Dv4
OLD LAPTOPS
You must be old like me,using TV bad tuner reception comparison.
the LCD is bad.
gently twist the frame of the the screen/
see the lines get worse
bad screen. easy no? just simple twist.
its super common, and they are fragile.dropped or hit;
Usually this means u have a damaged led panel or panel ribbon connector try a new LED screen first try ordering from Amazon get the numbers off the back of the screen
SOURCE: HP laptop not booting up - blank screen
hi
I had the same problem faced twice in one month, and it’s a new laptop just one month old,
I have removed battery for for few minutes and fixed it back. And it's working fine now.
If it continues what should I do?
SOURCE: Vertical white line on laptop display
Yes, this is a defective screen. The only fix is to replace the screen. It's called a column of dead pixels. Since it is under warranty, contact HP to have them warranty it out or take it back to the place you purchased it from for an exchange. Please take a moment and give this answer a good rating of fixya. Thank you.
SOURCE: hp dv6000 laptop screen has rainbow lines on it
Normal
0
false
false
false
MicrosoftInternetExplorer4
st1\:*{behavior:url(#ieooui) }
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Sounds like there is a bad connection somewhere on your
screen.
Is the computer new? If it is, send it back to where it came from for a repair.
If it is not new and it has passed its warranty, then you may have to take the Basel of the screen and
see if there are any sockets that are not connected properly. The problem with
doing this, with SOME laptops, you have to take off the main cover off the
laptop before you can take the Basel
off the screen.
If you do need to take it apart, please touch something like a metal plug sockets
screw or a unpainted radiator pip before you do this to get rid of any static
you gave on you otherwise the is a chance of permanently damaging you computer
the connections inside laptops are usually just thin wires that go into sockets
and the clips that secure the cables lift up and the cable can just be pulled
out or inserted with ease. If you can open your laptop and check the
connections, just firmly push them all in to make sure they are all connected
properly
Good Luck
SOURCE: Hp pavilion dv9000 wont boot,coloured lines appear no bootscreen
This is caused by burn out of the Nvidia graphics chip on the motherboard. You need a new motherboard. This is due to a design flaw (the subject of a class action against HP in the USA). I have had two motherboards fail on me in this way so far - do not expect any worthwhile support from the HP "support" people they are all in India and can hardly communicate outside of their simple repetative scripts. Its impossible to escape them - I tried communicating with head office but all you get is contact details back to the incomprehensible Indian call centre. I strongly recommend against ever purchasing from HP again.
SOURCE: I have a hp pavilion dv4-1220us computer with
Pl install your printer driver compatible to Windows Vista.
