Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
PAC L90 leaking oily substance
My PAC L90 was blowing air, like a fan, but not cold air so I decided to open it up. I found that there was a crack in a 1/4 inch copper pipe that connects the compresor to what looks like a radiator. There was an oily substance that leaked out - and there was alot of it. I mended the break by adding a 3/8 inch copper pipe that was about an inch long and sweat them together. After doing so, the problem still remained. I assume that whatever the oily substance was, it needs to be replenished. Can someone please tell me what this oily substance is and if I can replenish it myself (if possible) or if I can take it to someone to rpelenish it? Thanks.
    Genius:
  • 1,554 Answers
It leaked all the freon and oil out .
it needs to be vacuumed and oil replenished.
filled with freon.
should only cost you bout 50.give or take
as they use very little freon.
a shrader valve port has to be added to introduce the freon. takes just a few seconds.
Posted on Jun 04, 2008
PAC L90 air conditioner keeps frosting up. The room air intake frosts up completely, blocking all the air.
Air conditioners frost up when there is a lack of air flow. Clean the filter, check if a belt is broken (if any), check that the fan spins freely, check all in ports and out ports for blockage and clean the coils with mild soap and water.
Jun 08, 2016 | DeLonghi PAC L90 Portable Air Conditioner
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
I have a pf code flashong on my a/c unit. Could you tell me what it means. I have the PAC l90
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Sep 24, 2010 | DeLonghi PAC L90 Portable Air Conditioner
My 95 rodeo is loosing oil pressure then heats up and dies?
There are a fw possibilities.
1. you have a cracked block and the oil is going in to the water system. To check this open the water cap ,When cold , and see if there is a milky substance in the water.
2. Look to see if there are any oily leaks around the valve pan areas.
3.Your oil pump may be failing.
Jul 12, 2009 | 1991 Isuzu Rodeo
How to conect my air condittinion pinguino pca L90
This really Expensive AC quite on me. The fan works great, I hear the Compressor turn on and it still doesnt blow cold air. Should I flip out?
May 14, 2009 | DeLonghi Pinguino PAC-700T Air Conditioner
PINGUINO PAC-L90 PORTABLE AIRCONDITIONER
yes we charge freon if it leaks out, but we fix the leak first. but also it may have electrical problem only, better get it check with a technician
May 09, 2009 | DeLonghi Pinguino PACL90 Portable Air...
PAC-L90 NOT BLOWING COLD AIR . DO YOU HAVE TO ADD ANY R22 OR FREEON TO THESE SYSTEMS
they all take refrigerant but there are other things like dirty filter or condensor coils that will cause the same problem
PAC L90 water tank capacity
when tank is full you will get the letters FE will signal a FULL TANK
(The tank is full)
You have it setup to constantly drain GOOD.
Should you should not plug the drain hoses to get colder air.
Do let it drain . It is more convenient!
If the unit is the proper BTU for the square footage of the area to be cooled it will be cold!
If the tank gets full you will not get cool air?
Please remember to leave a rating before you go!
Thank you
Jul 28, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi Pac L90
Hoses for proper connection should have been included with your purchase. Without the hoses the set-up can not be done satisfactory. One is for fresh air supply and the other is the hot air exit hose. These are normally vented out a window. Check with the dealer where you perchased the unit from. If from a private individual contact them.
May 21, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
316 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
