Question about Black & Decker String Trimmer Cordless 12" 18V
Spool does not release line when tapped - Black & Decker String Trimmer Cordless 12" 18V
    New Friend:
    Problem Solver:
  • 6 Answers
The auto feed system is really poorly designed and produced. But essentially its designed to feed when resistance is made against the centrifugal force when spinning. Basically two ways. You start trimming some heavy grass and that provides enough resistance to feed some line. Or you can fullly squeeze and quickly release the trigger a couple times. If you look inside the spool housing there will be a little lever that should move freely. Frequently inspect it as it goes out often. Also make sure theres no dirt build up on or around it or the rails it follows on the spool. If the tiny weight is missing then that lever is useless. On the bright side you can order them online for a couple bucks and they are pretty easy to replace.
Posted on Apr 01, 2014
    President:
  • Black & Decker Master
  • 1,545 Answers
You do not need to bump the head to advance the line. The machine has automatic line feed. If the line will not advance, then there is a problem with the line spool, possibly a tangle inside on it. Here is your instruction manual.
http://tinyurl.com/2vz3fhb
Posted on Sep 27, 2010
Got three poulan gas weedeaters, none of them will release line when tapping the bumper knob
have you cleaned all the grass and grit out of the entire head? Some times it will get gritty and sticky and not release Line when it gets low on line
Dec 21, 2017 | Poulan Garden
How do you remove the spool on an echo srm-2100 trimmer
Most units like yours has a tap head feed spool. To get to the line spool, you need to push the spool inward and rotate it to release it. The line spool is spring loaded, hence the need to push it in and rotate it to get it to release. You return the spool to the trimmer head housing after loading new line on it the same way, in reverse. Hope this info helps.
Sep 17, 2015 | Echo Garden
Tapping does not release string.
the string on the spool can become entangled and not release when required
if pressing the centre knob and pulling the string at the same time doesn
t get more string out the it will be in the spool
if the problem persists ,take it back for a warranty check as the button may not be releasing on tapping.
Aug 12, 2015 | Garden
How do you advance the line on the trimmer
To advance the line on a trimmer just push down in the center of the spool head then pull on both lines at the same time and it should release and inch or so of line. If it has a spring on the inside of the head then just tap it in the center of the head on a hard corner surface while its running and it will release more line out. That is what ya call a bump feeder as such.
Oct 19, 2014 | Garden
Manual for Rt112 weedeater I ordered parts for my weedeater. RT112 They sent a spring, a funny looking four-pronged clip and the black round spool with blue plastic string wrapped around it. I thought I...
Hi and welcome to FixYa, I am Kelly (almost old at 56)
I looked up your parts and have come to the conclusion that you have items 13, 14 and 15 of this link:
http://www.ereplacementparts.com/images/poulan/RT112_.pdf
Watch the video in this link:
http://www.ehow.com/video_4426520_learn-spool-weed-eater.html
it should help you.
I found the manual here:
http://lawnandgarden.manualsonline.com/manuals/mfg/weed_eater/rt110_rt112.html
SEE PAGE 7 of the above manual. Includes pictures. Try pressing in and rotating the spool to remove it.
1. Disconnect the unit from the power
source.
2. Remove the spool by firmly pulling on the
tap button.
3. Clean entire surface of hub and spool.
4. Replace with a pre-wound spool or cut a
length of 30 feet of 0.065! (1.65 mm) diameter
Weed Eaterr brand line. Use of
heavier lines could overload and damage
unit.
WARNING: Never use wire, rope,
string, etc., which can break off and become a
dangerous missile.
5. Insert one end of the line about 1/2 inch (1
cm) into the small hole inside the spool.
6. Wind the line evenly and tightly onto the
spool. Wind in the direction of the arrow
found on the spool.
7. Push the line into the notch, leaving 3 to 5
inches (7 -- 12 cm) unwound.
8. Insert the line into the exit hole in the hub
as shown in the illustration.
9. Align the notch with the line exit hole.
10. Push the spool into the hub until it snaps
into place.
11. Pull on the line extending outside the hub
to release it from the notch; otherwise, the
unit will not function properly.
Thanks for choosing FixYa,
Kelly
Jun 19, 2011 | Poulan Garden
Feed the string
Both lines run in same direction on spool. Make sure it is not pinched or fed through any of the arms in the spool just coming out one on each side of the hole. Tap bottom on ground while trimmer is running to feed line. Each time you tap it line comes out approx 2 inch at a time Common mistake is when new line is added it gets put on in opposite directions. Both do they same direction-arrows on spool tell the way.
Aug 23, 2010 | Homelite Mighty Lite Lawn Trimmer
How do I load string in a P2500 string trimmer??
Remove spool by firmly pulling on tap button. Cut two pieces of line (0.080) about 12 feet. Insert the two ends of the line into the small holes inside the spool. Wind the lines evenly and tightly on the spool. Wind the string in the direction of the arrows on the spool. Push the lines into the notches on the spool leaving three or five inches hanging there. Insert the two ends in the two holes in the hub. Align the notches on the spool with the holes in the hub and push it in until it snaps into place. Pull on the lines to release them from the notches.
May 03, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
How do you refill the string on the homelite electric, straigh shaft, 13 in Trimmer?
Is the sting the cutting line at the bottom of the trimmer? If it is pull the spool out. At the bottom of the spool there is an arrow pointing in the direction that the line should be wound. When you first put in the line be sure to place the cutting line in the grove (V shape) and then when you put enough line around the spool. Thread the end of the line thru the hole on the side of the spool. Slide the spool over the shaft of the trimmer and it will click in. When the line is short just tap the spool lightly on the grass and it will feed out more line.
Good Luck.
Jan 06, 2010 | Homelite Garden
Trimmer line on spool of Challenge 250 Watt Grass Trimmer.will not automatically feed as it is supposed to do when tapped on firm surface - can you let me see by diagram how the line is feed onto spool and...
I did a lot of searching for a manual but I guess Argos does not want their customers to know how to use their product. When you are use the trimmer, most rotate clockwise. You may find on the spool an arrow showing direction to wind line. Otherwise you will have to take it apart the trimmer and remember with direction the spool turns. Wind the string on the same direction turns. plus try a little wd40 on the line to keep it from sticking together.
Cheers.
Oct 12, 2009 | Garden
My homelite trimmer string keeps getting stuck and when i tap it to release more string it doesn't the spring in it doesn't spring at all. I constantly have to stop take it apart pull enough string to edge...
It's sticking pretty good. Try what I do: Pull the head off and clean it out pretty good. Also clean where the spool attaches to the trimmer. Before you reassemble it, give it a shot of powdered graphite (I get mine at the hardware store. It's for locks). Reassemble the spool onto the trimmer. Bump it on the ground several times to distribute the graphite within the head. Now, press the head in and pull on the trimmer line. It should dispense a little line and stop, just like when the machine is in operation. If it works, you're done! If it doesn't work, you will need to replace the spool. They are available at the major hardware stores. Even if you have to replace the spool, the graphite trick is a good one. It'll keep the head dispensing line smoothly. I add the graphite probably every 7th or 8th time I rewind the spool.
Best regards, --W/D--
Aug 09, 2009 | Homelite Garden
Black & Decker String Trimmer Cordless 12" 18V Logo
376 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
