Question about Citizen 3550 Matrix Printer
Citizen iDp 3550 prints double-spaced
We have Citizen iDp 3550 printers here at work. They used to print single-spaced, but for some reason they print double-spaced now. I can't make sense of the manual I found online. We're wasting lots of paper for receipts! Anyone know how to fix this? Any help is much appreciated! =] I am having the same problem. I do not have access to make settings from the computer. I need to do any changes totally from the printer and I have not found the compination to getting the printer into a mode to do this. Does anyone have a solution. I am desperate. I need an answer so that I can get this reset before my snack bar opens tomorrow for the holiday weekend.
Thanks,
BD
Lubbock Country Club
2 Suggested Answers
SOURCE: Citizen iDp 3550 prints double-spaced
It is a dip switch setting, on dip switch #6, it needs to be "On" It will then single space the lines. After re-setting the switch under the cover, turn off the printer for 30 seconds to clear the buffer...then holding the "LF" button, turn it back on, until its self test is complete. You problem will be over.
Posted on Feb 06, 2008
Printer double spaces between lines
That is a setting in your printer setup menu under options or advanced. Page set up should come up under advanced or as its own tab.
Apr 09, 2014 | Citizen iDP-3550 Matrix Printer
I have a citizen 3550 printer how can i hook it up to my computer to print out misc. things instead of using you conventional printer?
Thank you for posting to Fixya.com and it is my pleasure to guide you.
To help you in the furture I have found the manual for reference. Click the link or copy paste it to download it. http://www.posguys.com/download/iDP3550UME_09E.pdf
From the manual for the Interface Cables, the manual has pictures.
4.2 Connecting the Interface Cable
1. Turn off the power. (Mating side included)
2. Check the top and bottom of the cable terminals, and connect to the interface connector.
3. Secure the cable terminals.
Serial interface: Tighten screws to secure.
Parallel interface : Turn clamps to secure.
4. Connect the interface cable to the computer.
4.3 Connecting the Drawer Kick-Out Connector
2. Check the top and bottom of the drawer kick-out cable connector and connect it to the drawer kick-out connector located at the lower section of the printer.
3. Screw the grounding cable of the drawer to the grounding terminal located at the lower section of the printer.
CAUTION: • Connect only the prescribed drawer (Solenoid) to the drawer kick -out connector.
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 21, 2011 | Citizen iDP-3550 Matrix Printer
After installing printer & drivers printer is still showing an error. Error light is flashing and "sel" button will not remove flashing error. Printer has paper installed correctly, ribbon is...
After installing the printer and the software you must reboot the computer to register the hardware changes. After booting up open your "printers" from the Control Panel or Start "settings - printers".
Make sure that the printer is listed. If it is listed, right click on it and select "properties". Now the printer control panel will come up. Select - "Print test page". If the software and cables are installed correctly the printer will be listed and it will print the test page.
In the same way, with a right click on the printer you can select to make it your "Default" printer.
New operating systems will see the new hardware and offer to install it for you. If you say yes and OK the computer will do an internet search and it should find the correct drivers for your operating system. If it does not find the correct drivers for your operating system you may have to the companies web page and select support - downloads and find your correct driver.
Apr 13, 2011 | Citizen iDP-3550 Receipt Printer PC...
Printer is printing jibberish = looks like a lot of "f"s underlined.
Try to turn the printer off and then on again. If that does not clear it you need to re-install the driver, the driver may be corrupt.
Nov 16, 2010 | Citizen iDP-3550 Matrix Printer
DELETING DOCUMENTS
if you double click on the printer in "printers and faxes" menu you should be able to click on the "printer" menu and click "cancel all documents" if it seems to hang on "deleting" right click on "my computer" and click "manage" expand the "services and applications" menu and click on services. find and single click on the the print spooler service and click "restart service" that should clear the job. If not, power the printer off, reboot your PC and then power the printer back on.
Apr 14, 2010 | HP DeskJet 3550 InkJet Printer
Jan 14, 2008 | Citizen 3550 Matrix Printer
How to disable the Okidata from printing double space
Try reseting to factory defaults.
Power unit on while holding down "tear" and "FF Load" buttons.
Hope this helps
Dezzi
Dec 27, 2007 | Office Equipment & Supplies
Documents in single space print in double space
There may be a dip switch somewhere on the printer which enables/disables the extra linefeed. If both CR (carriage return) & LF (linefeed) are both enabled, you will get the double-spacing. In years past, I've run a few different Epson dot matrix printers, and seems like they had such a dip switch. Also, on the software end, you may be able to disable either CR or LF- check in your printer driver software.
Apr 16, 2007 | Epson LX-300 Matrix Printer
Citizen 3550 Matrix Printer Logo
Top Citizen Office Equipment & Supplies Experts
Tejodhar Atreya...
Tejodhar Atreya...
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
