Question about Plantronics CS55 Wireless Headset
My plantronics CS55 headset doesn't beep in my ear when there is an incoming call? We are using a Cisco phone system. Thanks.
  • 32 Answers
SOURCE: I have plantronic headset model CS55 the green light is blinking
Either the battery is low, or the unit is switched on.  If you're looking at the base unit of the CS55, on the right hand side there is a switch that either points to I or II.  If it's on II, your headset will be activated the second it is removed from the base.  If it's on I, it won't turn on, thus it won't turn the light on.  Check to make sure that dial is on I instead of II, and when you pick it up you shouldn't have that problem anymore.
If it's a problem with low battery you have to make sure that when you place the headset on the charging cradle that it's securely seated in there.  Also make sure that you clean the charging contacts (the brass-coloured contacts on the headset and on the base) about once a month with rubbing alcohol.
Posted on Apr 28, 2009
  • 32 Answers
SOURCE: phone doesn't ring in earpiece
Only if you have an HL-10 lifter installed... you will then be able to hear three short beeps in your ear to indicate the phone is ringing.
keekus
  • 83 Answers
SOURCE: outside caller hears themselves in an echo
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Posted on Jul 18, 2009
keekus
  • 83 Answers
SOURCE: plantronics cs55 problem
Turn on the wireless headset as soon as the HL10 lifter picks up the headset. Remember to press the call answer switch. A steady green light should come on the base and the wireless headset should have a small green blinking light on, on its side.
* Make sure your hand receiver is off the hook when using the headset. Also check that you hear a dial tone on the handset/hand receiver before turning on the headset.
keekus
  • 83 Answers
SOURCE: Plantronics CS55/HL10 Wireless Office Headset System with Lifter won't lift headset
You may need to re-subscribe the headset.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
Posted on Jul 20, 2009
Plantronics CS55 Headset
Office was wired that way i have one tried several ways to use it without the lifter did't work had to buy a lifter the next problem is the phone not all will work Cisco uniden will work good
Jun 18, 2014 | Plantronics CS55 Wireless Headset
We are using the Plantronics CS55 wireless headsets. The users are complaining that the '3-beep' incoming call alert tones are too loud. We have tried to adjust this tone level by manipulating...
Lowering the ring volume on the phone only decreases the sensitivity of the lifter, which generates the signal to the headset. The signal volume between the two is preset and cannot be adjusted.
Good luck from Headsets Direct!
Jul 20, 2011 | Plantronics CS55 Wireless Headset
I cannot here the phone ringing from my CS55 headset or another call coming in.
You will need the Plantronics HL10 handset lifter in order to have the CS55 ring, indicating an incoming call. The HL10 also allows you to answer remotely on most phones and hang-up remotely.
Plantronics HL10 Handset Lifter
Good Luck from Headsets Direct!
May 17, 2011 | Plantronics PL-CS55 Wireless Headset
Incoming call alert
May 17, 2011 | Plantronics CS55 Wireless Headset
No beeping in ear piece
The microphone in the lifter was not centered over the microphone on my phone, so all I did was centered the lifter over the microphone, and it works.
Mar 18, 2009 | Plantronics PL-CS55 Wireless Headset
Outside caller hears themselves in an echo
Jan 23, 2009 | Plantronics CS55 Wireless Headset
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Phone doesn't ring in earpiece
Jul 31, 2008 | Plantronics CS55 Wireless Headset
Best Buy: Plantronics Problem
James, plug the phone cord that comes out of the back of the CS55 base into the handset port of the Cisco phone, not the headset port.  Then plug the coily cord from the cisco receiver into the front of the CS55.  Don't use the "Headset" button on your Cisco phone, just lift the receiver off.
Mar 21, 2008 | Plantronics PL-CS55 Wireless Headset
Plantronics CS55  Wireless Headset Logo
751 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
