Question about Princeton Digital VL1918 Monitor
I just hooked up this monitor princeton monitor VL SERIES vl1918 it is flashing off and on. Help please
  • 823 Answers
There is an electrical problem with either the power cord connected to the monitor or the outlet that it is plugged into.
If its a brand new monitor, return it to the place of purchase and exchange it.
If its a used monitor then I would suspect that someone has given you the wrong power cord for the unit. Sometimes people check to see which cord "fits" the unit and think that its appropriate because they can connect it.
That is not correct when it comes to monitors. Just because a power cord fits by connecting to the monitor does not always mean its appropriate to run it correctly.
Check the voltage requirements on back of the monitor and compare them to the power cord your using with it. If they are appropriate and your still experiencing this problem then the power cord might be bad.
Test this possibility by disconnecting the monitor from the computer and turn it on. Do you see a screen that says "no video" or "no connection"? Does the screen blink the same way as when connected to the pc? If it does, then its the power cord or supply source its connected to. Plug it into another socket and and see if you get the same thing and that tells you its the cord.
If the display is good when not connected to your pc, then use a process of elimination to figure out if its the monitor cords connector that is broken or frayed or if its the video card connection that is either loose and needs to be re seated in your case or the connection itself is unsturdy and needs the bolts tightened to give a solid connection.
How do you do that?
Check the pins on the end of the cable that connects the monitor to your pc. Are any broken, missing or bent?. Check the other end that connects to the monitor and verify the same thing.
Then try and jiggle the video card by grabbing the area that you connect the monitor cable to on the back of your pc's case and see if it is loose. If it is, get a screwdriver and tighten the screws until its tight.
Try plugging it in again and see if this solves your problems. If it doesn't then clarify your findings and I will help you solve this issue another way.
Posted on Sep 27, 2010
  • 11,361 Answers
Look for bad caps, shorted transistors, etc as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Nov 12, 2010
HOW TO HOOK UP PRINCETON VL1916 MONITOR
You'll get the manual here :
https://www.google.fr/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCQQFjAA&url=http%3A%2F%2Fsomemanuals.com%2FPRINCETON%2CVL1916-FE%2CDFFHI.PDF&ei=BewCVJy6FeWc0AWMsoCQCQ&usg=AFQjCNF_tw-Zz4qDTUP8Gs9fhVCdaSVSqA&sig2=hzPNSlSA0Noya_Uh88bwpA&bvm=bv.74115972,d.d2s&cad=rja
Aug 24, 2014 | Princeton Digital VL1918 Monitor
My VL 1918 is blinking on and off constantly
It does the same when used with another PC?
Otherwise, look for bad caps, transistors, transformers as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/PRINCETON/Princeton%20VL1918W/#!cpZZ1QQtppZZ20
Very common problem as you can see.
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 07, 2011 | Princeton Digital VL1918 Monitor
How do I change the size of the image of a Princeton Digital VL 1918?
You can't change the image size as such actually on the monitor but you can change the size of the image feeding the monitor.
In windows right click the desktop, click properties in drop down menu then click settings.The setting should correspond with the native setting of the monitor which is 1280x1024 pixels and that is what you should set it to.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 24, 2011 | Princeton Digital VL1918 Monitor
I've opened my princeton vl 1919 monitor to see if the caps are blown. I can't loosen the grey metal cover covering the boards to see the caps. I've removed the hexes on either side of the video inputs but...
Not sure if the VL1918 uses the same chassis as your, just remove the 4 screws and disconnect all the lamps connectors and other connectors.
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Can you post the pictures? so I can see what it is about.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 06, 2011 | Princeton Digital VL1919 19" Monitor
Hello I can't get anything on my screen except
Your PC is putting too high resolution for he VL1918 to display.
You need to set your PC video out put to the native resolution of the VL1918, which is 1280x1024 @60Hz.
You will have to hook up your old monitor (crt type?) and set the new resolution.
Or boot up in safe mode (hit f8 during boot up), and set the resolution to 640 x 480, reboot into regular mode, then rest the resolution to 1280x1024 260Hz.
Also watch out for bad caps in this monitor: http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
Apr 07, 2010 | Princeton Digital VL1918 Monitor
Need to download drivers for a princeton vl1918 HELP!
open the internet and open the link www.softwaredriverdownload.com/princeton_graphics_vl2018w_driver.html - United States and you can instantly download the drivers
Mar 28, 2010 | Princeton Digital VL1918 Monitor
Princeton vl1918 flashes on than off
See previous solution for Princton Monitor cycling on and off.
Solution: Change out 3 capacitors.
Jul 15, 2009 | Princeton Digital VL1918 Monitor
How is the cover removed from the Princeton VL1918
Theres sort of clips that clips to the side of the monitor's frame, use a flat screwdrive to care fully push through the sides of the LCD to unlock the clips.
Nov 15, 2008 | Princeton Digital VL1918 Monitor
Will Princeton monitor VL1918 support NVIDIA GeForce 6150 SE
Hi Alvie
I Just checked the specs on both the card and the monitor. It should work no problem. If for some reason you notice some lag or flicker in the monitor, go to this page and download the updated ForceWare graphics drivers.
http://www.nvidia.com/object/winxp_169.21_whql.html
Mar 27, 2008 | Princeton Digital VL1918 Monitor
Princeton Digital VL1918 Monitor Logo
226 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
William Ward
Level 1 Expert
Fishlung
Level 1 Expert
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
