Question about Health-O-Meter Health O Meter 349KLX Portable Digital Scale with Serial Port, 400 Lb Capacity, 0.2 Lb Resolution
The scale keeps saying batt even though we have changed the battery twice
Second request re: taylor lithium electronic scale model 7000 not working after changing battery twice. Yes interested correctly
On Amazon this scale got 24% 5 star and 43% 1 star rating.
In many cases it quit working or broke in some way.
"I owned this model for 1 year before it gave me the "batt" signal. after I spent another $7 on new lithium batteries, it turned out the scale was broken. looking on the web, I discovered lots of other stories like mine. advice: find another brand."
Aug 03, 2016 | Taylor Health & Beauty
When you get onto the scale (Taylor Lithium 7506), the numbers just keep cycling and never stop. We tried changing the battery, even though the scale is less than three months old, but it still does the...
Turn it over - take out battery and check with multimeter to ensure it is still workable - let sit for 10 to 15 seconds - replace battery - set it on level surface and step on and back off. Step on it again and it should now work.
Sep 16, 2011 | Taylor 7506 Precision Tech Lithium Battery...
I have a Taylor 9856 scale. The batt message came on so I changed the battery. Now it doesn't work.
"After replacing the 9-volt battery, the scale wouldn't turn on. I tried new Duracell and a Kroger brand batteries. I eventually discovered that the stock battery (Tianqiu brand) was shaped slightly differently from the new batteries. The minus contacts were not quite touching. Luckily, I just had to bend out the connector on the scale so that it touched the battery. Now it works again."
Aug 06, 2011 | Health & Beauty
Even though I change the battery, ti 89 keeps going off I don't know what's wrong
Try to reset
instal all the 4 battery's take one out
press and hold Right Arrow, Left Arrow, 2nd, On install the batt
wait 5 seconds
this is the reset if it will not help it could be an hardware failure
ecrdn@yahoo.com
Jack
Feb 14, 2011 | Texas Instruments TI-89 Calculator
Camera keeps saying low battery. although new batteries were installed twice
Please check if the new batteries are alkaline or rechargeable NiMH Batteries. Normal AA batteries my only take one shot and will be low batt.
Aug 23, 2010 | Canon PowerShot A1100 IS Digital Camera
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate batteries, turned the correct way. Cleaned off the battery terminals and still have replace battery...
Thermostat problem; Honeywell chronotherm lll ' Low Batt. indicator Keeps blinking after Batteries replace. I chk'd batt. with elect. volt ntr. Was told to pull batt. and change ends with them , letthem stay reversed for 5-10 sec. then put them back in right order,and replace thermostat. No success!
Anyone have any answers
Nov 12, 2009 | Honeywell Power Humidifier: Furnace...
Carbon Monoxide wired to the house, no battery, beeping
the batt is used for backup. Its beeping to get you to install a batt
Jun 18, 2009 | First Alert SA302 Dual System Smoke...
Battery
if you did keep the lappy on the charger all the time with the batt still pluged in it will wear the batt down...Yes even if you never ran off the batt...they lose power and recharge even when not being run off of...check the connections though and if you can see any probs (dirt,disscoloration anything) then it could be there. If now try finding a batt store that deals with batts they norm can test and fix em if its only a cell or so that has gone bad other than that run it down till its dead and recharge it to the max and see..
Aug 20, 2006 | MSI MS-1012 Notebook
Health-O-Meter Health O Meter 349KLX Portable Digital Scale with Serial Port, 400 Lb Capacity, 0.2 Lb Resolution Logo
19 people viewed this question
Top Health-O-Meter Health & Beauty Experts
Shehu Pro
Shehu Pro
NOEL
NOEL
terry stevens
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
