repair service for this problem.
Dec 17, 2007 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
468 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
